Old 18th September 2021, 01:33   #21  |  Link
poisondeathray
Originally Posted by DTL View Post
Can you show example of that shader output ? I do not have vapoursynth.
This is FFV1, YUV444P16 output of placebo.Resample Sinc 16 tap. You can open in AVS with LWLibavVideoSource, or FFVideoSource. It looks worse to me. FMTC was bit identical to avs version
https://www.mediafire.com/file/uy2k1...hader.mkv/file
avs input to vpy script
ColorBarsHD(9600,1000, pixel_type="YV24")
ConvertBits(16) # YUV 444 16
Crop(0,0,9600,500)
AddBorders(300,300,300,300)
GaussResize(width/10,height/10, p=10)
vpy
clip = core.placebo.Resample(clip, width=clip.width*4, height=clip.height*4, filter ="sinc", param1=16)
Also I found more execution non-stability of SincResize at different CPUs ans OS version
Maybe different path execution, SIMD, instruction sets ? Was there a way to disable ? In vapoursynth there was cpu_type="none" , IIRC there was similar switch in avs for debugging
Old 18th September 2021, 06:44   #22  |  Link
DTL
Originally Posted by poisondeathray View Post
e.g. 8bit sRGB converted "red" should 191,0,0 . AVS version is 188,0,0. VPY version is 191,0,0
I made calculation of 8bit codevalues for HDR colorbars (that I can design in MS-Paint and save as 8bit BMP/PNG) for 75% (brightness):
HLG narrow: 40% grey - 104, R'G'B' - 180 high, 16 low
PQ narrow: 40% grey - 104, R'G'B' - 143 high, 16 low
PQ full: 40% grey - 102, R'G'B' - 148 high, 0 low
And target 10bit YUV table for output now this (OpenOffice Calc designed)
"It looks worse to me."
Yes - it have some ringing on horizontal transients. And it is strange because the data after GaussResize have equal conditioning of vertical and horizontal transients.
May be some codevalues distorition happens when transfer from avisynth to vapoursynth. Anyway it may be task to vapoursynth shader designers to check.
Also difference between avs and vps in subtract operation is also with transients shape and levels (causing coloring also)
vps=FFMpegSource2("test3shader.mkv")
vps=vps.ConvertToRGB24(matrix="PC.709")
Subtract(last,vps)
Image: https://i5.imageban.ru/out/2021/09/1...054da523c4.png
So it looks there are really lots of codevalues changes somwhere.
Old 18th September 2021, 19:53   #23  |  Link
DTL
It looks I understand why it is so hard to get nice color-bars in subsampled form. The typically good looking only 1 of 3 RGB transients like white-yellow (B-only transient) and cyan-green (B-only transient). But with 2 or 3 transients at once it much more awful. It looks like different rise and fall speed of full-band Y/G and half band R and B makes bright and dark shadows on many color transients.
The green-magenta is something like (not very exact/symmethrical created in MS-paint with lines and curves)
So if any component is sub-sample misaligned - we got significant Y-error out of expected shape.
So I think of attempt of limiting band of Y so sort of 2:2:2 (in faked 4:2:2) may be look better - need to test. Current result still no good.
Old 30th September 2021, 00:23   #24  |  Link
DTL
Made 2 tools for manual transients design (in SDR and PQ/HLG HDR transfers/2020-matrix):
Web-based simulator https://github.com/DTL2020/TransientsDesign
Tool for write raw files from text-defined samples: https://github.com/DTL2020/WriteTransients
It have built-in chroma anti-ring filter I hope close to UserDefined2Resize(b=105,c=0).
