26th August 2009, 17:05 | #5581 | Link |
Does this happen with all files? (avi,mp4 and so on)
26th August 2009, 23:20 | #5583 | Link |
yes. if original mkv has chapters. chapters are automatically extracted and imported into new mkv.
27th August 2009, 01:26 | #5584 | Link | |
I loaded up the BD so I could encode it down to 720p. However, when I hit encode there is no info at the bottom of the ripbot screen saying what % it's at. It's completely blank. I don't remember it doing this on other encodes. I checked my CPU usage and it's 50% so it appears ripbot is going, and the temp folder has all the files in it. I just have no display to see how it's going.
Edit: Looks like I have the same issue as Ken does. x264_x86.exe is only using 620k of memory but 50% CPU. Quote:
27th August 2009, 10:24 | #5585 | Link |
replace old x264_x86.exe with new one http://jeeb.fiveforty.jp/x264/1235/x264.exe
27th August 2009, 12:32 | #5586 | Link |
Have a bit of an issue, trying to re-encode 'Cloverfield' blu ray to 480x272 with the PSP profile. It whizzes through the encode at something silly like 500fps and then gives me an MP4 which is only something like 8 minutes long. If I don't resize and use the Blu Ray profile it correctly re-encodes. Anyone got any idea what is causing this? |
27th August 2009, 12:45 | #5587 | Link |
Uninstall AviSynth , Haali Media Spliter , FFdshow. Update manually x264_x86.exe and x264_x64.exe
I hope this helps.
27th August 2009, 22:05 | #5588 | Link | |
BDSup2Sub
@Atak,
I was curious of the command that you use when running BDSup2Sub. I have a BD that's 24fps instead of 23.976fps and the subtitle is out of sync. I manually ran the following from the cmd shell: Quote:
-Hoju |
28th August 2009, 01:00 | #5589 | Link |
RipBot264 Setting?
Hey, i would like to know what setting is more good? Im ripping right now at 1080p (HD full) and with QC - 20. It gives me about 10-15gig each movies. Its big but i dont really want to loose quality. Can i go 22? Or you could see the diference? I have a 48inch Plasma TV. And is QC better than 2 pass method? I know with QC i cant make the output size. So im gessing thats better right?
PS: and all the other programmes, like ffdshow, haali media splitter, do i need to change some of these settings? Or its all good if i keep it like it is? Hope you guys can help Cya! ohh yeah.. I use MKV for file format, and also 640kbps (the better one). |
28th August 2009, 03:44 | #5590 | Link |
Hello gents, Have anyone had any issues with subtitles not working with BD rips? I would rip the whole movie, when I use ripbot to specify what subtitle I want it accepts it.
But when I actually finish the movie, there is no subs? any ideas? |
28th August 2009, 21:38 | #5593 | Link | |
I'll check when I get home.
I add it there also and still nothing. |
28th August 2009, 23:30 | #5595 | Link |
delay is constant?
28th August 2009, 23:32 | #5596 | Link | |
x264_x86 not working in Windows 7
I was wondering that was the issue but when I tried to follow a previous post to the "latest x264" thread, I was lost in a sea of patch definitions and updates. Thank you very much for providing a link to this file. Ken |
29th August 2009, 00:08 | #5597 | Link |
Two questions. First thanks for Ripbot. When creating a mkv I do not have the Copy Stream option for a HD-DVD. Is this possible? Does Ripbot support TrueHD in a mkv? My next question is why does Ripbot only have a 4.0 profile not a 4.1 profile? Thanks in advance.
29th August 2009, 00:47 | #5598 | Link |
I had the same issue. Wouldn't show up and no players could display it even though it appeared to be added when viewing the encoded video file with mediainfo. When trying to add the sub with build in picture, ripbot would just hang after the encoding was finished, freezing on "muxing".
29th August 2009, 01:28 | #5600 | Link |
Okay I did some more research. The only difference between 4.0 and 4.1 is bitrate. The author of RipBot feels strongly that there is no reason to go to 4.1. What does the bitrate mean in terms of quality? If there is no difference why does the standard exist? Thanks.
