29th September 2012, 15:19 | #261 | Link | |
契約者
want to add to JEEB's answer that swscale does poor ordered dithering... at least ffms2 supports only that. it was my request some time ago to add something better Last edited by Keiyakusha; 29th September 2012 at 15:24. |
29th September 2012, 15:27 | #263 | Link | |
Professional Code Monkey
29th September 2012, 16:52 | #264 | Link | |
how do I write it for the import path if my vpy file is on the desktop, and python was installed at "C:\Python32" ? ______________________________ And a few more things I spotted: - the uninstaller shortcut was missing in the start menu. - vapoursynth installer defaulted the python directory as python32. I updated python to 3.3 today and vapoursynth installer throws out an error - a context menu on creating a new blank vpy file should be added - there's a pop up sometime asking system reboot after i uninstalling vapoursynth And I did some benchmarking with x264 preset ultrafast comparing avisynth and vapoursynth. Code:
avs FFVideoSource("test.avi") 524fps x264 cpu usage: 100% vpy Source("test.avi") 285fps x264 cpu usage: ~50% python.exe cpu usage: 30% Last edited by lansing; 29th September 2012 at 17:57. Reason: typo |
29th September 2012, 16:58 | #266 | Link | |
2. The python module is built for 3.2 and will only work with that version. It's how annoying python on windows is. 3. I'll put it on the to-do list. Personally I never use those options so I don't notice it missing. 4. Of course. A file was in use and a reboot is needed to delete it. It's safe to just install over for upgrades though. Can you do the same benchmark but pipe the input to x264 and skip the vfw stuff? It'll help me find the bottleneck
29th September 2012, 18:14 | #268 | Link | |
vpy: Code:
import vapoursynth as vs import sys core = vs.Core(accept_lowercase=True) core.std.LoadPlugin(r'C:\Program Files (x86)\AviSynth 2.5\plugins\ffms2.dll') src = core.ffms2.Source(r"test.avi") src.output(sys.stdout, y4m=True) ___________________________________ cmd: python test.vpy | x264 --preset ultrafast --demuxer y4m --output vpy_ben.mkv - avs: Code:
ffvideosource("test.avi") ___________________________________ cmd: x264 --preset ultrafast --output avs_ben.mkv test.avs |
29th September 2012, 19:45 | #269 | Link | |
v210 is supported by almost every single software- from Vdub, through ffmpeg, Premiere, .... ending at high end grading tools and all preview cards- BM, AJA etc. It works for AVI the same as for MOV- one can be re-wrapped with no problem. Whole broadcast industry uses v210, so it's not something rare. As I said- it's the most supported 10bit format out there (except DPX, but this is an image sequence). Vdub is happy with v210- don't know about any problems with Vdub and v210 and I use it quite a lot. I know that it's not a easy format to work with (for processing), that's why I said it can exist only on final output stage. This, what I'm talking about is eg. fake AVI (like current avfs showing up as YUY2), which would have v210 format. This would make it working with 99% existing software- there is no other 10bit format with such a broad support. It's all about linking script to outside apps at higher than 8bit precision. Current avfs works very well, but only for 8bit. It's also about not have to render big v210 file, but use fake AVI as this is very useful solution. AVFS works very well and I hope there will be 10bit version of it. |
29th September 2012, 21:01 | #270 | Link |
ok i was able to solve my problem with the vd crashing from a kind forum member, it was caused by me setting the encoding of my vpy file to UTF-8, changing it back to ANSI solves it.
And since now I got the fake avi working, I will do some benchmarking with AVSMeter on pure avs and vpy in a avs wrapper, will report. |
30th September 2012, 02:21 | #271 | Link |
I still have crashes in Vdub upon opening this script :
import vapoursynth as vs import sys core = vs.Core(accept_lowercase=True) core.std.LoadPlugin(r'k:\programs\ffms2-r725-icl\ffms2.dll') ## src = core.ffms2.Source(r'k:\film\Battleship (2012) HDRip\Battleship.2012.mkv') ret = core.ffms2.Source(r"k:\film\Battleship (2012) HDRip\Battleship.2012.mkv") ## src.output(sys.stdout, y4m=True) last = ret What do I need to modify to open it in vdub/MPC-HC/AVISource ? Is there a FourCC specified for the VFW format ? Is this needed ? I've r10 installed (=checked using "print(c.version())") |
30th September 2012, 03:06 | #272 | Link |
phaeron from virtualdub confirm adding supports for vpy extension.