Green-magenta transient in SDR looks like
https://i1.imageban.ru/out/2021/09/3...591a84e339.png
So typical display-simulator script is:
Function Convert422ToRGB24mon_lin_x4_709(clip c)
  uc=UToY(c)
  vc=VToY(c)
  uc=UserDefined2ResizeMT(uc,src_left=0.001,uc.width, uc.height, b=105, c=0)
  vc=UserDefined2ResizeMT(vc,src_left=0.001,vc.width, vc.height, b=105, c=0)
  uc=SincLin2ResizeMT(uc, src_left=0, uc.width*2, uc.height, taps=8)
  vc=SincLin2ResizeMT(vc, src_left=0, vc.width*2, vc.height, taps=8)
  yuv444=CombinePlanes(c, uc, vc, planes="YUV", source_planes="YYY", pixel_type="YUV444P10")
  rgb_lin=ConvertYUVToLinearRGB(yuv444,Color=2)
  rgb_lin=SincLin2ResizeMT(rgb_lin,rgb_lin.width*4, rgb_lin.height*4, taps=16)
  yuv_out=ConvertLinearRGBToYUV(rgb_lin,Color=2)
  return yuv_out.ConvertToRGB24(matrix="PC.709")
Chroma position relative to Y' looks like not require 0.5..1 sample shift at conversion to 4:4:4 (not sure if it correct).
Old 2nd October 2021, 19:56   #25  |  Link
DTL
Now with ability to put transient sourcing to scripting (instead of loading external raw-file) it is easier to test different HLG to linear convertors (for monitoring).
LoadPlugin("plugins_JPSDR.dll")
LoadPlugin("avsresize.dll")
LoadPlugin("fmtcavs.dll")
Function Convert422ToRGB24mon_lin_x4_HLG(clip c)
  uc=UToY(c)
  vc=VToY(c)
# jpsdr_plugin
#  rgb_lin=ConvertYUVtoLinearRGB(yuv444,Color=0,HDRMode=2)
#  rgb_lin=RGBAdjust(rgb_lin,r=3,g=3,b=3)
# avsresize
#  rgb_lin=z_convertformat(yuv444,pixel_type="rgbps", colorspace_op="2020ncl:std-b67:2020:l=>rgb:linear:2020:l", nominal_luminance=300)
#fmtconv
  rgb_lin=fmtc_matrix(yuv444,mat="RGB", mats="2020",fulls=true, fulld=true)
  rgb_lin=fmtc_transfer(rgb_lin,transs="hlg",transd="linear",bits=32)
plY=Blankclip(width = 10, height = 1, pixel_type="Y10").Expr("sx 0 == 509 sx 1 == 509 sx 2 == 509 sx 3 == 509 sx 4 == 509 sx 5 = 498 sx 6 = 446 sx 7 == 361 sx 8 == 292 276 ? ? ? ? ? ? ? ? ?")
plU=Blankclip(width = 5, height = 1, pixel_type="Y10").Expr("sx 0 == 270 sx 1 == 263 sx 2 == 330 sx 3 == 761 754 ? ? ? ?")
plV=Blankclip(width = 5, height = 1, pixel_type="Y10").Expr("sx 0 == 203 sx 1 == 224 sx 2 == 271 sx 3 == 832 821 ? ? ? ?")
tr=CombinePlanes(plY, plU, plV, "YUV", "YYY", pixel_type="YUV422P10")
sust_l=Blankclip(width = 4, height = 1, pixel_type="YUV422P10").Expr("sx 0 == 509 sx 1 == 509 sx 2 == 509 509 ? ? ?","sx 0 == 270 270 ?","sx 0 == 203 203 ?").PointResize(50,1)
sust_r=Blankclip(width = 4, height = 1, pixel_type="YUV422P10").Expr("sx 0 == 276 sx 1 == 276 sx 2 == 276 276 ? ? ?","sx 0 == 754 754 ?","sx 0 == 821 821 ?").PointResize(52,1)
StackHorizontal(sust_l,tr)
StackHorizontal(last,sust_r)
PointResize(width, 100)
# source finishes here, 75% green-magenta transient HLG 10bit 4:2:2
#test convert to 4:4:4 and back
#ConvertToYUV444()
#ConvertToYUV422()
Convert422ToRGB24mon_lin_x4_HLG()
Results of decoding same green-magenta 75% transient to linear RGBPS by different tools are a bit different:
jpsdr plugin and fmtc looks close enough and z_convertformat looks like differs most. May be its 'std-b67' is not really linear but also contain OOTF ? Currently the most close to as expected result is from fmtc.
