#401 | Link |
I don't remember in which post I lost track on what you're saying
![]() ![]() ![]() I Just hope someday, someone (crl2007 ??? ) makes a guide with all the great things BDEdit is able to do... For example, crl2007's menu editing guide has been really helpfull to understand 2 or 3 things you've been talking about ![]() Pelican9 for this great program and to anybody else that is helping in the development of it
#403 | Link |
The replace current object and palette aren't ticking. I can't tick those boxes. They become active after pressing the load button. But then I end up with an extra unwanted object.
Feature request: Copy button commands and paste them to another one. LE: In Playlist, when editing IN/OUT Times, after inserting a value, the program immediately asks if I want to update. So if instead of 11.650 I want to put 10:00.000, I have to edit 3 times. Once for minutes, once for seconds and once for ms. Imo it should update on pressing Enter, so one can insert the whole time value. Last edited by crl2007; 14th April 2010 at 19:06. |
#404 | Link | |||
Coder
Fixed. Quote:
I think I have to do now... ![]() Quote:
#406 | Link |
Feature request: "Hide" button
Supose you have nine buttons in the following setup: (1) - (2) - (3) (4) - (5) - (6) (7) - (8) - (9) It would be nice to have an option to hide a button, where the original button image is substituted with a transparent one and the navigation commands of the buttons around the hided button are changed in order to ignore it (for example, If you hide button 5, pressing right when been on button 4, should take to button 6 and if you're on button 2, pressing down should take you to button 8). Greetings |
#407 | Link |
Coder
New version v0.30b
A new snapshot is available.
04/15/2010 Changes for v0.30 - Insert/delete image objects - Insert/delete palettes - Cut, copy, paste of movieobject and button commands - Insert/delete button commands - Easy NOPing (Shift-N) for button commands - EP fine and EP coarse table in CPI, CLIPINF - Lot of bug fix Last edited by Pelican9; 15th April 2010 at 16:30. |
#409 | Link |
Pelican9, something wrong with this v0.30b.
I imported Object with replacing and getting error when try to mux menu into m2ts. ![]() Naturally, menu has not been muxed. UPD: oops... it's not fault of BDedit. send you PM. Last edited by tymoxa; 15th April 2010 at 19:11. |
#410 | Link |
Does anybody know a way to keep the transparency ? If a button is set on a transparent square or something, the palette reverts to basic colors, as it should and the back transparency dissappears.
This is a button that is set on a transparent layer: In every scenario attempted, I always get a matte background. |
#414 | Link |
Tested it, doesn't do it. Even if I replace the palette, the other buttons look awkward, and the one edited hasn't that same transparency. I think the only viable solution for the moment is to delete the whole transparent background.
#415 | Link |
new to BD structure edit. With this app is it possible to jump past those annoying language selection screens that always pop up at the start of Paramount blurays. Would be cool to not have to click on english button and instead have it select automatically and continue without any user input
k-c-ksum |
#416 | Link | |
Coder
New version v0.31b
Changes for v0.31
- Insert/delete Pages - Insert/delete BOGs (maintain buttons) - Insert/delete Buttons (maintain ids, neighbours, commands) - Dragging button on graphic page (free, x/y only, grid only, 2x) - Load menu from .m2ts file. - Load menu from command line parameter - Bug fixes Quote:
#417 | Link | ||
Swallowed in the Sea
from the same disc... BDEdit v0.27b: Quote:
#418 | Link | |
Coder
Which movie is this? |
#419 | Link |
I can confirm this too. Slumdog Millionaire (German). Ticking 8.3 makes no difference.
On startup I get the messagebox Failed To Set Data For " v29b5 Code:
A new beta version (v0.31b) is available. Unregistered copy. Checking required files and directories... PLAYLIST folder: OK CLIPINF folder: OK BACKUP folder: OK index.bdmv: OK MovieObject.bdmv: OK Reading MovieObject.bdmv Found 77 objects, 0 extended entry. Reading playlists Found 76 playlists. Reading clipinfos Found 39 clipinfos. Reading index.bdmv Found 605 titles, 0 extended entry. AUXDATA folder: OK AUXDATA\sound.bdmv: missing STREAM folder: OK Found 39 AV streams META folder: OK BDJO folder: OK JAR folder: OK Reading 00000.mpls 1 PlayItem(s), 0 SubPath(s) and 1 PlayListMark(s) found. Reading 00000.clpi 2 Program stream(s) found. Reading 01000.bdjo Code:
Unregistered copy. Checking required files and directories... PLAYLIST folder: OK CLIPINF folder: OK BACKUP folder: OK : missing : missing ERROR: Check failed. Checking required files and directories... PLAYLIST folder: OK CLIPINF folder: OK BACKUP folder: OK : missing : missing ERROR: Check failed. Checking required files and directories... PLAYLIST folder: OK CLIPINF folder: OK INDEX.BDM: missing MOVIEOBJ.BDM: missing ERROR: Check failed.
Blu-Ray Movie Only Copies : Clown_BD Blu-Ray Movie Only DVD Conversion : Clown_BD Blu-Ray Copies With Menus : Clown_BD BD Copier Last edited by mrr19121970; 18th April 2010 at 18:00. |
#420 | Link | |
Coder
Is this error happens to all title or only to this one? Last edited by Pelican9; 18th April 2010 at 18:23. |
| Tags |
| bd menu, bdedit, blu-ray |
| Display Modes | |
