11th August 2022, 14:56 | #1401 | Link |
SMDegrain(tr=2,"
Max possible temporal denoising amplitude is about doubled with about 4x of tr-value. So tr=2 with 4 ref frames may only about half of noise amplitude. To decrease noise more it is required something like 2x4=8 or 2x16=32 (about 4 times less noise in lucky case of all ref blocks found and used). With too big noise level and too high thSAD it is good to set thSCD1 not below thSAD value. I think it is visibly faster to increase tr-value with single pass. Also if any prefiltering used - all th-values require re-adjustment. Because prefiltering typically make SAD values lower. Last edited by DTL; 11th August 2022 at 15:21. |
13th August 2022, 01:49 | #1402 | Link |
Hi, i report that deep_resize had problem when downscale from 4k to 1080p
I tried with this script: deep_resize(1920,edge="Zopti1080") But in video, her hair is wrong color My sample: https://youtu.be/49R_nMEW7X8 |
13th August 2022, 10:37 | #1403 | Link |
Thanks, updated TransformsPack - Main with a fix and some cosmetics.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
13th August 2022, 14:53 | #1404 | Link |
21 years and counting...
It doesn't seem to be SMDegrain related. My old statement that DGDenoise() works fine is not valid. I get the very same errors when using DGDenoise() alone and denoising the chroma planes. With cstrength=0 the problem seems to be gone. Will report this to DG. Maybe he can reproduce that error. Last edited by LeXXuz; 13th August 2022 at 17:38. |
14th August 2022, 13:02 | #1405 | Link |
@LeXXuz, thanks for reporting back. Just retested with ConvertBits(16).DGDenoise(cstrength=2) and I don't get the issue so as it looks it's driver/GPU related. I'm still on Win7 so I use the latest 400 branch driver version.
14th August 2022, 14:18 | #1406 | Link |
I'm on the lastest driver win10x64 - 3070TI, no issues here.
Post your script.
15th August 2022, 07:32 | #1407 | Link |
Problem is solved. And it was much simpler and stupider than expected. I downloaded a new mtmodes.avsi on that machine a few weeks back and some smart person thought it would be a good idea to set DGDenoise() as a NICE_FILTER. Well, you can guess the rest, I think.
20th August 2022, 19:40 | #1408 | Link |
Acid fr0g
Could you please suggest me some good quality resizer to resample from 720p to 1080p (1.5x)?
Unfortunately Waifu2x accepts 1.5 only. Any workaround or better to use deepresize or nnedi3resize? How to use them with nnedi3cl? What about the parameters? I always hope you find the time to write some documentation.
@turment on Telegram |
20th August 2022, 20:00 | #1409 | Link |
ResizersPack was updated with NNEDI3CL by default, you can switch to nnedi3 cpu with gpuid=-1 (read dependencies)
Yes, deep_resize is the way to go for quality resizing (like nnedi3_resize16() was before), it mixes different kernels for edge/flat/chroma areas. By default it's set to optimal kernels (check examples) but you can play with other ones if you want FCBI, etc. I haven't implemented waifu2 yet.
20th August 2022, 20:10 | #1410 | Link |
Acid fr0g
Any hint for anime? As usual 1080p are 720p with bicubic. I inverted the process and now I want to rescale to proper resolution.
I have tried w2xncnnvk by Asd-g but, as I told, it supports only 2x.
20th August 2022, 20:46 | #1413 | Link |
Then it's the same behavior than nnedi3, loop waifu2 until closest target dimensions then use alternative scaler to downscale or upscale. Didee bicubic coeffs are very good for small downscales.
21st August 2022, 02:31 | #1415 | Link |
What do you need to know, it's pretty straight forward.
Read the comments for the settings. In any case everything is already tuned for best results by default depending on up/dw scaling and the ratio of it. Code:
rth = Default(th_rat, 1.25) # threshold for mix mode. Lower than this (target_size/source_size) will use only 'kernel1' kernel krn1 = Default(edge, rat<=rth*0.95 ? "Didee" : /* # Resize kernel for the edge area. AI upscalers recommended here: nnedi3, FSRCNN, FCBI, SuperResXBR... or for downscaling: DPID, SSIM2, Zopti */ \ rw<1 && rh<1 ? isUHD ? "Zopti1080" : "SSIM2" : /* # By default, for small upscales -> "blackman" (define *small* with 'th_rat' value) */ \ rat<=rth ? "Blackman" : "nnedi3") /* # By default, for big upscales -> "nnedi3" # By default, for small downscales -> "Didée" # By default, for big downscales -> "Zopti1080" # By default, for mid downscales -> "SSIM2" (DPID also fine for down to 720p) (Beware!! for UHD to HD against all logic I recommend going with Zopti1080 (b=-0.99,c=0.06) ) */ krn1c = Default(chroma,rw<1 && rh<1 ? "Zopti" : "Blackman") # Chroma resizing kernel (no edge/flat discretion) *Remember you can directly call "kernel + taps". ie. Blackman6, Lanczos4 krn2 = Default(flat, rw<1 && rh<1 ? krn1 : isHD && isUHD2 ? "Sinc" : "Lanczos" ) # Resize kernel for the flat area (noop when downscaling). Ringing kernels are ok here (specially when up ratio is <1.7) like SincLin, Blackman, Lanczos, Sinc... ('Sinc' low taps -ie. 4- is worth testing, creates some faints halos specially for SD to HD so see whether it's faint enough for you) etp = Default(e_taps, krn1 =="Blackman" ? 6 : krn1 =="Lanczos" ? 4 : 0) # taps for edge kernel (0 for undefined) ftp = Default(f_taps, krn2 =="Blackman" ? 16 : krn2 =="Lanczos" ? 8 : 0) # taps for flat kernel (0 for undefined) ctp = Default(c_taps, krn1c=="Blackman" ? 6 : krn1c=="Lanczos" ? 4 : 0) # taps for chroma kernel (0 for undefined) thr = Default(th, 1.0) # 0-255 (normally up to 10) ela = Default(elast, 4.0) # 1-255 (normally up to 10) qual = Default(qual, 1) sh = Default(show, false) gpuid = Default(gpuid, 0) # Set to -1 for "cpu" nnedi3 dec = Default(deconv, 0) # 0~10 (0 is disabled, raise to apply deconvolution when upscaling a very sharpened downscale -anything sharper than Catmull-Rom-) gr = Default(grain, rw>1 && rh>1 && rat>rth ? 0.6 : 0 ) # Grain strength. >0 Add grain to big upscales as a mean of cheap hallucination
21st August 2022, 09:34 | #1416 | Link |
Pig on the wing
DGSource("test.dgi",ct=44,cb=44,cl=0,cr=0) a=deep_resize(1920, 1040) interleave(bicubicresize(1920, 1040, b=-0.5, c=0.25).propshow, a.propshow)
21st August 2022, 17:09 | #1417 | Link |
Yes, the chroma loc property was already fixed internally yesterday, and about the warmer tones I don't get them, but as I said I made some changes and fixes to TransformsPack, will release tomorrow probably.
21st August 2022, 23:15 | #1419 | Link |
fmtc hard codes 32-bit to full range so it's going to confuse you a little bit.
I have been refactoring a few things in ConvertFormat() to make it more robust, fixed quite a bit. With luck the next version after this one will finally be v1.0. Also added waifu2xresize() a wrapper for w2xncnnvk. Quality is very good as expected, sharper than nnedi3 but very slow (~1fps on my card)
avisynth, dogway, filters, hbd, packs |