Both jpsdr convert and fmtc require RGB gain 3.0 to bring intensity to something >50%.
z_convertformat have some misterious param 'nominal_luminance' that greatly infuence the output result but no adjustment for me can bring result close to the other 2 tools.
Old 3rd October 2021, 06:41   #26  |  Link
StvG
https://github.com/sekrit-twc/zimg/i...ment-319853981
approximate_gamma also changes the output.
StvG is offline   Reply With Quote
Old 3rd October 2021, 11:18   #27  |  Link
DTL
"approximate_gamma also changes the output."
Yes - it significally changes sustained levels and transient. Looks make things better.
Strange why default is not 'false'. Desciption at http://avisynth.nl/index.php/Avsresize says only about reduced precision. I think it is something about 1 LSB error in 16bit. But it may be slower so default is 'true' for speed ?
Anyway - one HLG-encoded dataset, one processing path and so different results with different conversion HLG to linear tools. It looks HDR workflows is still a big mess.
The colour tone and saturation of magenta field also different a lot. May be de-matrix transforms also not very equal ?
I tried to set available control params for HLG to linear conversion to get both good looking of transient and sustained levels of green and magenta. May be better to get best possible RGB levels of sustained green (R=B=0 G=some_level) and magenta (R=B=same_some_level G=0) and look how transient rendering will be.
Old 3rd October 2021, 16:22   #28  |  Link
StvG
Yes, approximate_gamma=false is slow. That's the reason to be true by default.
I suggest to use the filter for yuv_HLG->linear to reverse linear->yuv too.
So for avsresize:
# avsresize
#  rgb_lin=z_convertformat(yuv444,pixel_type="rgbps", colorspace_op="2020ncl:std-b67:2020:l=>rgb:linear:2020:l", nominal_luminance=1000, approximate_gamma=false)
yuv_out=z_ConvertFormat(rgb_lin, pixel_type="yuv444ps", colorspace_op="rgb:linear:2020:l=>709:709:709:l")
Now you have different output again.
Something about mixing of filters: I would suggest to not use avsresize/ftmconv (didn't tested the last) to perfrom PQ->linear and then tonemapping with HDRTools. If HDRTools is used for tonemapping, use this filter for everything (yuv->linear->tonemapping). If DGx filters are used for tonemapping, use avsresize for yuv->linear.
Last edited by StvG; 3rd October 2021 at 16:55. Reason: Was thinkng of PQ while writing about HLG
Old 3rd October 2021, 17:15   #29  |  Link
DTL
"Now you have different output again."
Yes - in this script we not control result in linear RGB but pack it again to rec.709 system to feed close to rec.709 typical display (at 2021 year). So may be additional errors.
"yuv_out=z_ConvertFormat(rgb_lin, pixel_type="yuv444ps", colorspace_op="rgb:linear:2020:l=>709:709:709:l")"
It looks again some misunderstanding. We test colorbars defined as 0..HLG_inverse(0.75) RGB triplets (and transients between this sustained values). Its numbers may define any physical primaries. But when we command system to convert prmaries from 2020 to 709 it creates mess of RGB triplets (also may be also some limited by 709 top values because 2020 colour space > 709 colour space and 0.75 100% saturated HLG is most possibly out of 709 colour space). So all transients will be damaged too.
We are not monitor exact rec.2020 physical spectrum (it is not possible on 709 monitors) but want to check if transients do not have ringing/large over/under shooting, parasitic bright or dark lines etc. So to try it we 'cast' rec.2020 RGB triplets to our physical rec.709 display output. It will display rec.709 spectrum colourbars but I hope the Intensity on transients will more or less follow the output of real rec.2020 primaries display. Though in best case it need to be checked with colorimetry calculation.
