#30882 | Link |
Starfish
Here is the MediaInfo
General ID : 0 (0x0) Complete name : E:\BDMV\STREAM\00001.m2ts CompleteName_Last : E:\BDMV\STREAM\00025.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 24.0 GiB Duration : 2 min 55 s Overall bit rate mode : Variable Overall bit rate : 1 175 Mb/s Maximum Overall bit rate : 109 Mb/s Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 2 min 54 s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 60.000 FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 7386 cd/m2 Maximum Frame-Average Light Level : 493 cd/m2 Video #2 ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 2 min 54 s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 60.000 FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : MLP FBA AC-3 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Muxing mode : Stream extension Codec ID : 131 Duration : 2 min 54 s Bit rate mode : Variable Bit rate : 640 kb/s Maximum bit rate : 7 563 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossless Stream size : 13.3 MiB (0%) Service kind : Complete Main Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Format profile : Blu-ray Disc Format settings : Dolby Surround EX Muxing mode : Stream extension Codec ID : 132 Duration : 2 min 54 s Bit rate mode : Constant Bit rate : 1 664 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 34.7 MiB (0%) Service kind : Complete Main Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 2 min 54 s Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 13.3 MiB (0%) Service kind : Complete Main |
#30884 | Link | |
![]() Join Date: Oct 2001
jdobbs.softworks@gmail.com Last edited by jdobbs; 14th September 2021 at 15:48. |
#30885 | Link | |
#30886 | Link | |
Starfish
#30887 | Link |
Starfish
Yes, Gemini Man has 60fps
https://www.blu-ray.com/movies/Gemin...lu-ray/252674/ Billy Lynn's Long Halftime Walk has 60fps, too. https://www.blu-ray.com/movies/Billy...lu-ray/166477/ |
#30888 | Link | |
Life's clearer in 4K UHD
![]() If anyone is interested there is/was a brief discussion (very brief) about HFR movies over on the Blu-ray Forum. Out of interest... Did anybody here have a AVCHD 2.0 camcorder that could capture 1920x1080p50/60 AVC video? Cheers
#30889 | Link | |
They play fine in my Panasonic player. Guess there is no need to adjust anything |
#30890 | Link | |
Big Bit Savings Now !
besides a few attempts at 4K@25p in .mov. The GH5 Micro 4/3 sensor isn't really worth 4K, but its HFR is very nice to have. Most projects of mine end up as Blu-ray 1280x720x50p. The result after stabilizing/framing fits the camera sensor capabilities well and is buttersmooth.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 15th September 2021 at 23:39. |
#30891 | Link | |
#30892 | Link | |
Like I said, I've added it to my to-do list. But it isn't a high priority.
jdobbs.softworks@gmail.com Last edited by jdobbs; 17th September 2021 at 13:44. |
#30893 | Link | |
#30894 | Link | |
Starfish
My post was just informational. If you decide it is too much work and you won't support it, I respect that. |
#30895 | Link | |
[09.15.21] BD Rebuilder v0.61.22 [10:58:45] Source: GEMINI_MAN - Input BD size: 86,10 GB - Approximate total content: [02:17:58.350] - Target BD size: 47,36 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), CQM - UHD-BD source detected. - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [10:58:47] PHASE ONE, Encoding - [10:58:47] Processing: VID_00000 (1 of 3) - [10:58:47] Extracting A/V streams [VID_00000] - [10:58:53] Reencoding video [VID_00000] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 528 frames - [10:58:53] Performing CQM Prediction... - Analyzing 17,25 21,70 23,30 23,70 [23,75] - [10:59:16] Encoding using constant quality mode. - [10:59:26] Video Encode complete - [10:59:26] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:59:26] Multiplexing M2TS - [10:59:30] Processing: VID_00003 (2 of 3) - [10:59:30] Extracting A/V streams [VID_00003] - [11:13:47] Reencoding video [VID_00003] - Source Video: HEVC, 3840x2160 - Rate/Length: 59,940fps, 420.962 frames - [11:13:47] Performing CQM Prediction... - Analyzing 1,00 18,20 19,70 21,00 22,30 23,40 24,30 25,05 25,60 25,95 26,15 [26,20] - [11:23:54] Encoding using constant quality mode. - [12:42:45] Video Encode complete - [12:42:45] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4354 (deu): Keeping original audio - [12:42:45] Multiplexing M2TS - [12:45:07] Processing: VID_00579 (3 of 3) - [12:45:07] Extracting A/V streams [VID_00579] - [12:45:26] Reencoding video [VID_00579] - Source Video: HEVC, 3840x2160 - Rate/Length: 59,940fps, 10.940 frames - [12:45:27] Performing CQM Prediction... - Analyzing 1,00 [8,15] - [12:45:33] Encoding using constant quality mode. - Performing size-correcting second pass... - [12:49:36] Video Encode complete - [12:49:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:49:37] Multiplexing M2TS [12:49:42]PHASE ONE complete [12:49:42]PHASE TWO - Rebuild Started - [12:49:42] Rebuilding BD file Structure [12:50:10] - Encode and Rebuild complete [12:50:10] Writing BD structure to ISO file - ImgBurn completed successfully - GEMINI_MAN folder removed. [12:53:36] JOB: GEMINI_MAN finished. I'd love to see more movies in HFR ... on a big screen with 4K thats just a stunning experience. |
#30896 | Link |
Yes, but is it HFR with DV? From what I saw it wasn't. The demo disc has a separate DV video file. I think that is the issue. I have run into an issue with a normal frame rate movie that has a separate DV video file and it failed.
| Thread Tools | |
| Display Modes | |
