Old 8th June 2018, 22:04   #6161  |  Link
Zathor
Originally Posted by VoodooFX View Post
Yes, here is log (after oneclick error I aborted audio job):
https://pastebin.com/gNijDJmS
btw I get same error " 4 is not valid for 'index' " when I edit x265 preset in oneclick and try to save it(clicking around presets error sometimes disappears, still I dunno why or when).
As you are able to reproduce it:
http://megui.org/megui_debug.7z
extract the content of eitehr the 32 or the 64 folder (depending on your MeGUI build), reprocude the error, close MeGUI & upload the log.
Zathor is offline   Reply With Quote
Old 9th June 2018, 17:15   #6162  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
Here you go:
https://pastebin.com/ixWEYDP1
VoodooFX is offline   Reply With Quote
Old 10th June 2018, 21:06   #6163  |  Link
Zathor
LouieChuckyMerry / hello_hello: Could you please try 2860? It should now properly detect that the included portable AviSynth is not used. Please try also if the MeGUI setting "log debug information" changes a thing (with the next restart).
Thanks, will have a look in the next days.
Old 11th June 2018, 14:20   #6164  |  Link
Statick
request:
I'd really like a way of accessing the input filename from within the OneClick encoder AVISynth script
specifically I want to access the .d2v file generated, which is always named after the input filename, and reference this in the script. something like %input_filename% would do the job, like this:
tfm(d2v="%input_filename%.d2v")
I'm sure there are other paramters that would be useful if exposed this way, but this is the only one I'm after!
Currently I have to edit the AVISynth profile for every single video I encode, which for several hundred videos is extremely long-winded and error prone
Statick is offline   Reply With Quote
Old 11th June 2018, 14:23   #6165  |  Link
hello_hello
Thanks for the effort!
Now you've made me feel bad for being the bearer of bad news.
[Warning] AviSynth Information
-[Information] AviSynth Wrapper
--[Information] Version: 1.0.2847.0
--[Information] Date: 06-05-2018
--[Information] Interface: 3
--[Information] File Version: 2.6.0.6
--[Information] File Date: 31-03-2015
--[Information] File Name: Avisynth 2.6
--[Information] File Path: c:\windows\system32\avisynth.dll
--[Information] AviSynth Version: AviSynth 2.60, build:Mar 31 2015 [16:38:54]
--[Information] AviSynth+: false
--[Information] AviSynth MT: false
--[Information] AviSynth Status: active
-[Warning] AviSynth portable
--[Information] File Version: 0.1
--[Information] File Date: 28-03-2018
--[Information] File Name: AviSynth+ 0.1 (r2664, MT, i386)
--[Information] File Path: c:\program files\megui\avisynth.dll
--[Warning] AviSynth Status: inactive - portable AviSynth build cannot be used. The loaded DLL is: c:\windows\system32\avisynth.dll
PS It makes no difference if the "log debug info" option is enabled/disabled.
Old 11th June 2018, 15:08   #6166  |  Link
LigH
LigH's Avatar
is probably protected by the UAC: Windows doesn't allow manipulation of files in this directory branch without Administrator access rights.
That's why we keep recommending not to install MeGUI there, over and over ... or you would have to disable the UAC, which is a security risk.
New German Gleitz board
Old 11th June 2018, 15:30   #6167  |  Link
Statick
I have "run this program as administrator" selected and it seems to solve all such problems, albeit that I have to click the "yes" prompt every time I open the program. I could be missing something though.
Old 12th June 2018, 01:57   #6168  |  Link
Zathor,
I have been experiencing some problems with both stable and developer for some months (WXP32SP3).
On checking Changelog, see this
- Windows Vista and older is not supported
The only problem I'm having is using MeGUI_AutoEncode_Batcher, which uses AutoIt code to add avs scripts to the Auto Encode queue.
Problem arises when Preview Window is opened (after avs script load) and the batcher clicks close Button (little x close alias ALT/F4).
Seems that the problem arises due to close button being clicked before MeGUI is ready, ie MeGUI is still doing its multiple scanning
of Avs script and has not as yet presented the clip graphic in the preview window, when close button is clicked it crashes MeGUI.
(the Batcher is un-affected).
I have been putting off posting this problem report, in hope of it disappearing, but update earlier today and then saw changelog.
I've tried adding in a 10 second delay after Preview Window appears, and that fixes my problem, and so I have to assume
that problem could also affect systems after VISTA, if user clicks ALT/F4 close button before MeGUI has finished whatever it does
during its multiple script scanning period.
Adding avs scripts by hand is no problem for me with current versions, but I like to use the batcher.
I was not at all aware until a short while ago (checking Changelog) that XP is no longer supported (in theory),
What is the latest version MeGUI that is supported for XP (I see no such dropping of support note in changelog).
Developer MeGUI 2860, stable 2836.
Thanks in advance.
