Old 5th April 2012, 12:45   #1  |  Link
vesolovski
DirectShowSource - short freezes
Dear AviSynth users,
I am having following problem with DirectShowSource:
Source clip is smooth, but after rendering it becomes strange - video freezes at some point (or points) (not working), but frame counter still goes on (working fine).
I don't know if this is the problem of AviSynth or maybe ffdshow. If so I still do not know how to fix this. Please provide me with some hints if you can.
I am attaching 3 files to help you visualize problem:
- script.avs
- source.avi (file being read by DirectShowSource)
- render.avi (problematic file received after rendering script.avs)
http://bit.ly/Hk4Sq7
vesolovski is offline   Reply With Quote
Old 6th April 2012, 10:22   #2  |  Link
Bloax
The speed of stupid
Bloax's Avatar
My best guess would be that DirectShowSource is a really bad pick for a source filter that's stupid and is totally OK with skipping frames.
Bloax is offline   Reply With Quote
Old 6th April 2012, 12:36   #3  |  Link
vesolovski
Thank Bloax for your answer. However if I understand DirectShowSource well, I think it grabs frames from ffdshow "on the fly". If the problem was only with skipping frames, this should not be noticeable. My video freezes for nontrivial period of time (say 0,7 s) - it means DirectShowSource would have to have skipped approximatelly 0,7*29.97 = 21 following frames. I cannot imagine DirectShowSource is that bad. I think it rather skips single (separate) frames.
Summarizing, I would say the problem would or could be with something else.
Old 6th April 2012, 13:07   #4  |  Link
Bloax
The speed of stupid
Bloax's Avatar
Tried FFMpegSource?
Old 6th April 2012, 14:32   #5  |  Link
vesolovski
Yeah, I have.
But it (AviSource as well) has a limit of processed clips in one script file (approximatelly 15 for HD 1080p clips). DirectShowSource does not have such limit (related to memory limit of computer), but it is buggy in my case (problem described above).
Old 8th April 2012, 01:54   #6  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Apparently I managed to make DSS behave "as it should"
fps=50, convertfps=true, framecount=265
and then:
AssumeFPS(29.97)
H.T.H.
Midzuki is offline   Reply With Quote
Old 8th April 2012, 02:47   #7  |  Link
vesolovski
Hello Midzuki,
I cannot check it now, but I will be able to do it in few days (trip). I hope it will work also for me. If it will, you are a genius )
Regards,
K.W.
Old 8th April 2012, 02:59   #8  |  Link
vesolovski
I checked your solution on different computer. Works perfectly. Ever if I bypass framecount=265 (is it useful?)
As I said before - you are a genius
Last edited by vesolovski; 10th April 2012 at 10:12. Reason: No relation with subject
Old 8th April 2012, 03:11   #9  |  Link
vesolovski
One more thing,
I checked this with HD1080 avi source file and rendered avs becomes so very slow. Sound goes at normal speed, but video much much slower
Old 8th April 2012, 04:37   #10  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Far from that In fact, I have understood less than 5% of the whole Avisynth thing so far ( even though I'm a semi-regular AVS user since 2007 )
One more thing,
Need More Info
directshowsource, freezes, problem
