#1901 | Link | |
Big Bit Savings Now !
SetTitleMatchMode, 2 #IfWinActive IrfanView Thumbnails SetKeyDelay, 0, 0 Down:: Send {Down} Send {Alt} Send o Send u return Up:: Send {Up} Send {Alt} Send o Send u return
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 26th December 2024 at 11:44. |
#1902 | Link |
Location: Mansfield, Ohio (formerly, Silicon Valley in California)
You are a prince! I don't mean to disappoint you, but I don't need it now. You see, in the trial of my custom Edit profile (https://forum.doom9.org/showthread.p...93#post2012093), I had to run Beautify about 700 times. But now that I've gained confidence in my custom Edit profile I'm only running Beautify twice, at the beginning and at the end of a session, I don't need a hot key for something I only run twice. Thank you, though. You are a prince.
#1903 | Link |
suggestion for simultaneously moving both cues
This would be a real time saver. Instead of moving sub1's out-cue and then sub2's in-cue, move them both, simultaneously.
Click sub1's out-cue and drag it to the right and it will eventually hit sub2's in-cue. When it does, drag them both! Click sub2's in-cue and drag it to the left and it will eventually hit sub1's out-cue. When it does, drag them both! Reversing direction during the drag drops the 'carried' cue where it is, but continues to drag the clicked cue, but in the new direction. That opens a gap between them. |
#1904 | Link |
[_<_Previous_] [_Play_current_] and [_Next_>_] play about 100ms past their actual out-cues. That's unwanted behavior. Is there a way to stop it? I couldn't find a setting.
#1905 | Link |
# signifies what appears to be a hex digit.
################-1.wav is a particular SE waveform file. SE _does_not_ reload it, so the prior waveforms _do_not_ appear. If I rename it to ################-0.wav, SE _does_ reload it, so the prior waveforms _do_ appear. This appears to be yet another off-by-one problem. I'm running SE 4.0.8 because I had too many problems with 4.0.9. Last edited by markfilipak; 28th December 2024 at 03:24. |
#1906 | Link |
Nikse, If you're going to grant focus to the List area on mouse-over, I suggest you remove its focus on mouse-out. When I try to delete a searched item in the Text box, SE wants to delete the current List subtitle, instead.
Currently (4.0.8) both show focus (by highlighted text), but only the List actually has the focus, not the Text box, which is where the mouse cursor is. Last edited by markfilipak; 28th December 2024 at 07:11. |
#1907 | Link |
The suffix -0, -1, -2... is the audio track index.
https://forum.doom9.org/showthread.php?t=185943 (I have extended that post for the legacy case of non-suffixed waveforms) If there is only one track (the first one), one should give index -0, pointing to -1 under these circumstances would be invalid. My findings: The older than January 2023 files in my \Waveforms folder have no track index appended. Within January 2023 I have both, track index and none; and the later ones have track index appended. (Since I work from different SE versions and merge results there is no sharp border found) Conclusion: SE versions before ~January 2023 seem to work on the first found audio stream, so do not append/respect any track index. The later SE versions which can load more than one audio track would need to append/respect that track index.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 28th December 2024 at 13:26. |
#1908 | Link |
Track 0 was Dolby Digital stereo. Track 1 was DTS-HDMA 7.1, FC channel. This was yesterday, not 2023. I suggest that Nikse save the wav as ################.wav and rely on the user remembering which index he/she extracted. Actually, the index is not important. Don't be anal compulsive. Last edited by markfilipak; 28th December 2024 at 16:01. |
#1910 | Link |
This has happened twice today. The MPV panel shows play-pause as paused and ready to play, while at the same time, the waveform panel shows play-pause as playing and ready to pause. The video will not play, no matter what I click. This appears to happen if I generate wavs _before_ beutification.
