1st July 2014, 21:27 | #7861 | Link |
Flanker-B, I've seen it a lot now. I agree with you, that appears to be the cause. I haven't seen BD RB tripped up by this yet.
It DOES make stripping a bit easier better though. You should be able to remove playlists (and unique m2ts files) that you don't want without accidentally removing m2ts files in the playlists you do want. (I still need to test this more to make sure.) Simple example: Playlist1: English Opening Credits -> chunk of movie -> English Closing Credits Playlist2: French Opening Credits -> (same) chunk of movie -> French Closing Credits. BD RB links these so you can't strip playlist2 without stripping all of playlist1 as well. multiavchd seems to make a second copy of the 'chunk of movie' that is shared by both playlists. As a result you SHOULD be able to blank playlist2 without effect to playlist1. If you don't strip one of the playlists though the output disc will be larger than the input. |
2nd July 2014, 14:07 | #7862 | Link |
Yeah, I know that blanking is the only option for now in multiavchd for these kind of movies.
PS: That other problem I'm having (the truehd issue), I've found the cause (but not a solution): tsmuxer, even the latest version, has no support for truehd audio tracks if they don't have ac3 core integrated. For now there's no proper solution for that issue, unles you want to use some other software to extract that truehd audio track manually (like eac3to, or mkvcleaver - requires mkvmerge) and then converting it to ac3 or dts (using eac3to - dts requires surcode dts audio encoder which isn't free) or dts-hd (using dts-hd master audio suite - not free). |
3rd July 2014, 01:35 | #7864 | Link |
TrueHD does not have a core like DTS does but it does, usually, contain an AC3 version of the audio interleaved into the TrueHD track as a backup for players that cannot play TrueHD. This AC3 track is not required by the TrueHD track at all and if it is missing eac3to will not be able to extract it. I wonder how one would add this AC3. Could you take the TrueHD track, encode it to AC3, and interleave it with the TrueHD?
3rd July 2014, 07:50 | #7865 | Link | |
Not much of a command-liner myself, I use UsEac3To to do that and you can set bitrate if you want, even 640 kbps. Cheers |
3rd July 2014, 07:54 | #7866 | Link | |
While it's possible to mux only THD into a file (M2TS), if this is supposed to be a BD, then the player would probably refuse to play it, for being non-standard. However, it is possible that some players have more "relaxed" checks and could play a THD track without an AC-3 interleaved.
Born in the USB (not USA) |
3rd July 2014, 08:12 | #7867 | Link | |
But if your (pre-)amp isn't able to decode TrueHD and needs SP/DIF AC3 or analogue inputs, it's also necessary that the BD player can decode TrueHD and DA-convert into multi-channel analogue outputs, or "downconvert" the TrueHD-only track into AC3. I know there are BD players that can't do any or both. |
5th July 2014, 09:50 | #7871 | Link |
Latest tsMuxer can mux this .thd+ac3 file into m2ts or BD disc without a problem.
With mkv it's different: this container can't have both the TrueHD stream with the embedded AC3 in 1 single stream. Should you want both audio in a mkv container you need 2 separate streams for muxing. One AC3-only (lossy) and one TrueHD-only (lossless). You can add both files in mkvmerge (with your video and subs) and output as mkv. If you would then take a look to the output file, MediaInfo will state that there are 2 audiotracks: 1 AC3 and 1 TrueHD. To be complete with DTS-MA it's different; the DTS-MA/core track can - must, actually - be muxed as 1 track (file) into mkv, just as you would with BD. MediaInfo says then the file has one audiotrack: DTS-MA/core (lossy & lossless). Dolby TrueHD+AC3 and DTS-MA/core audio are different in their build-ups. As Asmodian said earlier, the Dolby audio contains an independent TrueHD (lossless) stream and is interleaved with an independent AC3 (lossy) stream. DTS-MA/core audio contains an independent (dvd-like), lossy DTS stream and the (dependent) additional audio-data in the second stream. The 2 of them combined makes the lossless DTS-MA audio. So, actually, one would not be able to mux DTS-MA-only (as we know it for BD and mkv anyways) separately; it needs the data in the lossy DTS track. I did read somewhere else that independent DTS-MA-only-streams do exist (so, without the lossy DTS), but with what extension and to what use I can't remember. This post would be incomplete without me to say that, should one have supporting playback/audio equipment, it's a good alternative to recompress TrueHD or DTS-MA into flac. It takes much less space and because both input and output are lossless, no audio-information will be lost (maybe dialog normalisation, but this stands besides intrinsic audio-quality) Cheers Last edited by von Suppé; 5th July 2014 at 10:08. |
5th July 2014, 10:39 | #7872 | Link |
Thanks von Suppé for all these explanations.
Last thing : is there a trick to mux a True HD track with an ac3 track (both having exactly the same duration) into a single .thd+ac3 file or this interleaved file can only be created from a single True HD track ? It's just by curiosity, I understand that it's not very useful because if one really need to have another ac3 track, it can be muxed into m2ts in addition to the .thd+ac3. The only utility I see would be to avoid to increase the total bitrate if one need an ac3 track with a different mix than the True HD track. Last edited by Music Fan; 5th July 2014 at 10:49. |
6th July 2014, 01:14 | #7873 | Link |
Interesting question, Music Fan, if I understand it right. Makes me curious also
I can't tell, to be honest. As eac3to is somehow able to interleave its self-created AC3 stream with its TrueHD-only source, one would think it may be possible too with a TrueHD-only stream and any AC3 stream, for that matter. If it's possible I think it has to be done with command-line, with which I am a noob. Or maybe with another, more comprehensive front-end than UsEac3to. Considering your exact duration remark, I do wonder if the two streams have to be so. If - within a .truehd+ac3 track - the TrueHD stream has a higher samplefrequency than the embedded AC3 stream, I can imagine these two tracks not being of exactly the same duration (pure absolutely calculated). I think bitdepth differences should be no problem also then. It can be fun to experiment a bit with this and see what happens. But maybe it's easier to not re-invent a wheel and probably the cli die-hard guys in the eac3to thread in this forum can tell more about it. Cheers |
6th July 2014, 10:30 | #7874 | Link |
I guess it is possible (but is maybe not available yet but could perhaps be added), because just after having created the ac3 track from the True HD, thus just before interleaving them, there are 2 tracks. And I don't see the difference between taking this ac3 stream (existing as a temporary file) and another (already existing) for the interleaving operation.
6th July 2014, 11:48 | #7875 | Link | |
BTW UsEac3to work like a command line without worry about paths to eac3to or input/output files.
31st July 2014, 13:41 | #7877 | Link |
I am stuck with theatrical and extended version of "Tora! Tora! Tora!" movie to which I want to add french.sup subs to the extended version only.
MPLS files 00312 and 00335 are related to theatrical version and linked to 00303,00304,00305,00306,00307 and 00308.M2TS files. For Extended version, mpls files 00313 and 00336 are linked to those M2TS files: 00304, 00306, 00308, 00309, 00310 and 00311. Whatever mpls I've choosen to add subs to, gave me a 69 GB output which is close to an additional 30 GB for the BD. I've spent many hours with no way to resolve the issue. I've read many posts, made search but have not seen anything that could bring suggestions. How can it be authored ? Only adding subs to one version should be easy ? Help me please!
R M |
1st August 2014, 11:37 | #7878 | Link | |
Thanks for your help
R M |