So for 'casting' decoded RGB linear primaries to current display's primaries we just do not touch it:
Both
yuv_out=z_ConvertFormat(rgb_lin, pixel_type="yuv444ps", colorspace_op="rgb:linear:2020:l=>709:709:2020:l")
yuv_out=z_ConvertFormat(rgb_lin, pixel_type="yuv444ps", colorspace_op="rgb:linear:709:l=>709:709:709:l")
gives the same result.
Though it also differs from jpsdr's plugin.
Because jpsdr's plugin can not (I do not know) apply only transfer to RGB without matrix convert to YUV it looks no way to test transfer only. We not need to monitor to go down to YUV matriced data and back so better return from monitor function is
return z_ConvertFormat(rgb_lin, pixel_type="rgbp8", colorspace_op="rgb:linear:709:l=>rgb:709:709:l").ConvertToRGB() (I do not see how to output interleaved RGB from z_convertformat directly)
Or with fmtc:
return fmtc_transfer(rgb_lin,transs="linear",transd="709",fulls=true, fulld=true).ConvertBits(8).ConvertToRGB()
It is strange but fmtc again looks the best (almost same as jpsdr's with going to YUV and back). For unknown reason z_convertformat output have lot of low-amplitude ringing (may be it come from x4 upsize or not).
Last edited by DTL; 3rd October 2021 at 18:20. Reason: replaced image with more examples
Old 3rd October 2021, 20:48   #30  |  Link
DTL
"I suggest to use the filter for yuv_HLG->linear to reverse linear->yuv too."
Why ? When we monitor we do not need to subsample and any more resample - so no additional filtering. The task of processing after getting linear RGB in restored 4x upsampled size is just feed our RGB monitor (that can not still accept linear RGB so we still need to convert RGB to R'G'B' in the transfer of the used monitor that on PC's typically srgb/rec.709).
Also at the last simplification if not use jpsdr's plugin it is no more need YUV stage after linear RGB at all.
Old 3rd October 2021, 23:35   #31  |  Link
StvG
Right, HDRTools cannot convert only transfer.
Why ?
I meant the same filter should be used for both operations: convert_to_linear and convert_from_linear.
You're using full range for fmtc bul limited for avsresize.
You can try:
# avsresize
rgb_lin=z_convertformat(yuv444,pixel_type="rgbps", colorspace_op="2020ncl:std-b67:2020:f=>rgb:linear:2020:f", nominal_luminance=800)
return z_ConvertFormat(rgb_lin, pixel_type="rgbp8", colorspace_op="rgb:linear:709:f=>rgb:709:709:f").ConvertToRGB()
#fmtconv
Old 4th October 2021, 10:49   #32  |  Link
DTL
"I meant the same filter should be used for both operations: "
Oh - I think of 'filter' as engineering device/operation for spectrum changing (filtering) and the only applied spatial frequency filter here is for anti-ringing of subsampled UV. And you use Avisynth filter term as any command operation in Avisynth.
Well - the
rgb_lin=z_convertformat(yuv444,pixel_type="rgbps", colorspace_op="2020ncl:std-b67:2020:l=>rgb:linear:2020:l", nominal_luminance=800)
The only 'magic' combination that produce close result to fmtc and jpsdr's plugin (without conversion params adjustments but with RGB gain = 3.0).
I later think nominal_luminance may be same adjustment as RGB gain after z_convertformat, but it looks no.
So the main important and hidden param to z_convertformat for HLG to linear is "nominal_luminance=800".
Old 4th October 2021, 17:10   #33  |  Link
StvG
Why are you using avsresize with limited range but fmtc with full?