And i'm having small issue with argument having float value, like fft3dfilter(sigma=1.0) . I have to add a decimal in order for it to work, if i put "1" it will return invallid argument. |
30th September 2012, 06:52 | #273 | Link | |
契約者
Edit: What are the names of planar colorspaces for 4:4:4 8+bit material? I know only these: P016,P010,P216,P210, but this is only 420 and 422. Microsoft website mentions something like Y410, but they are packed? So Vapoursynth have no choice but support something more than planar colorspaces? Last edited by Keiyakusha; 30th September 2012 at 07:46. |
30th September 2012, 09:41 | #274 | Link | |
typo lover
EDIT: my miss understanding, deleted
They will be defined if Microsoft, other companies, or an person is needed. Since Microsoft had not used the YUV444-Planar format yet in MediaFoundation, it is not exists now.
my repositories Last edited by Chikuzen; 30th September 2012 at 09:59. |
30th September 2012, 10:50 | #275 | Link | |
契約者
Edit: i wanted to ask if it possible to open image sequences in VS, but from what I see in documentation just now:
I see. But is it something that can be defined in vapoursynth? Won't it be better to just implement packed variants that already exist? |
30th September 2012, 11:53 | #276 | Link | ||
typo lover
You can use avisynth's ImageSource vis that. Quote:
try as follows Code:
>>> import vapoursynth >>> print(help(vapoursynth))
my repositories Last edited by Chikuzen; 30th September 2012 at 11:55. |
30th September 2012, 12:37 | #277 | Link | |
契約者
Of course 8bit images is possible, but there is no reason for me to have 8bit sequences, there is nice lossless video formats. There is no good lossless formats for 8+ bitdepth though... At least not the ones that are free and supported by different software Last edited by Keiyakusha; 30th September 2012 at 12:40. |
30th September 2012, 12:54 | #278 | Link |
I've reproduced it. But I'm not quite sure why it happens. I also redid the comparison with avs2yuv (to add the piping overhead in both cases) and avisynth is then still 50% faster.
30th September 2012, 14:12 | #279 | Link |
Nice, I have VFW working with MPC & AVISource, but I get access violations with VirtualDUB v1.9.11.
I've tried the newer beta vdub v1.10.2, but got same problem. Any idea what could be wrong ? Thanks in advance ! crash report : Code:
VirtualDub crash report -- build 32842 (release) -------------------------------------- Disassembly: 00000000: 0000 add [eax], al <-- FAULT 00000002: 0000 add [eax], al 00000004: 0000 add [eax], al 00000006: 0000 add [eax], al 00000008: 0000 add [eax], al 0000000a: 0000 add [eax], al 0000000c: 0000 add [eax], al 0000000e: 0000 add [eax], al 00000010: 0000 add [eax], al 00000012: 0000 add [eax], al 00000014: 0000 add [eax], al 00000016: 0000 add [eax], al 00000018: 0000 add [eax], al 0000001a: 0000 add [eax], al 0000001c: 0000 add [eax], al 0000001e: 0000 add [eax], al 00000020: 