6th January 2006, 00:59 | #301 | Link | |
retired developer
Detritus Software |
6th January 2006, 01:39 | #302 | Link |
@riggits
I forgot to update, it's compatible so you can use it anyway, you can disable the warning. @Sirber Thanks, I'll take a look at this tool.
6th January 2006, 11:53 | #303 | Link |
Hi there,
this is a great tool Stax , thanks for your hardwork.I recently started using it and I have a problem , I am trying to encode some anime raws from Japan at 120 fps with your tool to make x264 mkv files.The problem is I couldnt find a way to reduce the fps to 23.976 ; in which my ssa subtitle is.I really don't know anything much about avisynth but tried this : Decimate(5).Decimate(4).Decimate(2).Decimate(3) which gives me : 23.98 How can I achive 23.976 fps ? Thanks.
The Real King |
7th January 2006, 00:53 | #304 | Link | |
0.9.2.0 (2006-01-07)
You can try post to the AviSynth forum.
7th January 2006, 04:01 | #305 | Link |
TeMa=) team member
Location: Universe, Galaxy, Solar System, Earth, Russia, Moscow
Here's high-quality audio profile, "Nero 5.1ch HE-AAC 192 KBit/s"
Output type: AAC-HE Bitrate: 192 Command Lines: "%application:BeSweet%" -core( -input "%input%" -output "%output%" ) -azid( -c normal -L -3db ) -ota( -d %delay% -hybridgain ) -bsn( -6chnew -aacprofile_he -vbr_normal --codecquality_high )
Without effort, you can't even pull a fish out of the pond. Without a pond you can't pull it out even with effort. |
7th January 2006, 04:10 | #306 | Link |
@LRN
Thanks, I'll add it.
7th January 2006, 09:39 | #307 | Link |
I'm very impressed. I love the dialogs. so many apps are lacking clarification on options. I like that it downloads those filters too, they can be tricky to find! Is it necessary that I have all the missing apps installed before it lets me continue? I just played with it briefly!
7th January 2006, 13:15 | #308 | Link |
TeMa=) team member
You should install only required apps (i.e. if you encoding with x264, you don't need DivX, XviD etc)
7th January 2006, 14:25 | #310 | Link | |
7th January 2006, 15:06 | #312 | Link |
I've added it already so it will be available next release, you can disable the warning and use it anyway meanwhile.
7th January 2006, 15:29 | #313 | Link |
Thanks for your god job, maybe you could help me again, i want to rip a 21 minutes anime, so i have put in staxrip a size of 178 mo but after the compressability check he put a size of 360 mo and a 2168 bitrate ! How can i fix that ? i want a 178mo video in 640x480 ....
7th January 2006, 16:18 | #314 | Link |
In StaxRip most settings are located where they logically belong to, comp check is a encoder feature and thus filesize adjustment after the comp check options are in the encoder options.
May I ask why you want exactly 178 MB? Hitting a filesize means making compromises with image size and bitrate and that mean making compromises with quality, XviD quality mode at quant 3 might be a good alternative.
7th January 2006, 17:03 | #316 | Link |
TeMa=) team member
After compressibility check StaxRip establishes a link between video bitrate and resolution (video bitrate and filesize is already linked as "filesize = VideoBitrate*MovieLength + AudioBitrate*MovieLength"), showing this as "quality". Quality 100% means, what you won't loose anything (except a small unavoidable quality loss due to recompression). Your goal is to reach quality nearest to 100% (90+ or 110-), because quality more than 100 is not better than 100. If you need EXACTLY 178 Mb filesize, then you can change resolution. If you need one PARTICULAR, exact resolution, then you should change video bitrate (and thus filesize).
I'm DVD-backuper, so i'm restricted to 700 Mb,1400 Mb and 2100 Mb filesizes. Because of it, i can only change resolution, not bitrate. In your case, you should set resolution to 640, and then decrease (or increase) bitrate until quality reaches 100% P.S. This is applicable for x264. I did not used XviD in StaxRip, maybe for XviD everything is different.
Without effort, you can't even pull a fish out of the pond. Without a pond you can't pull it out even with effort. Last edited by LRN; 7th January 2006 at 17:07. |
7th January 2006, 17:22 | #317 | Link | |
7th January 2006, 18:12 | #320 | Link | ||
edit: OK, this is my default answer and pretty stupid in that case, sorry but I don't know a possible reason. Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 7th January 2006 at 18:15. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
