28th December 2015, 06:10 | #201 | Link |
Soul Architect
If someone wants to port NNEDI3...
https://github.com/zachsaw/MPDN_Exte...Scripts/NNEDI3 There might be some advantages to it. First, it would allow processing NNEDI3 with 16-bit depth. Second, it *might* not have performance overhead compared to SuperRes if both are run together, since running more commands in the same chain won't increase memory transfers. I know the AviSynth version of NNEDI3 is well optimized, and I'd be curious to see how it would perform in this case since the GPU is under-utilized anyway. It would take a stand-alone version of NNEDI3, and then another script that combines NNEDI3 and SuperRes to run in the same chain. What I'm not sure about is how to do the sub-pixel shift in HLSL. |
28th December 2015, 07:11 | #202 | Link |
Soul Architect
btw I found something that makes SuperRes shine even more. If I use KNLMeans with cmode=true to also denoise the chroma, I can apply a stronger SuperRes. See for yourself.
Without SuperRes Code:
AviSource("Preview.avi", pixel_type="YV12") ConvertToYV24() KNLMeansCL(D=1, A=2, h=2.1, cmode=true, device_type="GPU", device_id=0) ConvertToYV12() ColorMatrixShader(MatrixIn="601") edi_rpow2(2, nns=4, cshift="Spline16Resize", Threads=2) edi_rpow2(2, nns=4, cshift="BicubicResize", a1=-.6, a2=0, fwidth=960, fheight=720, Threads=2) With SuperRes Code:
AviSource("Preview.avi", pixel_type="YV12") ConvertToYV24() KNLMeansCL(D=1, A=2, h=2.1, cmode=true, device_type="GPU", device_id=0) ConvertToYV12() Double="""edi_rpow2(2, nns=4, cshift="Spline16Resize", Threads=2)""" SuperRes(1, 1, 0, Double, MatrixIn="601") Double="""edi_rpow2(2, nns=4, cshift="BicubicResize", a1=-.6, a2=0, lsb=true, fwidth=960, fheight=720, Threads=2)""" SuperRes(1, 1, 0, Double, lsb_upscale=true) |
28th December 2015, 11:30 | #203 | Link | |
28th December 2015, 18:07 | #204 | Link |
Soul Architect
Oh.
Using ShaderModel 5 requires DirectX 11 DirectCompute instead of DirectX 9. I had worked on that implementation before; and then reverted back to DX9 when I realized configuring parameters was complex complicated. Everything else was pretty straightforward. Exact same logic as DX9 but replacing the commands with new names that make more sense. The DirectX code is well separated from the AviSynth code to make it easy. That still would be considerable work that I won't have time for.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 28th December 2015 at 18:15. |
29th December 2015, 01:58 | #206 | Link | |
Soul Architect
In the meantime, here's AviSynthShader v1.3.2 What's new: - Added FormatOut to all scripts to set output format - Fixed SuperRes when using lsb_out - Removed bogus "info" in Super-xBR |
29th December 2015, 03:11 | #207 | Link |
Soul Architect
Natural Grounding Player v1.3 is here. Merry Christmas!!
Natural Grounding Player Media Encoder thread is here
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 29th December 2015 at 03:40. |
29th December 2015, 03:17 | #208 | Link |
Anime addict
Hi, thanks for your work. One question, I am testing your code with some modification, this:
DGDecode_mpeg2source("E:\Dragon Ball\DB_13\074\VideoFile.d2v", info=3) assumetff() tfm(order=1,pp=6,mode=4).tdecimate(mode=1) Spline36Resize(720,480,6,0,-3,-6) ConvertToYV24() ChromaReconstructor() # Dont smooth KNLMeansCL(D=1, A=2, h=2.1, cmode=true, device_type="GPU", device_id=0) ConvertToYV12() Double="""edi_rpow2(2, nns=4, cshift="Spline16Resize", Threads=2)""" SuperRes(1, 1, 0, Double, MatrixIn="601") Double="""edi_rpow2(2, nns=4, cshift="BicubicResize", a1=-.6, a2=0, lsb=true, fwidth=960, fheight=720, Threads=2)""" SuperRes(1, 1, 0, Double, lsb_upscale=true) spline36resize(640,480) # its for comparison return last The result is good, but in dark areas is too smoothing and lost details (background). Any configuration less destrutive for your code, type as sourcematch in qtmgc??
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
29th December 2015, 12:34 | #210 | Link |
Anime addict
Ok, apologize me. It is KNLMeansCl which causes lost of details.