EDIT: Batcher:- https://forum.doom9.org/showthread.php?t=163343
EDIT:
From current Changelog of both Stable and Development.
Known Problems:
from Full Changelog
2077 [Progress Window] lower also I/O and memory priority when priority below normal (requires Windows Vista or newer). Feature request #3468249
Is this the first one that does NOT support XP ?
EDIT: Found this on sourceforge
Known Problems: - Windows XP and older is not supported [2624]
So maybe 2525 last supported stable (despite me not knowing that neither development nor stable not supported since March 2015).
Old 12th June 2018, 05:48   #6169  |  Link
tuanden0
mkvmerge update version 24.0.0
tuanden0 is offline   Reply With Quote
Old 12th June 2018, 15:23   #6170  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
Version 2860 seems to properly detect that the included AviSynth is not used; ticking "Log debug information" does change something: [Information] AviSynth+: false in the log became [Information] AviSynth+: true. However, now I receive an access error for loading ConvertStack.dll, and if I # that line of my script out I receive an access error for the next line, and so on. Here's the script:
# Set DAR in encoder to 16 : 9. The following line is for automatic signalling
global MeGUI_darx = 16
global MeGUI_dary = 9
SetMemoryMax(1024)
LoadPlugin("F:\[0]StandAloneApps\MeGUI-2500(core)2443(data)0.3.5(libs)[Portable]\Tools\Avs\plugins\ConvertStacked.dll")
LoadPlugin("F:\[0]StandAloneApps\MeGUI-2500(core)2443(data)0.3.5(libs)[Portable]\tools\lsmash\LSMASHSource.dll")
LWLibavVideoSource("D:\Temp\[0000]ReEncTemp\[1080p]AlohaBobbyAndRose[S]{1975}[1080p]\OriginalVideo,OriginalAudio.mkv")
SMDegrain(TR=3,ThSAD=700,RefineMotion=True,Plane=0,Chroma=False,Lsb=True,Lsb_Out=True)
F=DitherPost(Mode=-1)
S=F.FastLineDarkenMod()
D=MT_MakeDiff(S,F).Dither_Convert_8_To_16()
Dither_Add16(Last,D,Dif=True,U=2,V=2)
GradFun3(Radius=16,Lsb_In=True,Lsb=True)
Trim(11111,11666)
Dither_Out()
ConvertFromStacked(Bits=16)
Prefetch(7)
My system is Win 7 64 bit, UAC has been disabled since I opened the package, and portable MeGUI is on a RAMDisk, F:\.
LouieChuckyMerry is offline   Reply With Quote
Old 12th June 2018, 18:08   #6171  |  Link
LigH
LigH's Avatar
Sounds like a misinterpretation of the confusingly bracketed path names... is there any reason to interpret them?
I would guess if you simplified the path and file names as much as possible, there may be no issue?
Old 12th June 2018, 18:11   #6172  |  Link
Groucho2004
Misinterpretation? All the characters in the path names are valid.
Groucho's Avisynth Stuff
Old 12th June 2018, 19:18   #6173  |  Link
LouieChuckyMerry
I've been using those path names with SEt's AviSynth MT for some years without issue. Would AviSynth+ be different that way?
Old 12th June 2018, 19:25   #6174  |  Link
hello_hello
Fortunately, I'm in a UAC free zone (still running XP).
How do people put up with the crap? I plugged a USB hard drive into my ex's laptop the other day, to copy some stuff to the laptop drive, and UAC had to bother me to ask permission to access it. More than once, I think.
Old 12th June 2018, 19:45   #6175  |  Link
videoh
Useful n00b
It's easy to turn off completely if you don't like it.
Old 12th June 2018, 20:20   #6176  |  Link
LigH
LigH's Avatar
So, do you see any better reason for
or maybe I misunderstood the meaning of the term "access error"?
Old 12th June 2018, 20:47   #6177  |  Link
Groucho2004
That's one possibility.
Old 12th June 2018, 21:13   #6178  |  Link
Groucho2004
I'm curious about the "portable mode" in Megui.
I suppose this option will load the included avisynth.dll instead of the DLL that was installed in System32/SysWow64.
What about the plugins that were installed with Avisynth which are referenced in the registry? The only way I can see to avoid these being used is to have an explicit "LoadPlugin()" call for each plugin used in the script, right?
Old 13th June 2018, 03:49   #6179  |  Link
hello_hello
That's the theory, although it still isn't working correctly for me.
Would it be preferable for MeGUI not to use auto-loading plugins? If it didn't, when Avisynth is installed other programs could open scripts that rely on auto-loading plugins but they'd fail to open in MeGUI.
Old 13th June 2018, 07:40   #6180  |  Link
LigH
LigH's Avatar
I believe (strongly, like I read it before) that MeGUI redirects the auto-load directory during its activity. AviSynth may have an API to change the location read from the registry after the initialization of its interface.
