Old 23rd January 2021, 23:26   #6961  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Thanks !
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
Old 1st February 2021, 04:22   #6962  |  Link
tp9192
Hello, whenever I modify a setting in a One Click Encoder profile, and then try to encode something, the change I made doesn't seem to take effect until I fully re-open MeGUI. Specifically, this happened when I tried to change the preset from Medium to Slow or whatever. Any reason why this is?
tp9192 is offline   Reply With Quote
Old 2nd February 2021, 10:06   #6963  |  Link
kedautinh12
Are you use x64 ver??
Old 18th February 2021, 01:47   #6964  |  Link
kedautinh12
DGMPGDec v2.0.0.3
http://rationalqm.us/dgmpgdec/dgmpgdec2003.zip
MKVToolNix v53.0.0
https://mkvtoolnix.download/windows/releases/53.0.0/
MP4Box v1.1.0-DEV-rev506-gc259a3e65
http://www.mediafire.com/file/awy9wd...GCC102.7z/file
x264 0.161.3048 b86ae3c
http://www.mediafire.com/file/l5rmui...GCC102.7z/file
Old 18th February 2021, 02:57   #6965  |  Link
videoh
Useful n00b
Originally Posted by kedautinh12 View Post
DGMPGDec v2.0.0.3
It's at 2.0.0.4 now:
http://rationalqm.us/dgmpgdec/dgmpgdec2004.zip (right click and save link as)
Old 18th February 2021, 03:47   #6966  |  Link
kedautinh12
Windows security detected virus in file DGIndex.exe. Your old ver don't meet any virus problem
Old 18th February 2021, 08:46   #6967  |  Link
LigH
LigH's Avatar
Microsoft Defender is the only engine producing a false alarm.
New German Gleitz board
Old 18th February 2021, 15:13   #6968  |  Link
videoh
Useful n00b
Correct, thank you. I submitted a sample but that's all I can do. I recommend making an exclusion:
Go to Start > Settings > Update & Security > Windows Security > Virus & threat protection.
Under Virus & threat protection settings, select Manage settings, and then under Exclusions, select Add or remove exclusions.
Select Add an exclusion, and then select from files, folders, file types, or process.
Old 20th February 2021, 23:26   #6969  |  Link
Chouonsoku
MeGUI hasn't worked with QAAC encoding in months, is anyone else having any issues here? The program just force closes while trying to generate an L-SMASH index. Input format doesn't seem to matter, I've tried with FLAC, WAV, DTS, AC3, etc. Running latest Windows 10 Build 19041, L-SMASHWorks 20201212, QAAC 2.71.
Preliminary log file only. During closing of MeGUI the well formed log file will be written.
-[Information] Versions
--[Information] MeGUI: 2924 x64
--[Information] MeGUI Debug Data: available
--[Information] Update Check: development update server
-[Information] Operating System: Windows 10 Pro 2004 x64 (10.0.19041.804)
-[Information] .NET Framework: 4.0 (4.0.0.0)
-[Information] .NET Framework: 4.8 (4.8.04084)
-[Information] Microsoft Visual C++ 2010 x64: 10.0.40219
-[Information] Microsoft Visual C++ 2010 x86: 10.0.40219
-[Information] Microsoft Visual C++ 2012 x64: 11.0.61030
-[Information] Microsoft Visual C++ 2013 x64: 12.0.40660
-[Information] Microsoft Visual C++ 2013 x86: 12.0.40660
-[Information] Microsoft Visual C++ 2015-2019 x64: 14.23.27820
-[Information] Microsoft Visual C++ 2015-2019 x86: 14.27.29016
-[Information] Redistributables
-[Information] DPI: 100% (96/96)
-[Information] Resolution: 2560x1440
-[Information] Primary Screen: True
-[Information] Monitor 1
-[Information] Resolution: 3840x2160
-[Information] Primary Screen: False
-[Information] Monitor 2
--[Information] System Information
-[Information] Update detection
-[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
-[Information] Haali DSS2: (14-04-2013)
-[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (08-01-2019)
-[Information] MediaInfo: 18.05.0.0 (08-01-2019)
-[Information] SevenZipSharp: 0.64.3890.29348 (08-01-2019)
-[Information] 7z: 9.20 (08-01-2019)
--[Information] Component Information
--[Information] [2/20/2021 4:20:03 PM] Using cached update config and server: http://megui.tmebi.de/test/
-[Information] Version: 1.0.2847.0
-[Information] Date: 08-01-2019
-[Information] Interface: 3
-[Information] AviSynth Wrapper
