Old 4th March 2023, 20:19   #1  |  Link
avinewbie
Multiple trims not working
Hi folks
I am not able to get trim to work on multiple clips.
using AVPMod V 2.6.7.0
using AVSplus V 2.7.2 64 bit
script tried for testing:
video=FFVideoSource()
Trim(video, 18133,27421)ColorYUV(gain_y=74, gamma_y=90, off_y=-9).tweak(sat=10)
b=trim(video, 33478,42974) ColorYUV(gain_y=90, gamma_y=90, off_y=64).tweak(sat=9.00)
c=trim(video, 61235,74272) ColorYUV(gain_y=74, gamma_y=90, off_y=-9).tweak(sat=9)
return(last++b++c)
ISSUES:
1)
I cannot label the first trim as a=Trim(video, 18133,27421)ColorYUV(gain_y=74, gamma_y=90, off_y=-9).tweak(sat=10)
I get an error:invalid arg to function colour YUV. removing "a= " works
so how do some post get a+b+c to work? here only Last+b+c works
BUT
2)
Filtering is only working on the first script when i scroll thru the Last++b++c video in preview on AVSPMod.
Runing each script individually makes the filtering work but when joined, only the first video is filtered.
Any guidance appreciated
avinewbie
avinewbie is offline   Reply With Quote
Old 5th March 2023, 09:16   #2  |  Link
Selur
Selur's Avatar
Looks like you are missing dots,..
a=Trim(video, 18133,27421).ColorYUV(gain_y=74, gamma_y=90, off_y=-9).tweak(sat=10)
b=trim(video, 33478,42974).ColorYUV(gain_y=90, gamma_y=90, off_y=64).tweak(sat=9.00)
c=trim(video, 61235,74272).ColorYUV(gain_y=74, gamma_y=90, off_y=-9).tweak(sat=9)
return a++b++c
Old 5th March 2023, 09:50   #3  |  Link
avinewbie
[QUOTE=Selur;1983980]Looks like you are missing dots,..
Hi Selur,
YEESS! that was it.
Thank you so much. I had spent all yesterday to find a solution.I suspected such a stupid error but could not see it.
Thank you for this (and for all your help in the forum)
