Old 29th May 2022, 15:07   #7141  |  Link
kedautinh12
PgcDemuxMod
http://downloads.sourceforge.net/pro...se_mirror=iweb
Old 2nd June 2022, 08:23   #7142  |  Link
tormento
Acid fr0g
tormento's Avatar
Has MeGUI x64 development stopped? Why?
@turment on Telegram
Old 2nd June 2022, 10:25   #7143  |  Link
LigH
LigH's Avatar
Probably a lack of volunteers.
New German Gleitz board
Old 3rd June 2022, 13:21   #7144  |  Link
kedautinh12
x264-r3095-baee400
https://artifacts.videolan.org/x264/
Note :
The commit value is wrong due to something upstream at MulticoreWare.
Correct commit number for this release is
9b59d45
FFmpeg version n5.0.1-x
x86
https://github.com/sudo-nautilus/FFm...Win32/releases
https://github.com/sudo-nautilus/FFm...2-lgpl-5.0.zip
x64
https://github.com/BtbN/FFmpeg-Builds/releases
https://github.com/BtbN/FFmpeg-Build...4-lgpl-5.0.zip
Opus-tools v0.2-29-gecd50e5 (using libopus 1.3.1-107-gccaaffa9)
https://www.mediafire.com/file/7dira6fs3m5doyc/
MP4Box v2.1-DEV-rev188-ga1be12658
https://www.mediafire.com/file/i8o50mtdu9kg0kf/
Old 7th June 2022, 08:18   #7145  |  Link
LigH
LigH's Avatar
Multicoreware manages x265, but not x264.
Old 27th June 2022, 18:10   #7146  |  Link
Barough
Barough's Avatar
GPAC-MP4Box v2.0-rev0-g418db4149 (Latest Stable)
https://www.mediafire.com/file/i8zwk6wkwj5b06k/
Old 9th July 2022, 11:50   #7147  |  Link
LeXXuz
19 years and counting...
LeXXuz's Avatar
That would be really sad. It's still my favourite frontend.
LeXXuz is offline   Reply With Quote
Old 14th July 2022, 10:06   #7148  |  Link
Barough
Barough's Avatar
MKVToolNix v69.0.0
https://mkvtoolnix.download/windows/releases/69.0.0/
https://mkvtoolnix.download/doc/NEWS.md
Old 17th July 2022, 19:34   #7149  |  Link
magnetite
Who maintains the update server? If they're busy IRL, maybe they could transfer those duties to someone else?
magnetite is offline   Reply With Quote
Old 17th July 2022, 20:31   #7150  |  Link
I think was Maintained by Zathor,
his/her/they/it public profile does NOT show last active date [does for some people, not for others],
but his last post seems to be [when right click his Avatar, "find all posts by Zathor"], shows last post May 2020.
Old 17th July 2022, 20:31   #7151  |  Link
Barough
Barough's Avatar
Zathor is the only one that works with MeGUI these days as it seems so.......
Old 17th July 2022, 23:56   #7152  |  Link
kedautinh12
dgdecnv_244
https://www.rationalqm.us/dgdecnv/binaries/
Old 17th July 2022, 23:56   #7153  |  Link
kedautinh12
He/she still update from here
http://megui.tmebi.de/test/?C=M;O=D
Old 18th July 2022, 05:40   #7154  |  Link
OK, thanks Ked.
Dont know if you know, but DGDecode(2.0.0.7) x64, does not support some/several args that the x86 version does support, eg UpConv [convert to YUY2].
Old 18th July 2022, 06:33   #7155  |  Link
kedautinh12
OK, thanks Ked.
I think you need talk to videoh for this
Old 18th July 2022, 14:00   #7156  |  Link
He probably knows, it's just that a month or two ago I tried to use an old script on x64 and it did not work,
looking at dll args, it omits several existing in x86.
Its no big deal for me.
Old 18th July 2022, 21:12   #7157  |  Link
Barough
Barough's Avatar
Please, remove.
Old 24th July 2022, 02:15   #7158  |  Link
Barough
Barough's Avatar
* Opus-tools v0.2-29-gecd50e5 (using libopus 1.3.1-156-gab04fbb1)
https://www.mediafire.com/file/c63yp0wydz7cf9g/
* MP4Box v2.1-DEV-rev259-gfc4749f9c
https://www.mediafire.com/file/5s39zpxuevlq62t/
QAAC v2.76
https://github.com/nu774/qaac/releases
* = Updated
Old 28th July 2022, 00:51   #7159  |  Link
kedautinh12
FFmpeg version n5.1-x (x86)
https://github.com/sudo-nautilus/FFm...32-gpl-5.1.zip
FFmpeg version n5.1-x (x64)
https://github.com/BtbN/FFmpeg-Build...64-gpl-5.1.zip
Old 4th August 2022, 16:12   #7160  |  Link
Barough
Barough's Avatar
FDK-AAC v1.0.4 (GCC v12.2.0)
https://www.mediafire.com/file/cskw19a8c6d00pe