-[Information] AviSynth Status: ignored as portable build is forced
--[Information] [2/20/2021 4:20:03 PM] No package requires an update
-[Information] File Version: 3.5
-[Information] File Date: 02-04-2020
-[Information] File Name: AviSynth+ 3.5 (r3106, 3.5, x86_64)
-[Information] File Path: e:\tools\megui\avisynth.dll
-[Information] AviSynth Version: AviSynth+ 3.5 (r3106, 3.5, x86_64)
-[Information] AviSynth+: true
-[Information] AviSynth MT: true
-[Information] AviSynth Status: active
-[Information] AviSynth portable
--[Information] AviSynth Information
-[Information] Log for job2 (audio, 00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz.flac -> 00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz.m4a)
--[Information] [2/20/2021 4:20:56 PM] Started handling job
--[Information] [2/20/2021 4:20:56 PM] Preprocessing
--[Information] [2/20/2021 4:20:56 PM] MediaInfo
---[Information] File: C:\Temp\Jackie Chan Rush Hour 3 Disque 1 Le Film\00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz.flac
-[Information] Format: FLAC
-[Information] FileSize: 840391808
-[Information] PlayTime: 01:30:48.032
---[Information] General
-[Information] FormatInfo: Free Lossless Audio Codec
-[Information] SamplingRate: 48000
-[Information] SamplingRateString: 48.0 kHz
-[Information] Channels: 2
-[Information] ChannelsString: 2 channels
-[Information] ChannelPositionsString2: 2/0/0
-[Information] BitRateMode: VBR
-[Information] [2/20/2021 4:20:57 PM] The language information is not available for this track. The default MeGUI language has been selected.
---[Information] Audio
--[Information] [2/20/2021 4:20:57 PM] Trying to open the file with LWLibavAudioSource()
Chouonsoku is offline   Reply With Quote
Old 21st February 2021, 01:59   #6970  |  Link
kedautinh12
Can you try old ver 2.70?
http://megui.tmebi.de/test/qaac-2.70-64.7z
Old 21st February 2021, 19:27   #6971  |  Link
tebasuna51
tebasuna51's Avatar
@Chouonsoku
But the problem seems related with L-SMASHWorks 20201212, not with QAAC:
Work fine for me. Running latest MeGUI 2924 x64, Windows 10 Build 1607, L-SMASHWorks 20201212, QAAC 2.71,AviSynth+ 3.5 (r3106, 3.5, x86_64).
--[Information] [21/02/2021 19:11:20] Trying to open the file with LWLibavAudioSource()
--[Information] [21/02/2021 19:11:22] Successfully opened the file with LWLibavAudioSource()
---[Information] [21/02/2021 19:11:26] qaac 2.71, CoreAudioToolbox 7.10.9.0
--[Information] [21/02/2021 19:11:28] Job completed
I don't have the latest Windows version.
tebasuna51 is online now   Reply With Quote
Old 1st March 2021, 19:34   #6972  |  Link
Chouonsoku
No change, as tebasuna51 says, it's failing at the LWLibavAudioSource part so it's not even running qaac.
@Chouonsoku
Are you using a portable install or no? That's the only other thing I can think of. I deleted the entire MeGUI folder, downloaded a fresh copy, updated everything and get the crash. LSMASH works fine with the files that fail in MeGUI in my standard AVS+ install. I tried running MeGUI as Admin in case that was it but no dice.
Old 2nd March 2021, 00:44   #6973  |  Link
tebasuna51
tebasuna51's Avatar
Nope, I have installed AviSynth+ 3.5 (r3106, 3.5, x86_64), the AviSynth.dll in my C:\Windows\System32 and in C:\Portable\MeGUI64\tools\avs is the same.
What is the version you have installed?
Old 2nd March 2021, 23:37   #6974  |  Link
Chouonsoku
AviSynth+ 3.6.2 (r3347, master, x86_64) is my installed AVS+.
By portable install I meant if your MeGUI was portable, but maybe it's only portable now. I just remember it used to have an installer.
Edit: lol, you gave me an idea to try copying my system32 avisynth.dll and devil.dll to my MeGUI avs folder to replace the one MeGUI updates to and now LSMASH works. :O So I guess maybe there's somehow a conflict with my portable MeGUI install trying to use my Program Files plugin folder or something? idk, never would have guessed this as the fix since I figured my MeGUI was separated from my main installs of AVS+. My log now complains about AviSynth but the audio encode completes successfully.
