#201 | Link |
only minor changes so far, no changelog yet
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English |
#203 | Link |
right, the beta file is automatically synced to Google Drive as soon as I make any changes.
#204 | Link |
I've got a setup of Shield 2019 through to LG TV utilising a Plex server and it can happily play native DV rips (Dune) and standard UHD rips (Sicario) from MKV
no issue. When I have ran Sicario through the script (3-1) the film does trigger DV on the TV but there are blocky aspects when it comes to dark colours on light background and a few frames that are obviously awry. Just wondered if I am doing something wrong in prepping the scripts, or do I need to invest in a Nvidia GFX card or a SSD to carry out the conversion work? Thanks |
#205 | Link | |
Posts: n/a
What are the spec's of your PC ?? Which .bat are you using, .mp4 or .mkv version ?? Is the original video good, without these blocky aspects, etc ?? As you haven't got an nVidia GPU, you can't be using NVENC, so that's not an issue. There are a lot of "behind the scenes" settings, but default should be fine. An SSD or Nvme would only speed up certain parts of the process. |
#206 | Link | |
Also, it might be a cmv4.0 vs cm2.9 thing, on my 2023 Hisense TV, cmv4.0 looks wrong/bad. So you could try to remove cmv4.0 with 2-1-5 and if it is the source of the problem, you can configure the script to always remove it at line 101
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English Last edited by Kuler087; 16th March 2024 at 13:31. |
#208 | Link |
Choose the largest AR but your min and avg pq metadata won't be 100% accurate.
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English Last edited by Kuler087; 16th March 2024 at 23:16. |
#210 | Link |
png/tiff input is just for when you want to check a specific frame.
If you want more frames, input a video file and the script will output as many frames as you have configured at line 125 (set frame_number=50)
#212 | Link |
Cropping BL
I often crop my encodes. Sometimes the original video will have L5 values that are odd, e.g. 0,0,143,143. Can cropping the BL to 0,0,144,144 negatively affect the DV presentation?
If so, would it be better to crop to one row less than the original L5 values, 0,0,142,142 then edit the L5 to 0,0,1,1? Last edited by Gatorman3385; 19th March 2024 at 07:57. |
#213 | Link | ||
#214 | Link |
Posts: n/a
Multi tasking & multiple GPU's..
I've been wanting to ask you if certain workflows are, or could be multi threaded ?
Also, would some workflows benefit from having multiple nVidia GPU's ? With all the video's you post on Youtube, you must be processing a lot of stuff, a lot of the time. Which leads me to also ask, I'd be interested in what spec's your PC(s) (or Mac's) are. ? I've currently got a 7950X & a 13900KF, pretty much the top of the line "normal" desktop CPU's But I haven't got any hi end 4000 series nVidia GPU's, hence the question about multi cards. You can never have enough processing power & "speed"
#215 | Link |
You can run more than 1 workflow at the same time. I do it all the time.
My PC is similar to yours. I have an i9 13900ks + RTX3070 + 32gb ram. What allows me to do all the screenshot comparisons and dv plots so quickly is the very fast nvme pci-4 drives I have. I even have one dedicated to my temp folder so any remuxing/demuxing is crazy fast (1-2gb/s)
DoVi_Scripts //// Dolby Vision Stuff (more tabs below) LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E Sorry for my English Last edited by Kuler087; 20th March 2024 at 12:23. |
#216 | Link | |||
Posts: n/a
, but I have to ask, if you're "feeding" 2 or 3 jobs into the same temp folder, is there going to be any naming conflicts ?Quote:
So, you didn't mention if the workflows might benefit from multiple GPU's ? Thanks. |
#217 | Link | ||
#218 | Link | ||
Posts: n/a
I just thought of something, if you had multiple dovi_script folders that have all the tools in them, but you sent them to different temp folders, you might be able to do multiples of the same workflow then... Quote:
#219 | Link | |
#220 | Link |
Only the L2 L8 L5 L6 plotter does that so as long as you don't run two instances of 6-4 or 6-5, it will be fine.
This is something I want to revisit though. This is also the reason why these workflows are disabled when your output path is on a C:\ drive.
| Tags |
| batch scripts, dolby vision processing, dovi_scripts |
| Display Modes | |