Edit: I get a good result but its bit slooooooow XD: Original: 640x480; Upsize: 960x720 Code: Code:
DGDecode_mpeg2source("E:\Dragon Ball\DB_13\074\VideoFile.d2v", info=3) assumetff() tfm(order=1,pp=6,mode=4).tdecimate(mode=1) Spline36Resize(720,480,6,0,-3,-6) ConvertToYV24() ChromaReconstructor() ConvertToYV12() Double="""edi_rpow2(2, nns=4, cshift="Spline16Resize", Threads=2)""" SuperRes(1, 1, 0, Double, MatrixIn="601") Double="""edi_rpow2(2, nns=4, cshift="BicubicResize", a1=-.6, a2=0, lsb=true, fwidth=960, fheight=720, Threads=2)""" SuperRes(1, 1, 0, Double, lsb_upscale=true) #/*Prefiltrado*/# original=last pre=original.BrightDfttestMod(sbright=8.5, smedium=2.0, sdark=0,th_low=20, th_med=40, th_high=100, tbsize=1,lsb=true,mode=6) mascara=original.mt_edge("hprewitt",thY1=8, thY2=255,thc1=0,thc2=255) prefiltrado=mt_merge(pre, original, mascara) #Temporal degrain tr = 6 last=prefiltrado.SMDegrain (tr, thSAD=570, thSADC=180,lsb=true,lsb_out=true,thSCD1=570,thSCD2=160, blksize=8, overlap=4,search=4,contrasharp=false) #/*Otros*/# csmod16(lsb_in=true, lsb=true) gradfun3(mode=6,lsb_in=true, lsb=false) Unsharphq(19,1.6,0.2,show=false) santiag(aa=15) hysteria(showmask=false,strength=0.9,lowthresh=32,highthresh=32)
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 29th December 2015 at 13:53. |
29th December 2015, 15:27 | #211 | Link |
The image enthusyast
overdrive80, suggestion: instead use spline 36 and edi, apply spline 144 or lanczos 4, and nnedi3, and change cshift: put spline144 or lanczos4. Post here the result. Your result you`ve posted is a bit blurry, if we compare with original image.
Searching for great solutions Last edited by luquinhas0021; 29th December 2015 at 15:47. |
29th December 2015, 17:09 | #212 | Link |
Anime addict
The code is here, you can change at your way. I am only playing with that tool.
29th December 2015, 18:41 | #214 | Link |
Soul Architect
ChromaReconstructor is very slow; remove it to get a performance boost.
ConvertToYV24() ChromaReconstructor() ConvertToYV12() SuperRes runs around resizers to restore the details while upscaling. Super-xBR is a frame-double algorithm, similar to NNEDI3. SuperRes require a frame-double algorithm to run: either NNEDI3, EEDI3 or Super-xBR. |
29th December 2015, 19:10 | #216 | Link | |
Anime addict
If I remove Converttoyv12, I get this: http://postimg.org/image/s1g7mv6pp/ I had add Converttoyv12 before of Hysteria because dont admit YV24 EDIT: Problem of SMDegrain, neither admit YV24
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 29th December 2015 at 19:31. |
29th December 2015, 20:02 | #217 | Link | |
Soul Architect
Super-xBR seems to be doing a good job on some material. It is very sharp but has serious ringing problems, which are then reduced by applying SuperRes. I personally prefer NNEDI3 because its results are more consistent. |
29th December 2015, 20:10 | #218 | Link |
Anime addict
#Obviously, garbage is accentuated Double="""edi_rpow2(2, nns=4, cshift="SincResize", Threads=8)""" SuperRes(1, 1, 0, Double, MatrixIn="601") Double="""edi_rpow2(2, nns=4, cshift="SincResize", a1=-.6, a2=0, lsb=true, fwidth=960, fheight=720, Threads=8)""" SuperRes(1, 1, 0, Double, lsb_upscale=true)
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite Last edited by Overdrive80; 29th December 2015 at 20:22. |
29th December 2015, 20:17 | #219 | Link |
MisteryX, edge strenght goes from 0 to 5. 1 is the maximum acceptable value? 1 is the maximum acceptable value of sharpness? Super-xBR in Dither16 generates less artifacts? You talked you preffer nnedi3, but a lot of people says Super-xBR retains more details than nnedi3. You told me that use Super-xBR with SuperRes reduces ringing. What about sharpness where there isn`t ringing: reduces? Super-xBR is equal sharp or sharper than sinc4? And compared with the monstruosly sharp, and aliased, Bicubic b=-1, c=1?
Searching for great solutions Last edited by luquinhas0021; 29th December 2015 at 20:31. |
