Old 23rd August 2023, 01:17   #25021  |  Link
ashlar42
There is a known issue with high-bitrate Atmos tracks that I haven't gotten around to addressing quite yet. Hopefully soon.
Thanks for your reply. Much appreciated.
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM
Old 23rd August 2023, 14:39   #25022  |  Link
ashlar42
Just to be sure that we are talking about the same issue:
My problem does not lead to any audio dropouts. Audio is perfect, it's just frames that are getting dropped or repeated in madVR.
Old 26th August 2023, 07:00   #25023  |  Link
htnut
When this issue is solved do you think it may solve the DirectSound bitstreaming audio dropouts w/ momentary video glitch that I reported on the JRiver forum?
htnut is offline   Reply With Quote
Old 26th August 2023, 08:18   #25024  |  Link
nevcairiel
No. Not every issue is related.
Old 26th August 2023, 16:23   #25025  |  Link
ashlar42
Hi! Could you let me know if the issue I reported is the one you mentioned as being likely solvable through LAV Filters? From your wording I am not sure I understood things correctly. Sorry...
I am experiencing dropped/repeated frames in madVR but no audio dropouts or anything. Audio remains perfect throughout playback.
Old 30th August 2023, 06:38   #25026  |  Link
pcamino
Hi all, new to the forum and new to this in general. I was curious as to if LAV filters are able to handle and decode 4ch audio video files within Windows and what is needed to playback those types of files if I have my audio card in windows set to "quadraphonic" I'm trying to replicate a video player like Playback pro, where if I put a Mac OS in quadraphonic. then it can actually read all 4channels of the video files and send them discretely to the quadraphonic outputs of my audio interface. I coudn't find any settings within the LAV filter GUI to make it work. Though i'm not sure if the player software may need some tweaking as well.
pcamino is offline   Reply With Quote
Old 30th August 2023, 13:04   #25027  |  Link
tebasuna51
tebasuna51's Avatar
Welcome to the Doom9 forum.
I was curious as to if LAV filters are able to handle and decode 4ch audio video files within Windows...
No problem, in Windows I can recommend you software players like MPC-HC or BE with LAV filters included. Also VLC can be used.
Old 30th August 2023, 19:17   #25028  |  Link
Balling
Samples?
Balling is offline   Reply With Quote
Old 30th August 2023, 23:16   #25029  |  Link
ashlar42
Originally Posted by Balling View Post
Samples?
The new Avatar remuxed, for instance. But it's not just that... even the old Avatar in UHD suffers from the same problem.
Old 31st August 2023, 22:16   #25030  |  Link
ashlar42
Just wanted to add that with mpc-be, using internal filters (hence not LAV), frames are not repeated/dropped with madVR. With the Atmos titles, I mean.
Old 1st September 2023, 16:56   #25031  |  Link
Balling
Can you give a file? I will test on my LG C9. Because all other genius players are hardly reference.
Old 1st September 2023, 22:06   #25032  |  Link
ashlar42
Not sure what copyright limitations allow me to do. If a small segment would be ok, how small, etc.
Old 1st September 2023, 22:11   #25033  |  Link
Balling
Small that allows to reproduce falls under the fair use.
Old 7th September 2023, 05:01   #25034  |  Link
pcamino
Thanks @tebasuna51, but wanted to build custom software to use as a player, just need to figure out code to be able to do the 4ch decode thing.
Old 7th September 2023, 10:27   #25035  |  Link
tebasuna51
tebasuna51's Avatar
... but wanted to build custom software to use as a player, just need to figure out code to be able to do the 4ch decode thing.
You can use the LAV filters, after solved some problems/bugs in past year, can decode and output correct multichannel audio with any kind of channel configuration.
Before that the LAV filters apply a default :
{4, SPEAKER_FRONT_LEFT|SPEAKER_FRONT_RIGHT|SPEAKER_FRONT_CENTER|SPEAKER_LOW_FREQUENCY},
always for 4 channels, now preserve the channel mask from the source and can output quadraphonic audio (FL,FR,SL,SR) to your player.
Old 7th September 2023, 11:41   #25036  |  Link
nevcairiel
I've applied a fix for this, give the latest test build a try from here:
https://files.1f0.de/lavf/nightly/LA...s-0.77.2-3.exe
Old 9th September 2023, 07:40   #25037  |  Link
htnut
Will the associated fix be included in a JRiver MC31 build?
Old 11th September 2023, 00:24   #25038  |  Link
ashlar42
Preliminary results seem good. Probably better than MPC-BE Audio filter that I was using "ad interim".
Avatar The Way of Water remux played for one and a half hour without drops/repeats. This is far, far better than before. I left the movie playing and after another 30 minutes or so I found 3 frames dropped (or repeated, I don't remember). In the next few days I will experiment some more to see whether that can be replicated or if it was a one-off glitch (I try to keep my HTPC Windows 10 install lean but it's not *completely* dedicated).
Refresh rate should not be the culprit, as that indicates frames dropped/repeated after a couple of days.
In any case this is a clear step forward, of this I'm sure. Thanks a lot.
I actually would like to know if there's a way in madVR to activate a log, in order to have a reference to when, during playback, frames have been dropped/repeated. I like Avatar but I can't watch it ten times...
Old 13th September 2023, 01:59   #25039  |  Link
debug tracks pretty much everything.
they are very hard to read and have an absolute insane size.
Old 19th September 2023, 07:46   #25040  |  Link
v0lt
@nevcairiel
Please update FFmpeg. The developers recently eliminated a very unpleasant noise when playing APE 24-bit files.
v0lt is offline   Reply With Quote