Old 4th October 2021, 18:15   #34  |  Link
DTL
Oh - it looks my error of too bad reading documentation. I think fulls/fulld = true as of 'limited'.
Also somwhere set it, somwhere forgot. jpsdr's plugin uses default=limited, fmtc_transfer uses default=full(true), fmtc_matrix (depends). z_convertformat have no default ?
With sustained R'G'B' output still a big mess:
I hope the encoded HLG in 'limited' range so output low-RGB (limited 8bit) should be 16 (and max_RGB not exactly defined because of some 3.0 multiplier to RGB linear to make image bright enough, though maxR=maxG=maxB).
 .. scale x4
 return ConvertLinearRGBToYUV(rgb_lin,Color=2).ConvertToRGB24(matrix="PC.709")
returns green R'G'B' 0, 205,13, magenta R'G'B' 201,11,213 - I think it some matrix and transfer errors ?
 .. scale x4
returns green R'G'B' 16,211,16 and magenta R'G'B' 212,16,212 that looks most perfect and as expected.
  rgb_lin=fmtc_matrix(yuv444,mat="RGB", mats="2020",fulls=false, fulld=false)
  rgb_lin=fmtc_transfer(rgb_lin,transs="hlg",transd="linear",bits=32,fulls=false, fulld=false)
.. scale x4
return fmtc_transfer(rgb_lin,transs="linear",transd="709",fulls=false, fulld=false).ConvertBits(8).ConvertToRGB()
returns green R'G'B' 0,227,0 and magenta R'G'B' 228,0,228 that looks like somewhere scaled to 'full' though I everywhere set full*=false. May I need to report issue to fmtc development thread ? (post a question - https://forum.doom9.org/showthread.p...94#post1953894 ).
Old 4th October 2021, 20:39   #35  |  Link
DTL
Oh - the fmtc require some (undocumented magic) of Avisynth to work as expected:
return fmtc_transfer(rgb_lin,transs="linear",transd="709",fulls=false, fulld=false).ConvertBits(8,fulls=true,fulld=false).ConvertToRGB()
Now it outputs also
green R'G'B'=16,211,16 and magenta R'G'B' =211,16,211.
Need post request for update docs at http://avisynth.nl/index.php/ConvertBits .
Current HLG monitor function now:
  uc=UToY(c)
  vc=VToY(c)
# jpsdr_plugin
# avsresize
#rgb_lin=z_convertformat(yuv444,pixel_type="rgbps", colorspace_op="2020ncl:std-b67:2020:l=>rgb:linear:2020:l", nominal_luminance=800)
#rgb_lin=RGBAdjust(rgb_lin,r=3,g=3,b=3)
#fmtconv
#return z_ConvertFormat(rgb_lin, pixel_type="rgbp8", colorspace_op="rgb:linear:709:l=>rgb:709:709:l").ConvertToRGB()
# return ConvertLinearRGBToYUV(rgb_lin,Color=2).ConvertToRGB24(matrix="PC.709")
fmtc again wins in sustained levels precision (very small - 1LSB at 8bit at some RGB channels). z_convertformat (very small) better with less visual intensity falling at the green-magenta transient.
jpsdr's plugin is subject to many questions.
And 2 of 3 full-3 primaries changing at transient examples:
# red-cyan
plY=Blankclip(width = 10, height = 1, pixel_type="Y10").Expr("sx 0 == 240 sx 1 == 252 sx 2 == 283 sx 3 == 359 sx 4 == 418 sx 5 = 495 sx 6 = 545 sx 7 == 548 sx 8 == 548 548 ? ? ? ? ? ? ? ? ?")
plU=Blankclip(width = 5, height = 1, pixel_type="Y10").Expr("sx 0 == 418 sx 1 == 418 sx 2 == 432 sx 3 == 600 606 ? ? ? ?")
plV=Blankclip(width = 5, height = 1, pixel_type="Y10").Expr("sx 0 == 848 sx 1 == 844 sx 2 == 799 sx 3 == 184 176 ? ? ? ?")
