Old 22nd February 2023, 16:20   #281  |  Link
rgr
Why am I getting this error?
Both clips should have the same colorspace!
(C:/Program Files (x86)lAviSynth+/plugins64+/TemporalDegrain-v2.6.4.avsi, line 441)
(C:/Program Files (x86)lAviSynth+/plugins64+/TemporalDegrain-v2.6.4.avsi, line 395)
Source: MPEG2, 720x576, YUV420
Full script:
video_org=FFmpegSource2("../00000.m2ts", atrack=-1)
	crop_left=12	# | rimozione esatta delle bande nere sinistra, sopra, destra e del disturbo sotto
	crop_top=2	# | 720-(12+16)x576-(2+14)=692x560
	crop_right=16
	crop_bottom=14
video_org_crop=video_org.crop(crop_left,crop_top,-crop_right,-crop_bottom)
video_org_crop_adj=video_org_crop.ColorYUV(off_u=+12, off_v=-6)
### de-interlacing
deinterlaced=video_org_crop_adj.AssumeTFF().QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, tr1=2, tr2=1, NoiseTR=2, sharpness=0.1)
### convert to YV16
deinterlaced_yv16=deinterlaced.convertToYV16()
### denoising
denoised_yv16=deinterlaced_yv16.TemporalDegrain2(degrainTR=3)
### convert to YUY2
denoised=denoised_yv16.convertToYUY2()
### convert to YV12
denoised_yv12=denoised.convertToYV12()
### sharpening
sharpened_yv12=denoised_yv12.LSFmod(defaults="slow")
### convert to YUY2 with chroma from YUY2 color space
sharpened=sharpened_yv12.convertToYUY2().MergeChroma(denoised)
### add borders
video_restored=sharpened.addborders((crop_left+crop_right)/2,(crop_top+crop_bottom)/2,(crop_left+crop_right)/2,(crop_top+crop_bottom)/2)
return(video_restored)
rgr is offline   Reply With Quote
Old 22nd February 2023, 17:11   #282  |  Link
rgr
Originally Posted by ErazorTT View Post
Feb 11, 2023: v2.6.4
- always undot before postFFT stage, increasing FFT efficiency by quite a bit when degrain was disabled
- mention suggested settings inside the script file
In the new version I get this error:
Rolling back to 2.6.3 solves the problem.
Old 24th February 2023, 19:24   #283  |  Link
ErazorTT
Yes, I just updated the file. Should be fixed now.
ErazorTT is offline   Reply With Quote
Old 25th February 2023, 21:22   #284  |  Link
ErazorTT
I found that there is a wierd inconsistent chroma shift for 420 sources. It can be upto half a pixel. Which means that when resized onto the luma, it will be twice of that.
From my investigation I found that it comes from mvtools MDegrain. I reported it here, you can take a look of the magnitue of the deviation there.
I thus decided to go back to a single degrain step for the chroma. I think this is the best compromise in total.
This halfs the shift introduced by mvtools, which I think is good enough. And it gives quite some speed increase, at the expense of a slightly less clean chroma.
For the paranoid among us, a complete the circumvention of the chroma shift bug can be enabled by the flag "degrainAvoidChromaShift", but that is relatively expense at 10% performance cost.
Also, if it is really necessary to clean the chroma more, which should be rather rarely, both degrains steps can be enabled for the chroma by the flag "degrainChromaTwoStep". This will however also enable the relatively expensive circumvention of the bug.
Old 3rd March 2023, 01:58   #285  |  Link
karthauzi
thanks for v2.6.6! Can it ported in G41fun.py Vapoursynth? Its actually v2.6.3
I have abolutely no Idea how to do this, even with googling, maybe i only need to adjust some lines? they are very different AVS and VS codelines.
Can you have a look into my G41Fun.rar to show us how to adjust it, so i can use v2.6.6?
Im using Staxrip and i already just Copy & Pasted the entire TemporalDegrain2 code from another G41fun.py into this one and replaced it from an old v2.4.3?. Improvising
https://drive.google.com/file/d/1uPa...ew?usp=sharing
Greetings
karthauzi is offline   Reply With Quote
Old 14th March 2023, 00:01   #286  |  Link
Mounir
I'm Trying the filter for the first time, i get an error (for a change) (tried v2.6.2 and v2.6.3 aswell)
avisource
convertoyv12()
TemporalDegrain2("CUDA"=false)
script error expected a , or )
Mounir is offline   Reply With Quote
Old 14th March 2023, 00:09   #287  |  Link
poisondeathray
avisource
convertoyv12()
CUDA=false , no ""
TemporalDegrain2(CUDA=false)
Old 14th March 2023, 03:29   #288  |  Link
kedautinh12
Cuda parameter only use with postFFT=5. You can use without postFFT=5 but that parameter no meaning when don't set postFFT=5
Old 25th September 2023, 02:34   #289  |  Link
Drommer
Hi. Is there any solution to the problem of color loss and artifacts when switching scenes? I saw in the manual about DCT, but it doesn't help and sometimes makes it worse.
I really like this filter. I have already found the optimal settings and transcode a few videos. Very reluctant to try anything else.
Drommer is offline   Reply With Quote
Old 25th September 2023, 05:06   #290  |  Link
kedautinh12
Originally Posted by Drommer View Post
Hi. Is there any solution to the problem of color loss and artifacts when switching scenes? I saw it in the manual about DCT, but it doesn't help and sometimes makes it worse.
I really like this filter. I have already found the optimal settings and transcribed a few videos. Very reluctant to try anything else.
I think it's related to banding colors after denoising, I think you can try parameter postFFT=3 or 4 or 5 to avoid banding. If banding continues after use 3, 4, and 5, you can try debanding with neo_f3kdb or gradfun3plus with 16bit
Example:
* Denoiser scripts
ConvertBits(16)
GradFun3plus(thr=0.25, radius=10, mask=2, smode=0,UV=1)
Old 25th September 2023, 13:29   #291  |  Link
Drommer
No, it's not about banding. This problem was discussed two pages ago. The last frame of the previous scene and the first frame of the next scene have distorted colors and spots. In this case (screenshots below) both processed frames go to cold tones, the second frame also has a small pink spot right of the door that gets bigger as the grainLevel increases.
https://imgsli.com/MjA5MTQx
https://imgsli.com/MjA5MTQy
P.S. My line: grainLevel=0, meBlksz=4, postFFT=4. I have also tried postFFT=0 and other options, but it has no effect.
Old 26th September 2023, 01:52   #292  |  Link
Drommer
Just in case, I checked the script version - everything is fine, 2.6.6. I also update all other components the script might depend on.
I went back to the discussion on the previous pages and noticed a post where the problem was solved by changing the values of ppSCD1 and thSCD2. This works, but I had to reduce the values to ppSCD1=2 and thSCD2=80. I think such an extremely low value would lead to false positives within the same scene. Am I the first to experience this problem after the fixes in version 2.3.3?
UPD 27/09. I did some more tests. I tried using the SceneCutSelectClip function, which (as I understand it) uses the same mechanism of searching and comparing frames. With default settings (thSCD1=400, thSCD2=130) scene change detection works correctly.
Old 27th September 2023, 01:30   #293  |  Link
Drommer
I found a bug when using postFFT=4 (KNLMeansCL). The devId variable is ignored because it is not specified in the function call. It is necessary to fix line 513 as follows:
output = KNLMeansCL(temp, a=a, d=d, h=strength, device_id=device_id, channels=channels)
