14th April 2003, 04:26 | #82 | Link |
I've only just noticed that eclCCE is here to provide DVD2SVCD support for CCE 2.66 Trial, so I downloaded eclCCE and went through the installation and Usage portions of the eclCCE pdf. I must be missing something though, because every time DVD2SVCD gets to encoding, CCE says
Limitation of Trial Version Can't save ECL file. and in the DVD2SVCD log Executing Cinema Craft Encoder. Error cannot find CCE project file. I've got the CCE path pointing to eclCCE.exe, which is in the same dir as CCE 2.66.01.04 and eclCCE.dll, and the eclCCE.ini is set for cctspt.exe. It does the same thing if I run just eclCCE and load the AviSynth_Script_file.avs DVD2SVCD created. I'm using Keep Interlaced and an Interlaced Source CCE template made while reading the eclCCE pdf. The DVD2SVCD log file also says it has to perform IVTC based on the DVD2AVI project file. Any idea? -=<halcyon>=- |
14th April 2003, 08:13 | #83 | Link |
Retired
CCE 2.66.01.04 is not supported by the ECL functionality in EclCCE, this is in the readme. You need to use 2.66.01.07 at least. See http://forum.doom9.org/showthread.ph...r=2#post290438 for an unsupported workaround.
15th April 2003, 11:07 | #85 | Link |
EclCCE doesn't give CCE tthe correct task priority!
I'm using this nice tool together with DVD2SVCD where I have choosen the priority ILDE. EclCCE gets this priority correct, but CCE always runns as normal! EclCCE should check which priority itself has and take this priority also for CCE. For DVD2SVCD it is more difficut to implement this that it is for you because the autor can get the correct handle of EclCCE by using ShellExecute, but if he wants to reach CCE behind your program he needs to search the correct CCE window! If the user has multiple instances of CCE running at the same time this is much to difficult so you should implement this small feature in your program. THANK YOU FOR YOUR WORK & HELP! Regards TKS |
15th April 2003, 11:53 | #87 | Link | |
@RB
I'm using EclCCE 1.3, CCE 2.67.00.09, DVD2SVCD 1.1.3b2 unter Win2K. Quote:
Regards TKS |
15th April 2003, 12:18 | #88 | Link |
Retired
Strange. On my system (XP and 2000), when EclCCE is run with idle process priority either via the "Start" command or DVD2SVCD, then cctspt.exe runs with that same priority (idle). Did you actually go into task manager and check this? This is also what the MS docs say. That is, a process running with idle or normal priority inherits it's priority to child processes.
15th April 2003, 12:33 | #89 | Link | ||
Regards TKS |
16th April 2003, 13:13 | #90 | Link |
Retired
New version 1.4 is out. Here are the changes:
16/04/2003 v1.4 - Added option to shut down system after encoding - Added EclCCE settings dialog along with the ability to specify the CCE process priority - Added a manifest file for CCE to the distribution. Copy cctspt.exe.manifest to the CCE installation directory to apply Windows XP visual styles. - Fixed: CCE window title was set incorrectly when ECL file name contained a dash - Fixed: in some cases Encoding did not start when clicking Yes in the "Save changes....?" prompt and then canceling the Save dialog. - Fixed: in some cases you were not prompted to save changes after modifying the Bitrate Tweak settings. - Fixed: problem with hooking into CCE when EclCCE.exe was run with process priorities above "Normal". |
25th April 2003, 08:00 | #91 | Link |
@RB
Great stuff, really slick. I wanted to request saving of the 3:2 pulldown detection settings. You mention earlier in the thread that you might work on that if there is demand...so I wanted to speak up. (My dream is to write a program that would take a DVD2AVI project and use the field flags in it to instruct CCE exactly how to encode a hybrid source. The hope is that this would allow one to, with CCE, create an exact copy of a hybrid source -- something currently possible with DVD2One and the like, but at the cost of image quality.) |
25th April 2003, 11:03 | #92 | Link |
Retired
Custom technology released CCE 2.67.00.10 (still a beta version), so here is a new EclCCE version supporting it.
25/04/2003 v1.4a - Added support for CCE 2.67.00.10 - Added ability to minimize CCE to the system tray during encoding |
25th April 2003, 11:37 | #93 | Link | |
Retired
Anyway, I'll start looking into it in the near future, can't promise anything yet, sorry. |
25th April 2003, 19:54 | #94 | Link |
Thanks, I understand. That dialog is a nightmare. I think you can ignore all the "Phase calculators" buttons though. And on the left, there is a duplicate set of 10 buttons that can be ignored (A:1 2 B:1 2 3 C:1 2 D:1 2 3) -- these do the same thing as the (1 2) / (1 2 3 4 5) buttons above them. (Or you could ignore the (1 2) and (1 2 3 4 5) buttons, but I'm guessing you'd rather ignore 10 buttons than 7 ).
I'll look for an ECL with 3:2 pulldown detection settings -- probably difficult to locate, though. In any case, great app. |
26th April 2003, 08:46 | #95 | Link |
Hi!
What a pitty. I tried your EclCCE to be able to load an ecl from a script. But its seems that wine does not like it . It starts correctly up cce (2.5) but does not load the ecl. I guess you wont mess with such things. Anyway the idea is great. Greets blixi |
2nd May 2003, 12:15 | #100 | Link |
Retired
EclCCE v1.4b with minor fixes is out.
02/05/2003 v1.4b - Fixed: Advanced VBR Settings dialog was visible during automated bitrate tweaking even though CCE was minimized to tray - Fixed: Shutdown feature didn't work when using bitrate tweaking |