sust_l=Blankclip(width = 4, height = 1, pixel_type="YUV422P10").Expr("sx 0 == 237 sx 1 == 237 sx 2 == 237 237 ? ? ?","sx 0 == 418 418 ?","sx 0 == 848 848 ?").PointResize(50,1)
sust_r=Blankclip(width = 4, height = 1, pixel_type="YUV422P10").Expr("sx 0 == 548 sx 1 == 548 sx 2 == 548 548 ? ? ?","sx 0 == 606 606 ?","sx 0 == 176 176 ?").PointResize(52,1)
rc=PointResize(width, 100)
# source finishes here, 75% red-cyan transient HLG 10bit 4:2:2
# blue-yellow
plY=Blankclip(width = 10, height = 1, pixel_type="Y10").Expr("sx 0 == 103 sx 1 == 103 sx 2 == 143 sx 3 == 294 sx 4 == 416 sx 5 = 568 sx 6 = 659 sx 7 == 684 sx 8 == 682 682 ? ? ? ? ? ? ? ? ?")
plU=Blankclip(width = 5, height = 1, pixel_type="Y10").Expr("sx 0 == 848 sx 1 == 848 sx 2 == 710 sx 3 == 202 169 ? ? ? ?")
plV=Blankclip(width = 5, height = 1, pixel_type="Y10").Expr("sx 0 == 485 sx 1 == 485 sx 2 == 507 sx 3 == 539 539 ? ? ? ?")
sust_l=Blankclip(width = 4, height = 1, pixel_type="YUV422P10").Expr("sx 0 == 103 sx 1 == 103 sx 2 == 103 103 ? ? ?","sx 0 == 848 848 ?","sx 0 == 485 485 ?").PointResize(50,1)
sust_r=Blankclip(width = 4, height = 1, pixel_type="YUV422P10").Expr("sx 0 == 682 sx 1 == 682 sx 2 == 682 682 ? ? ?","sx 0 == 176 176 ?","sx 0 == 539 539 ?").PointResize(52,1)
by=PointResize(width, 100)
# source finishes here, 75% blue-yellow transient HLG 10bit 4:2:2
Looks not very great on simulator but at the monitoring looks better (additionally manually tweaked to look best at monitoring). They are not exist in 'old standard color bars' but possibly useful for testing too.
Old 5th October 2021, 01:15   #36  |  Link
StvG
avsresize has the following default values for range:
- rgb - full
- yuv < 32-bit - limited
- yuv 32-bit - full.
Both avsresize and fmtc treat a clip in float in the same way - always full range.
To avoid range mess and to perform also matrix conversion with fmtc in float:
# avsresize
# rgb_lin=ConvertBits(yuv444, 32, fulls=false, fulld=true).z_convertformat(pixel_type="rgbps", colorspace_op="2020ncl:std-b67=>rgb:linear", nominal_luminance=800)
#fmtconv
rgb_lin=ConvertBits(yuv444, 32, fulls=false, fulld=true).fmtc_matrix(mat="RGB", mats="2020")
rgb_lin=fmtc_transfer(rgb_lin,transs="hlg",transd="linear")
# return z_ConvertFormat(rgb_lin, colorspace_op="rgb:linear=>rgb:709").ConvertBits(8, fulls=true, fulld=false).ConvertToRGB()
return fmtc_transfer(rgb_lin,transs="linear",transd="709").ConvertBits(8, fulls=true, fulld=false).ConvertToRGB()
Old 5th October 2021, 13:00   #37  |  Link
DTL
"fmtc_matrix(mat="RGB", mats="2020")"
Yes - the most of full*=false function arguments to fmtc are either useless or may be even make things worse. Unfortunately Avisynth API/environment looks like have not ability to display user-side useful warning messages about arguments interpreting, formats and other. Only can throw stop-errors messages.
