Old 9th September 2010, 09:46   #1  |  Link
jackdigital
Scenarist HDMV 4.2 problem with pop up menus
Hello,
I had a made a blu ray with pop up menus in all my playlists, and they worked fine when first testing. But after i changed the m2v of some of those playlists, they did'nt work there anymore. I have tried everything i can come up with to get them working again, creating new clips, playlists, rebuilding the menus, etc... But I cannot get them back.
Seems that altering a playlist screws up the pop up menu, does anyone know how i can "reset" or fix this?
Thanks,
Jack
jackdigital is offline   Reply With Quote
menus, pop, popup, problem