[Error] Log
-[Error] Versions
---[Information] Operating System: Windows 10 Pro 2004 x64 (10.0.19041.804)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.8 (4.8.04084)
---[Information] Redistributables
----[Information] Microsoft Visual C++ 2010 x64: 10.0.40219
----[Information] Microsoft Visual C++ 2010 x86: 10.0.40219
----[Information] Microsoft Visual C++ 2012 x64: 11.0.61030
----[Information] Microsoft Visual C++ 2013 x64: 12.0.40660
----[Information] Microsoft Visual C++ 2013 x86: 12.0.40660
----[Information] Microsoft Visual C++ 2015-2019 x64: 14.23.27820
----[Information] Microsoft Visual C++ 2015-2019 x86: 14.27.29016
---[Information] DPI: 100% (96/96)
---[Information] Monitor 1
----[Information] Resolution: 2560x1440
----[Information] Primary Screen: True
---[Information] Monitor 2
----[Information] Resolution: 3840x2160
----[Information] Primary Screen: False
---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
---[Information] Haali DSS2: (14-04-2013)
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
---[Information] MediaInfo: 18.05.0.0 (08-05-2018)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Error] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2847.0
----[Information] Date: 06-05-2018
----[Information] Interface: 3
----[Information] AviSynth Status: ignored as portable build is forced
---[Error] AviSynth portable
----[Information] File Version: 3.6.2
----[Information] File Date: 18-12-2020
----[Information] File Name: AviSynth+ 3.6.2 (r3347, master, i386)
----[Information] File Path: e:\tools\megui\avisynth.dll
----[Error] AviSynth Status: inactive - portable AviSynth build cannot be used. The loaded DLL is: c:\windows\system32\avisynth.dll
---[Error] AviSynth: not found
--[Information] [3/2/2021 4:38:25 PM] Connected to server: http://megui.org/auto/
--[Information] [3/2/2021 4:38:25 PM] No package requires an update
-[Information] Log for job1 (audio, 00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz.dts -> 00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz_new.m4a)
--[Information] [3/2/2021 4:38:28 PM] Started handling job
--[Information] [3/2/2021 4:38:28 PM] Preprocessing
--[Information] [3/2/2021 4:38:28 PM] MediaInfo
---[Information] File: C:\Temp\Jackie Chan Rush Hour 3 Disque 1 Le Film\00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz.dts
----[Information] Format: DTS
----[Information] FileSize: 173656020
----[Information] FormatInfo: Digital Theater Systems
----[Information] SamplingRate: 48000
----[Information] SamplingRateString: 48.0 kHz
----[Information] Channels: 2
----[Information] ChannelsString: 2 channels
----[Information] ChannelPositionsString2: 2/0/0.0
----[Information] BitRateMode: CBR
----[Information] [3/2/2021 4:38:29 PM] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [3/2/2021 4:38:29 PM] Trying to open the file with LWLibavAudioSource()
--[Information] [3/2/2021 4:38:33 PM] Successfully opened the file with LWLibavAudioSource()
--[Information] [3/2/2021 4:38:35 PM] AviSynth script
---[NoImage] LoadPlugin("E:\Tools\MeGUI\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavAudioSource("C:\Temp\Jackie Chan Rush Hour 3 Disque 1 Le Film\00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz.dts")
---[NoImage] # detected channels: 2
---[NoImage] # detected channel positions: 2/0/0.0
---[NoImage] return last
--[Information] [3/2/2021 4:38:35 PM] Command line used: --ignorelength --threading -V 82 --no-delay - -o "{0}"
--[Information] [3/2/2021 4:38:35 PM] AviSynth script environment opened
--[Information] [3/2/2021 4:38:37 PM] Script loaded
--[Information] [3/2/2021 4:38:37 PM] Output Decoder
---[Information] [3/2/2021 4:38:37 PM] Channels: 2
---[Information] [3/2/2021 4:38:37 PM] Bits per sample: 32
---[Information] [3/2/2021 4:38:37 PM] Sample rate: 48000
--[Information] [3/2/2021 4:38:37 PM] Job command line: E:\Tools\MeGUI\tools\qaac\qaac.exe --ignorelength --threading -V 82 --no-delay - -o "C:\Temp\Jackie Chan Rush Hour 3 Disque 1 Le Film\00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz_new.m4a"
--[Information] [3/2/2021 4:38:37 PM] Process started
--[Information] [3/2/2021 4:38:37 PM] Standard output stream
--[Information] [3/2/2021 4:38:37 PM] Standard error stream
---[Information] [3/2/2021 4:38:37 PM] qaac 2.71, CoreAudioToolbox 7.10.9.0
---[Information] [3/2/2021 4:38:37 PM] 00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz_new.m4a
---[Information] [3/2/2021 4:38:37 PM] AAC-LC Encoder, TVBR q82, Quality 96
---[Information] [3/2/2021 4:39:37 PM] 261505536/-1 samples processed in 0:59.795
---[Information] [3/2/2021 4:39:37 PM] Overall bitrate: 116.288kbps
---[Information] [3/2/2021 4:39:37 PM] Optimizing...66%
---[Information] [3/2/2021 4:39:37 PM] Optimizing...done
--[Information] [3/2/2021 4:39:37 PM] MediaInfo
---[Information] File: C:\Temp\Jackie Chan Rush Hour 3 Disque 1 Le Film\00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz_new.m4a
----[Information] Format: MPEG-4
----[Information] FileSize: 80259611
----[Information] PlayTime: 01:30:48.043
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] CodecID: mp4a-40-2
----[Information] Format: AAC
----[Information] FormatInfo: Advanced Audio Codec
----[Information] FormatProfile: LC
----[Information] BitRateMode: VBR
----[Information] [3/2/2021 4:39:37 PM] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [3/2/2021 4:39:37 PM] Postprocessing
---[Information] [3/2/2021 4:39:37 PM] Deleting intermediate files
----[Information] [3/2/2021 4:39:37 PM] Successfully deleted C:\Temp\Jackie Chan Rush Hour 3 Disque 1 Le Film\00003 - 4 - DTS, English, 2.0 channels, 255kbps, 48kHz.dts.lwi
--[Information] [3/2/2021 4:39:37 PM] Job completed
Old 3rd March 2021, 01:10   #6975  |  Link
tebasuna51
tebasuna51's Avatar
Sorry I can't help you with AviSynth+ 3.6.