Old 28th June 2022, 16:29   #38  |  Link
DTL
Some interesting update after I finally was not too patient to wait more years untill official release of EBU Tech 3325 Test Pattern 7 and decide to ask jpsdr in the mid of 2022 about why it outputs not perfectly matched result with fmtconv and avsresize: https://forum.doom9.org/showthread.p...95#post1970995
He point to some more magic in HDRtools:
With
rgb_lin=ConvertYUVtoLinearRGB(yuv444,Color=0,HDRMode=2, OOTF=false, HLGLw=350)
return ConvertLinearRGBToYUV(rgb_lin,Color=2, OOTF=false).ConvertToRGB24(matrix="PC.709")
Conversion to linear and scaling and back to rec.709 transfer the sustained levels are close enough to avsresize and fmtconv plugins but the view of transient looks different (and may be close to the initial design of this transient in simulator - less contrast dark stripe):
Though the Lw=350 is completely adjusted by hand value not based on any theory math just to attempt to put green and magenta sustained levels to match other plugins as close as possible.
Compare with old script of 2021 year. So it looks playing around OOTF and Lw values may give different results in the intermediate levels calcultaion. Are there ways in fmtconv and or avsresize to play also with OOTF on/off and Lw adjustment ?
Old 4th August 2022, 13:49   #39  |  Link
StvG
The following two conversions give me close output:
# jpsdr_plugin
 rgb_lin=ConvertYUVtoLinearRGB(yuv444,Color=0,OOTF=false, HDRMode=2)
# avsresize
rgb_lin=z_convertformat(yuv444,pixel_type="rgbps", colorspace_op="2020ncl:std-b67:2020:l=>rgb:linear:2020:l", nominal_luminance=1500)
return z_ConvertFormat(rgb_lin, pixel_type="yuv444p16", colorspace_op="rgb:linear:709:l=>709:709:709:l").ConvertToRGB(matrix="PC.709")
Also the following two conversions:
# jpsdr_plugin
# avsresize
rgb_lin=z_convertformat(yuv444,pixel_type="rgbps", colorspace_op="2020ncl:std-b67:2020:l=>rgb:linear:2020:l", nominal_luminance=1000)
I cannot get close result with fmtconv. It has sceneref and ambient arg but they didn't change anything.
Old 5th August 2022, 21:50   #40  |  Link
DTL
With updated avsresize r15 plugin https://forum.doom9.org/showthread.p...16#post1972716 and scene_referred param it looks finally the winner in precision but still need some very magic numbers of additional correction to finally output 180/16 codevalues high/low R'G'B' 8bit in green-magenta for HLG narrow:
# jpsdr_plugin
# rgb_lin=ConvertYUVtoLinearRGB(yuv444,Color=0,HDRMode=2, OOTF=false, HLGLw=1000)
# avsresize
rgb_lin=z_convertformat(yuv444,pixel_type="rgbps", colorspace_op="2020ncl:std-b67:2020:l=>rgb:linear:2020:l", scene_referred=true)
rgb_lin=RGBAdjust(rgb_lin,r=0.157,g=0.157,b=0.157)
#fmtconv
#  rgb_lin=fmtc_matrix(yuv444,mat="RGB", mats="2020",fulls=false, fulld=false)
#  rgb_lin=fmtc_transfer(rgb_lin,transs="hlg",transd="linear",bits=32,fulls=false, fulld=false)
#return fmtc_transfer(rgb_lin,transs="linear",transd="709",fulls=false, fulld=false).ConvertBits(8,fulls=true,fulld=false).ConvertToRGB()
#return ConvertLinearRGBToYUV(rgb_lin,Color=2, OOTF=false).ConvertToRGB24(matrix="PC.709")
also the transient looks about good.
jpsdr plugin can only make some unbalanced R'G'B' of Green 16,182,13 and Magenta 171,11,176 when trying to align high value to 180. May be some matrixing is not perfect.
