Old 8th June 2022, 21:09   #1  |  Link
avinewbie
KNLmeansCL -sytem acess violation error
Hi
If other newbies are getting a "system acess violation error" on trying to install and run KNLmeansCL with older GPU( mine Geforce9800GT),
The solution is to follow the brilliant tip posted by Fiesty:
"after the driver reinstallation, copy Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll to SysWOW64 folder and rename Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll to OpenCL.dll and copy it to System32"
Prior to finding fiesty's post I had tried the usual
1) use older version KNLmeans
2)Install older NVIDIA driver
3)check the visual studio install--2013
But nothing worked till I followed Fiesty's instructions. I had received similar errors in past for 32bit vs 64 bit mistakes but never thought the NVIDIA install would not put the DLL in the right places!
Hope this helps
avinewbie is offline   Reply With Quote
Old 18th August 2022, 03:52   #2  |  Link
pmccullough
Real.Finder Zs RF Shared.avsi, which you probably need If not already modified, https://github.com/realfinder/AVS-St...Functions.avsi and possibly smdegrain.avsi as well. Additionally, pretty much every Real.finder script needed for the most recent QTGMC was updated.
pmccullough is offline   Reply With Quote
Old 17th September 2022, 05:23   #3  |  Link
Mac4353
thanks @Avinewbie, It will help me a lot.
Mac4353 is offline   Reply With Quote