0000 add [eax], al 00000022: 0000 add [eax], al 00000024: 0000 add [eax], al 00000026: 0000 add [eax], al 00000028: 0000 add [eax], al 0000002a: 0000 add [eax], al 0000002c: 0000 add [eax], al 0000002e: 0000 add [eax], al 00000030: 0000 add [eax], al 00000032: 0000 add [eax], al 00000034: 0000 add [eax], al 00000036: 0000 add [eax], al 00000038: 0000 add [eax], al 0000003a: 0000 add [eax], al 0000003c: 0000 add [eax], al 0000003e: 0000 add [eax], al 00000040: 0000 add [eax], al 00000042: 0000 add [eax], al 00000044: 0000 add [eax], al 00000046: 0000 add [eax], al 00000048: 0000 add [eax], al 0000004a: 0000 add [eax], al 0000004c: 0000 add [eax], al 0000004e: 0000 add [eax], al 00000050: 0000 add [eax], al 00000052: 0000 add [eax], al 00000054: 0000 add [eax], al 00000056: 0000 add [eax], al 00000058: 0000 add [eax], al 0000005a: 0000 add [eax], al 0000005c: 0000 add [eax], al 0000005e: 0000 add [eax], al 00000060: 0000 add [eax], al 00000062: 0000 add [eax], al 00000064: 0000 add [eax], al 00000066: 0000 add [eax], al 00000068: 0000 add [eax], al 0000006a: 0000 add [eax], al 0000006c: 0000 add [eax], al 0000006e: 0000 add [eax], al 00000070: 0000 add [eax], al 00000072: 0000 add [eax], al 00000074: 0000 add [eax], al 00000076: 0000 add [eax], al 00000078: 0000 add [eax], al 0000007a: 0000 add [eax], al 0000007c: 0000 add [eax], al 0000007e: 0000 add [eax], al 00000080: 0000 add [eax], al 00000082: 0000 add [eax], al 00000084: 0000 add [eax], al 00000086: 0000 add [eax], al 00000088: 0000 add [eax], al 0000008a: 0000 add [eax], al 0000008c: 0000 add [eax], al 0000008e: 0000 add [eax], al 00000090: 0000 add [eax], al 00000092: 0000 add [eax], al 00000094: 0000 add [eax], al 00000096: 0000 add [eax], al 00000098: 0000 add [eax], al 0000009a: 0000 add [eax], al 0000009c: 0000 add [eax], al 0000009e: 0000 add [eax], al 000000a0: 0000 add [eax], al 000000a2: 0000 add [eax], al 000000a4: 0000 add [eax], al 000000a6: 0000 add [eax], al 000000a8: 0000 add [eax], al 000000aa: 0000 add [eax], al 000000ac: 0000 add [eax], al 000000ae: 0000 add [eax], al 000000b0: 0000 add [eax], al 000000b2: 0000 add [eax], al 000000b4: 0000 add [eax], al 000000b6: 0000 add [eax], al 000000b8: 0000 add [eax], al 000000ba: 0000 add [eax], al 000000bc: 0000 add [eax], al 000000be: 0000 add [eax], al 000000c0: 0000 add [eax], al 000000c2: 0000 add [eax], al 000000c4: 0000 add [eax], al 000000c6: 0000 add [eax], al 000000c8: 0000 add [eax], al 000000ca: 0000 add [eax], al 000000cc: 0000 add [eax], al 000000ce: 0000 add [eax], al 000000d0: 0000 add [eax], al 000000d2: 0000 add [eax], al 000000d4: 0000 add [eax], al 000000d6: 0000 add [eax], al 000000d8: 0000 add [eax], al 000000da: 0000 add [eax], al 000000dc: 0000 add [eax], al 000000de: 0000 add [eax], al 000000e0: 0000 add [eax], al 000000e2: 0000 add [eax], al 000000e4: 0000 add [eax], al 000000e6: 0000 add [eax], al 000000e8: 0000 add [eax], al 000000ea: 0000 add [eax], al 