I don't know if MeGUI can work with that version.
Old 3rd March 2021, 01:23   #6976  |  Link
Chouonsoku
Well, it's working now because that's the version in my system32 and MeGUI tools folder so idk what's going on.
Old 3rd March 2021, 04:54   #6977  |  Link
hello_hello
Assuming 64 bit MeGUI works the same way as the 32 bit version, there's a setting in options "Always use the included Avisynth" to check/uncheck according to whether you want MeGUI to use the installed Avisynth or it's portable version. Looking at your log file, the portable Avisynth is failing to work now, so the installed Avisynth is used instead, whereas previously the portable version worked but of course it'd crash.
Old 3rd March 2021, 08:44   #6978  |  Link
LigH
LigH's Avatar
Some of the most recent AviSynth+ compatible plugins (especially by pinterf and cooperating developers) may require a more recent AviSynth+ base DLL due to updated programming interfaces, I guess...
Old 3rd March 2021, 13:12   #6979  |  Link
hello_hello
You're probably right, but....
From Chouonsoku's latest log file.
The version of Avisynth+ Chouonsoku said he copied from his system32 folder, has MeGUI declared it to be 32 bit? I'm still using XP so I'm not very 64 bit savvy. Unless maybe MeGUI is confused, or maybe it's me.
And another question....
I know QAAC can be downloaded in two flavours. qaac.exe and qaac64.exe. I couldn't find an answer via google but I did find a few log files showing 64 bit MeGUI creating a command line to encode with qaac64.exe, and others such as the log file above where it's qaac.exe. Any idea how that works? I'm just curious.
Old 6th March 2021, 17:47   #6980  |  Link
DS2902
Every time it starts, it tries to download the update and cannot, always an error.
[Error] Log
--[Information] Update Check: custom update server
----[Information] Microsoft Visual C++ 2005 x64: 8.0.61000
----[Information] Microsoft Visual C++ 2005 x86: 8.0.61001
----[Information] Microsoft Visual C++ 2012 x86: 11.0.61030
----[Information] Microsoft Visual C++ 2013 x64: 12.0.40664
----[Information] Microsoft Visual C++ 2013 x86: 12.0.40664
----[Information] Microsoft Visual C++ 2015-2019 x64: 14.27.29016
---[Information] DPI: 150% (144/144)
----[Information] Resolution: 1920x1536
----[Information] File Version: 3.5
----[Information] File Date: 02-04-2020
----[Information] File Name: AviSynth+ 3.5 (r3106, 3.5, x86_64)
----[Information] File Path: c:\windows\system32\avisynth.dll
----[Information] AviSynth Version: AviSynth+ 3.5 (r3106, 3.5, x86_64)
----[Information] AviSynth+: true
----[Information] AviSynth MT: true
-[Error] Update detection
--[Information] [06.03.2021 19:38:53] Using cached update config and server: http://megui.tmebi.de/test/?c=m;o=d/
--[Information] [06.03.2021 19:38:53] There is 1 package which can be updated: FFMS
--[Information] [06.03.2021 19:38:58] There is 1 package which can be updated: FFMS
--[Information] [06.03.2021 19:39:00] 1/1 - updating package FFMS
--[Error] [06.03.2021 19:39:02] Failed to download package FFMS: File cannot be found on the server.
--[Information] [06.03.2021 19:39:03] Connected to server: http://megui.tmebi.de/test/?c=m;o=d/
--[Error] [06.03.2021 19:39:04] Packages which have not been successfully updated: 1
DS2902 is offline   Reply With Quote
