Old 1st May 2013, 15:16   #15041  |  Link
leeperry
Kid for Today
Is there a way you could please allow to choose between the WM9 DMO and libavcodec? ffdshow has the option but when I open a bunch of files in seamless playback mode with PotP, the latter will not switch between LAV/ffdshow(as LAV can also decode it) and I've got some videos that would appear to show glitches with the DMO and not libav(which also decodes in MT IIRC?)
Old 1st May 2013, 15:25   #15042  |  Link
DragonQ
You mean like this option?
http://www.aotplaza.com/Files/HTPC/L...Properties.png
Old 1st May 2013, 15:26   #15043  |  Link
paradoxical
Posts: n/a
There already is an option. Uncheck "Use Microsoft WMV9 DMO decoder" in the LAV video properties. It's been there for some time now.
Old 1st May 2013, 16:09   #15044  |  Link
DarkSpace
If dynamic ASS style switching worked, this would be possible - but this is not in my hands, its the subtitle filters which don't support this right now.
The xy-VSFilter dev expressed that he sees this as a useful feature to support. Possibility for the future.
Just for the record, I created an issue at the xy-VSFilter Issue Tracker for this.
Out of interest, are you still trying to re-send the relevant styles to the subtitle renderer on a Segment switch in addition to loading the whole Style block of the main Segment or is this behavior turned off?
DarkSpace is offline   Reply With Quote
Old 2nd May 2013, 08:04   #15045  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Hi nevcairiel
LAV splitter incorrect work with some .aob files (DVD-Audio).
http://aleksoid.voserver.net/Sample/MLP/ats_01_1.aob - incorrect duration detect.
http://aleksoid.voserver.net/Sample/...4100stereo.AOB - wrong track type detect, pcm_s16be instead of MLP.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 2nd May 2013, 08:06   #15046  |  Link
Aleksoid1978
if any have a MKV's with linked Segment and different subtitle style - upload please, i want do accept new style when Segment changes.
Old 2nd May 2013, 14:31   #15047  |  Link
THX-UltraII
Is it possible with LAV filters to move my subtitles when playing BDMV Blu-Ray structure? I tried the override placement setting in MPC-HC but it does not do anything.....
THX-UltraII is offline   Reply With Quote
Old 2nd May 2013, 14:46   #15048  |  Link
nevcairiel
Why would the source move your subtitles?
Old 3rd May 2013, 06:42   #15049  |  Link
AngelGraves13
I've got LAV set up perfect for watching my blu-ray remuxes.
Forced Subs + flags in the MKV and MPC BE. Arcsoft DTS-HD Decoder as well. Using the 32-bit build of MPC BE because Arcsoft DLL is only 32-bit.
It doesn't get any better than using LAV.
AngelGraves13 is offline   Reply With Quote
Old 3rd May 2013, 07:04   #15050  |  Link
QBhd
QB the Slayer
QBhd's Avatar
Agreed... Paired with madVR nothing is better! Mad props to nevcairiel and madshi!
QB
ps... I use PotPlayer with a super minimalist skin. I think it was Cruncher who created it... slick and clean.
QBhd is offline   Reply With Quote
Old 3rd May 2013, 22:44   #15051  |  Link
Soukyuu
Soukyuu's Avatar
Chapter jumping is wonky with the current LAV splitter. Many files end up not showing typesetting that are close to the chapter jump, even though the .ass lines make sense (i.e. chapter jump x:xx:xx.767, subtitle line x:xx:xx.80 - subtitle is not shown after jump). Switching to Haali splitter works fine.
Soukyuu is offline   Reply With Quote
Old 4th May 2013, 02:56   #15052  |  Link
nx6
Playing with MKV files...
nx6's Avatar
It these are the original subtitles from the BD they can't be moved because they are graphical in nature. The settings you're referring to in MPC-HC are for where plain text-based subs (usually SRT format) are placed on screen after being rendered by the player. Those settings have no effect on native subs from a DVD or BD, or styled text subs (SSA/ASS) because they include position information in their style info.
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8
nx6 is offline   Reply With Quote
Old 4th May 2013, 05:48   #15053  |  Link
dansrfe
Is there any possible way to shift the subtitle bitmap render coordinates in MPC-HC, however? Something that can be added perhaps? If so then I might as well add a feature request for it in the MPC-HC thread. I want to be sure that it isn't a dumb request though...
Old 4th May 2013, 07:30   #15054  |  Link
nevcairiel
I can't do anything without a sample demonstrating the problem.
This generally goes for any issue reports. The most important thing is to be able to reproduce the problem, only then there is a chance to fix it.
Old 4th May 2013, 09:34   #15055  |  Link
AngelGraves13
Would it be difficult to add Color Management (gamma correction) to LAV Video? Only EVR Custom supports Color Management in MPC and I prefer to watch movies with 16-235 with 2.2 gamma instead of plain old 0-255 with no gamma correction.
It looks better. I'd love for LAV Video to do this.
Old 4th May 2013, 09:36   #15056  |  Link
nevcairiel
Not going to happen. LAV Video is a decoder, not a color processor.
Old 4th May 2013, 11:00   #15057  |  Link
Aleksoid1978
Hello nevcairiel. You have to disable the opening of .IFO files by LAV Splitter. LAV can open .IFO - but not correctly.
Old 4th May 2013, 11:06   #15058  |  Link
nevcairiel
LAV cannot open IFO files at all, that would've been news to me. I tested just now, it refuses to open the file.
Old 4th May 2013, 13:26   #15059  |  Link
Aleksoid1978
But - sometimes still tries to open ... and open
Here screen-shot and .IFO file which opened by LAV Source.
http://aleksoid.voserver.net/Sample/LAV_IFO/
Old 4th May 2013, 13:50   #15060  |  Link
nevcairiel
Ah it misdetects them as AAC for some reason.
I added a check to block opening .ifo files completely.