000000ec: 0000 add [eax], al 000000ee: 0000 add [eax], al 000000f0: 0000 add [eax], al 000000f2: 0000 add [eax], al 000000f4: 0000 add [eax], al 000000f6: 0000 add [eax], al 000000f8: 0000 add [eax], al 000000fa: 0000 add [eax], al 000000fc: 0000 add [eax], al 000000fe: 0000 add [eax], al Built on Aegis on Fri Dec 24 13:18:44 2010 using compiler version 1400 Windows 6.1 (Windows Vista x64 build 7601) [Service Pack 1] EAX = 05e67f78 EBX = 0280fce8 ECX = 05e67f04 EDX = 05e67f78 EBP = 0018f67c ESI = 0280e898 EDI = 0280e89c ESP = 0018f61c EIP = 00000000 EFLAGS = 00210202 FPUCW = 027f FPUTW = ffff Crash reason: Access Violation Crash context: An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'... ...reading address 00000000. Pointer dumps: EAX 05e67f78: 705c3a4b 72676f72 5c736d61 68747970 765f6e6f 2e322e33 65745c33 2e317473 EBX 0280fce8: 005fab98 00000001 00000000 0280e880 0280e880 00000000 00000000 00000100 ECX 05e67f00: 00000002 05e67f78 00000000 00000000 00000000 00000023 0000002f 00000000 EDX 05e67f78: 705c3a4b 72676f72 5c736d61 68747970 765f6e6f 2e322e33 65745c33 2e317473 ESI 0280e898: 005fa240 05e67efc 05e67ef0 00000001 17ad34de 80000000 00000056 00000000 EDI 0280e898: 005fa240 05e67efc 05e67ef0 00000001 17ad34de 80000000 00000056 00000000 ESP 0018f618: 05e67f04 6bff1e18 05e67f78 05e67f20 0280e89c 0280e898 0280fce8 0280fce8 0018f638: 0018f694 0053000e 656853a3 6bff7188 0018fbb0 00000000 00000000 0050000f 0018f658: 656853a3 00000000 04d3e980 027b0358 759f9e62 0018f6c8 0018f6cc 6bff18a4 0018f678: 05e67ef0 0018f6d8 6bff1dac 0280e89c 0280e898 0280fce8 0018f624 0018f6fc EBP 0018f678: 05e67ef0 0018f6d8 6bff1dac 0280e89c 0280e898 0280fce8 0018f624 0018f6fc 0018f698: 0018f764 772471d5 0041f7e0 fffffffe 771fe38c 771fe0f2 00000010 00000000 0018f6b8: 771fe046 00730000 04d3e980 0018f72c 00000002 0018f728 6bff186a 05e67ef0 0018f6d8: 0018f72c 6bff2444 0280e89c 0280e898 0280fce8 0018f704 771fe023 028f8f00 Thread call stack: 6bff1e18: vsvfw!DllCanUnloadNow [6bff0000+14a0+978] 759f9e62: ole32!CoCreateInstanceEx [759b0000+49d4e+114] 6bff18a4: vsvfw!DllCanUnloadNow [6bff0000+14a0+404] 6bff1dac: vsvfw!DllCanUnloadNow [6bff0000+14a0+90c] 771fe38c: ntdll!RtlInitUnicodeString [771d0000+2e228+164] 771fe0f2: ntdll!RtlAllocateHeap [771d0000+2e046+ac] 6bff186a: vsvfw!DllCanUnloadNow [6bff0000+14a0+3ca] 6bff2444: vsvfw!DllCanUnloadNow [6bff0000+14a0+fa4] 771fe023: ntdll!RtlFreeHeap [771d0000+2dfa5+7e] 771fe023: ntdll!RtlFreeHeap [771d0000+2dfa5+7e] 005b2fb6: malloc() 004c74c4: AVIReadHandlerTunnelW32::AVIReadHandlerTunnelW32() 004c76ab: CreateAVIReadHandler() 004ce98b: InputFileAVI::Init() 772035a7: ntdll!RtlImageNtHeader [771d0000+33184+423] 7720389a: ntdll!RtlImageNtHeader [771d0000+33184+716] 75738443: USER32!GetClassLongW [75720000+183a8+9b] 772038be: ntdll!RtlImageNtHeader [771d0000+33184+73a] 7720389a: ntdll!RtlImageNtHeader [771d0000+33184+716] 7573d184: USER32!GetWindowLongA [75720000+1d156+2e] 7573d190: USER32!GetWindowLongA [75720000+1d156+3a] 7573d190: USER32!GetWindowLongA [75720000+1d156+3a] 77203492: ntdll!RtlImageNtHeader [771d0000+33184+30e] 7573d190: USER32!GetWindowLongA [75720000+1d156+3a] 7575f962: USER32!GetCursor [75720000+3f6e0+282] 7720389a: ntdll!RtlImageNtHeader [771d0000+33184+716] 77203492: ntdll!RtlImageNtHeader [771d0000+33184+30e] 7573717a: USER32!IsWindow [75720000+17136+44] 7573692a: USER32!gapfnScSendMessage [75720000+15fc8+962] 75737290: USER32!GetPropW [75720000+17227+69] 75737276: USER32!GetPropW [75720000+17227+4f] 75737257: USER32!GetPropW [75720000+17227+30] 75738e0d: USER32!RemovePropW [75720000+18dbd+50] 75738de4: USER32!RemovePropW [75720000+18dbd+27] 6e6876a5: uxtheme!GetThemeBool [6e670000+16651+1054] 6e687650: uxtheme!GetThemeBool [6e670000+16651+fff] 757362fa: USER32!gapfnScSendMessage [75720000+15fc8+332] 75736d91: USER32!GetThreadDesktop [75720000+16c63+12e] 75736d51: USER32!GetThreadDesktop [75720000+16c63+ee] 75736ce9: USER32!GetThreadDesktop [75720000+16c63+86] 75736d91: USER32!GetThreadDesktop [75720000+16c63+12e] 75736d51: USER32!GetThreadDesktop [75720000+16c63+ee] 75736de8: USER32!GetThreadDesktop [75720000+16c63+185] 75736df3: USER32!GetThreadDesktop [75720000+16c63+190] 75736df3: USER32!GetThreadDesktop [75720000+16c63+190] 75739a21: USER32!FindWindowW [75720000+198fd+124] 771ef8ca: ntdll!NtCallbackReturn [771d0000+1f8b8+12] 75739a49: USER32!FindWindowW [75720000+198fd+14c] 771e010a: ntdll!KiUserCallbackDispatcher [771d0000+100dc+2e] 7573692a: USER32!gapfnScSendMessage [75720000+15fc8+962] 7575cdb3: USER32!DialogBoxIndirectParamW [75720000+3cbf3+1c0] 7575cf5c: USER32!DialogBoxIndirectParamAorW [75720000+3ce54+108] 7577cb58: USER32!DialogBoxParamA [75720000+5cb0c+4c] 004cc7d9: InputFileAVI::promptForOptions() 00464e4e: VDProject::Open() 0051d29e: VDAutoLogger::VDAutoLogger() 00453e5c: OpenAVI() 0046c491: VDProjectUI::MenuHit() 75736b00: USER32!gapfnScSendMessage [75720000+15fc8+b38] 004794a0: VDUIFrame::DefProc() 0046da41: _catch$?MainWndProc@VDProjectUI@@IAEJIIJ@Z$0() 00465ac0: VDProjectUI::WndProc() 00479b65: VDUIFrame::StaticWndProc() 757362fa: USER32!gapfnScSendMessage [75720000+15fc8+332] 75736d3a: USER32!GetThreadDesktop [75720000+16c63+d7] 75736ce9: USER32!GetThreadDesktop [75720000+16c63+86] 771e010a: ntdll!KiUserCallbackDispatcher [771d0000+100dc+2e] 757377c4: USER32!CharPrevW [75720000+1768c+138] 757460dc: USER32!PeekMessageA [75720000+25f74+168] 75737bca: USER32!DispatchMessageA [75720000+17bbb+f] 00452596: WinMain@16() 005b78db: __tmainCRTStartup() 74b4339a: kernel32!BaseThreadInitThunk [74b30000+13388+12] 77209ef2: ntdll!RtlInitializeExceptionChain [771d0000+39e8f+63] 77209ec5: ntdll!RtlInitializeExceptionChain [771d0000+39e8f+36] -- End of report |
30th September 2012, 14:18 | #280 | Link | |
typo lover
avisynth has ISSE optimized one, but ffms2 for VS has only pure C++ code.
my repositories |
speed, vaporware, vapoursynth |