From experience, I do know that generating wavs _after_ beutification often malfunctions: The first attempt to generate wavs closes with no action.-- it has to be done a second time. Last edited by markfilipak; 29th December 2024 at 03:50. |
#1911 | Link |
focus problem
Operating these controls:
[_<_Previous_] [_Play_current_] [_Next_>_] What should happen: video play resumes What does happen: the current subtitle text is replaced by a space. These settings: Code:
[x] Set focus on mouse enter [x] Also set list view focus on mouse enter in list view Workaround: click on the wav before pressing [_space_]. Verions 4.0.8. Last edited by markfilipak; 5th January 2025 at 22:17. |
#1912 | Link |
Suggestion for easier control
I have a suggestion how to speed up these controls.
[_<_Previous_] [_Play_current_] [_Next_>_] [____Pause_____] 1 - Change [_Play_current_] to [_Play_/_Pause_] While playing, [_Play_/_Pause_] immediately pauses. While paused, [_Play_/_Pause_] re-initializes repeat, but resumes playing at the point it left off. When the end of the text is reached, it automatically resumes with the next repeat, if any. Code:
2 - Remove [____Pause_____] That way, I could watch the Waveform and pause at a particular point without having to move my mouse to hit the lower button -- I'm not very good at that. Bonus: It would be great if I could 'split' exactly at that pause-point. |
#1913 | Link |
Rebind keys to waveform
Alt+V : Jumps the waveform to the previous subtitle and runs it.
Alt+N : Jumps the waveform to the next subtitle and runs it. They are not listed in 'Settings', 'Shortcuts'. Can I change Alt+v to Control+Left? Can I change Alt+N to Control+Right? How? Thanks! |
#1914 | Link |
Beautifier has corrupted subtitle end time
Before beautification: 00:40:11.242..00:40:12.744 <-- CORRECT
After beautification: 00:40:11.242..00:40:11.326 <-- CORRUPT All three times are on frames. The preceding out-cue is at 00:40:09.240. The next in-cue is at 00:40:13.411 I have no idea how to proceed investigating the cause. I need help with that. --Mark. Notation: File is '3-61 A Matter of Perspective.srt', which will be retained for future inspection. The fault is hard -- it survives restarting SE. ==EDIT== To detect the corrupted subtitle, run "Apply duration limits" with these settings [note]: [X] Min. duration, milliseconds [__100_] [_] Max. duration, milliseconds [_8000_] The result: Code:
Apply Line# Before After [X] 637 40:11,242 --> 40:11,326 - 0,083 40:11,242 --> 40:11,342 - 0,100 [note] My beautify settings set gaps to 2 frames (i.e., 83 milliseconds). Different beautify settings may result in different bad durations -- I have not tested to see whether that's true. ==AFTER NOTE== In about 100 videos, I found 3 or 4 that had similarly corrupted end out-cues. In all of them, beautify had set the out-cues to the in-cues so that the subtitles had zero duration. Last edited by markfilipak; 26th January 2025 at 20:23. |
#1915 | Link |
Banana User
Report that at GitHub, with the files to reproduce the issues.
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling |
#1916 | Link |
Thank you,
Report which? My latest posting? The facts: What I posted is the only difference in the SRTs. And, any further analysis is not possible without the video source. The video source is 2.7 GB. Plus, the source is copyrighted and cannot legally be distributed. Perhaps there is a private way to handle this fault, eh? |
#1917 | Link |
New update, 4.0.11 broke spacebar playing video for anyone else?
I changed play/pause in settings as well from Control+P to space only, and it is still broken for me. I tried uninstalling, reinstalling. Didn't work. Uninstalled, restarted, reinstalled, restarted, still broken. Uninstalled, then reinstalled 4.0.10 and can confirm it works on that version. For now, 11 is broken it seems like. Last edited by Yosho; 31st January 2025 at 01:13. |
#1918 | Link |
UPDATE
I previously reported that the beautifier is driving some durations to zero. It's more complicated than that. The beautifier is deducting exactly 2 seconds from the durations of random subtitles -- at least, the victims seem random. If the duration is less than 2 seconds, the result is zero duration. Only end times (out-cues) are affected. Start times (in-cues) are not affected. I have no more information at this time. |
#1919 | Link |
Banana User
