Old 18th July 2024, 17:22   #2321  |  Link
nji
Yes, that's the way I do it manually now.
But I have to do it all the time - if I recognize at all that a movie is cropped.
I wonder if MPC-HC has a permanent mode to do as decribed?
nji is offline   Reply With Quote
Old 19th July 2024, 14:59   #2322  |  Link
LigH
LigH's Avatar
MPC-HC 2.3.3
New German Gleitz board
Old 19th July 2024, 16:30   #2323  |  Link
Amuat
Went from basically never having errors after switching from madVR to MPC-VR to now constantly having multiple skipped frames, without having changed any settings. Is this an issue with new drivers or might something else explain this?
Amuat is offline   Reply With Quote
Old 20th July 2024, 08:57   #2324  |  Link
rgr
Originally Posted by LigH View Post
"The file delete function now shows a confirmation prompt on Windows 10/11, because Windows may not show one by itself anymore like it did in the past."
But doesn't it depend on how someone has set the file deletion confirmation in the system?
rgr is offline   Reply With Quote
Old 20th July 2024, 11:28   #2325  |  Link
varekai
varekai's Avatar
cosmetics
options→output→directshow video→settings→properties
varekai is offline   Reply With Quote
Old 21st July 2024, 11:56   #2326  |  Link
rgr
What is the Video Frame->Correct Monitor/Desktop AR Diff option for?
When I turn it on, my video resolution changes from 1450x1080 to 1450x1067. Since I have a monitor with PAR 1:1, this shouldn't have any effect, should I? Am I missing something?
https://imgur.com/EdIyvy3
Old 21st July 2024, 19:34   #2327  |  Link
Sunspark
Leave it off, your player is already set to scale DVDs, etc. to the correct aspect ratio for your display. If you were outputting to a CRT, then you probably need this option since the pixels aren't square there. In other words, the player knows the resolution of the display and aspect ratio as well as that of the video, but it doesn't know if the display itself isn't using square pixels.
A simple test, a DVD with a perfect circle on it, with the default scaling settings it displays on a square pixel monitor as a round circle. Turning the option on stretches it slightly to make it more oblong.
If I'm wrong, someone correct me.
Old 24th July 2024, 23:48   #2328  |  Link
Bahamuth
Would really be nice if that could be configurable within MPC-HC. I was wondering about this, checked my recycle bin options and was puzzled. Couldn't find anything to configure such in the options, not even in the advanced options.
Bahamuth is offline   Reply With Quote
Old 25th July 2024, 14:13   #2329  |  Link
hubblec4
Matroska find' ich toll
Hi clsid
I have some question about playback and jumping:
When MPC-HC play a video(with audio streams) and there is a jump to another position in the file (ordered chapters or a user jump):
What happens with the Audio frame which is currently playing?
Lets say the Audio is an AC3 (32ms frame duration) and after 5ms comes a jump to another position: what happens with the last 27ms of this audio frame?
Fully ignored, and the new Audio frame will be played directly?
What happens when in an mkv file a duration(BlockDuration) for a Audio frame is defined?
Is the entire audio frame played in this "new duration", or play the audio frame only the given duration and omit the rest of the frame?
hubblec4 is offline   Reply With Quote
Old 28th July 2024, 08:16   #2330  |  Link
kieksiedus
Since I guess the latest 3 versions I have this annoying playing-status getting stuck in the top left corner when in fullscreen-mode (I use D3D). It won't go away, I have to exit fullscreen and wait for it to disappear after some time and go fullscreen again. Is anyone else aware of this bug?
kieksiedus is offline   Reply With Quote
Old 12th August 2024, 11:50   #2331  |  Link
Konrad Klar
Konrad Klar's Avatar
I set "Toggle normalization" to Num 5 but it does not work.
Normalization that is disabled in Options is still disabled after I press Num 5 (while watching video).
MCP-HC 2.3.4 x64 Windows 7 x64 (and the same in previous version of MCP-HC, I did not check other versions)
Konrad Klar is offline   Reply With Quote
Old 12th August 2024, 12:13   #2332  |  Link
clsid
Num5 is already assigned to Pan&Scan reset.
It shows red background color when you duplicate a key assignment. It does that for a reason!
MPC-HC 2.3.4
Old 12th August 2024, 12:16   #2333  |  Link
Konrad Klar
Working!
Old 12th August 2024, 18:28   #2334  |  Link
kieksiedus
It got fixed in the latest version 2.3.4
Old 16th August 2024, 06:06   #2335  |  Link
Bellator
Originally Posted by GMJCZP View Post
I have noticed that in MPC-HC when an MP3 file has 2 Front Cover it always shows the second in the order, WmP and Xmplay for example show the first Front Cover.
Hello, I know this is an old post but I think they fixed this with the new updates.
However I actually prefer the settings this way, Does anyone here know if there an option to set in MPC-HC so that it's the second cover shows when playing, instead of the first?
For clarification, I'm still using v1.9.16 since the newer versions no longer show the second cover when playing using MPC
Bellator is offline   Reply With Quote
Old 19th August 2024, 00:43   #2336  |  Link
jay123210599
How do I play videos backwards?
jay123210599 is offline   Reply With Quote
Old 19th August 2024, 04:45   #2337  |  Link
v0lt
1. Install AviSynth+ and FFmpegSource (FFMS2) plugin.
2. Create video_reverse.avs file, specifying the path to the desired video file.
file = "с:\Temp\video.mkv"
A = FFAudioSource(file)
V = FFVideoSource(file)
AudioDub(V, A)
Reverse()
3. Open the .avs file in MPC-HC.
4. Stop asking the same question in different threads.
v0lt is offline   Reply With Quote
Old 19th August 2024, 20:12   #2338  |  Link
jay123210599
AudioDub(V, A)
Reverse()
@v0lt Can you help me out with this?
https://forum.doom9.org/showthread.php?t=185682
Old 21st August 2024, 12:43   #2339  |  Link
rgr
Is there a chance that MPC-HC will respect AviSynth flags during playback?
Just like ffmpeg, which does it strangely though, because by default it respects only some flags.
Old 21st August 2024, 12:46   #2340  |  Link
rgr
VDub2:
Video->Decode Menu-->change 709 to 601 (or vice versa).
Or post a sample but not in this thread.
