Old 4th September 2024, 06:08   #31981  |  Link
SquallMX
Special SeeD
Unfortunately that's what is sounds like -- either that or just a badly tested release. Any other software showing issues?
Finally I found the cause of this misbehavior!
It was the option "Beta: Use Unicode UTF-8 for worldwide language support", disabling this checkbox fixed the issue after a restart.
According to my google-fu "If you check this option, Windows will use codepage 65001 (Unicode UTF-8) instead of the local codepage. The downside is that ANSI-Only programs (most older programs) will show garbage instead of accented characters." Looks like BD-Rebuilder is one of those older programs.
SquallMX is offline   Reply With Quote
Old 4th September 2024, 13:52   #31982  |  Link
jdobbs
Hmmm... I seem to remember getting a report of that error many, many years ago.
Website: www.jdobbs.net
Old 6th September 2024, 12:23   #31983  |  Link
stonesfan129
jdobbs, is there any way you can add the AMD VCE encoder into this program? I see that Intel QSV was added, and I think NVENC has always been available. I specifically would like to compress some 4K content to BD50/BD25. Thank you.
stonesfan129 is offline   Reply With Quote
Old 6th September 2024, 12:34   #31984  |  Link
jdobbs
It was added for testing in v0.62.10 (see CHANGES.TXT). You can enable it (for testing) by adding the following line to the "[Options]" area of BDREBUILDER.INI (in the same folder as BDRB.EXE):
VCE_TEST=1
Old 6th September 2024, 23:01   #31985  |  Link
Lathe
Lathe's Avatar
Originally Posted by MrVideo View Post
What the hell is 24H2? What is it. i.e., the version of Win 11?
... Annnnnnd, that's why after a very scary, almost compulsory huge screen filled prompt basically TELLING me I have to upgrade to W11, I desperately searched for what to do. For me personally, I have turned off Windows update completely in the system settings (they're not going to update W10 anyway) That was the only way I could prevent a very FORCEFUL update to W11.
Lathe is offline   Reply With Quote
Old 6th September 2024, 23:03   #31986  |  Link
Lathe
Lathe's Avatar
It was McFly coming back to warn you that this would happen...
Old 6th September 2024, 23:49   #31987  |  Link
stonesfan129
VCE_TEST=1
Thank you. This will be great for doing some test 4KBD encodes to BD50 and BD25.
Old 7th September 2024, 01:04   #31988  |  Link
jdobbs
Could it be?
Old 8th September 2024, 08:31   #31989  |  Link
Hooman
Hi, when (re-)muxing with BD-RB, the playlists’ IN_Time always defaults to 00:00:00:00. If the original IN_Time is different, we’ll see an unintended portion at the start of the clips. Can you please fix this issue?
Hooman is offline   Reply With Quote
Old 8th September 2024, 14:04   #31990  |  Link
jdobbs
Can you post the log for that encode?
Old 8th September 2024, 15:16   #31991  |  Link
Hooman
It’s not an issue with the encodes. Whenever the clip (the streams) contains a part at its start that is to be skipped according to its corresponding playlist file, BD-RB doesn't retain the (PlayItem's) IN_Time at its original value and changes it to 00:00:00:00. This could be due to the commands BD-RB sends to tsMuxer (Or the "Rebuilding BD file Structure"). The attached image shows the original structure as imported into Scenarist by a BD-Reauthor script. The black frame that reads ‘Cinerama Everywhere, RT 8:20…’ is a shot of the short part at the start of the clip that is not intended to be played back.
If I rebuild the same title (even with the FORCE_NOENCODE=1 flag?) and then import the rebuilt version into Scenarist for re-authoring, the aforementioned IN_Time is not the same as in the original MPLS. When that playlist/clip is called from the disc menu, those few frames at the start of the clip play back because the IN_Time has changed. Maybe something like BDTools can correct it in MPLS files.
PS
For this particular clip, the “IN_time” of the PlayItem and the “mark_time_stamp” of the first “PlayListMark” in the original playlist MPLS (converted by BDTools to readable JSON) is 27167041. However, in the BD-Rebuilt version, it has changed to 27000000.
    "MPLS": {
        "version_number": "0200",
        "reserved_header": [
            0
        "AppInfoPlayList": {
            "reserved01": 0,
            "PlayList_playback_type": 1,
            "UO_mask_table": {
                "menu_call_mask": 0,
                "title_search_mask": 0,
                "chapter_search_mask": 0,
                "time_search_mask": 0,
                "skip_to_next_point_mask": 0,
                "skip_back_to_previous_point_mask": 0,
                "play_FirstPlay_mask": 0,
                "stop_mask": 0,
                "pause_on_mask": 0,
                "pause_off_mask": 0,
                "still_off_mask": 0,
                "forward_play_mask": 0,
                "backward_play_mask": 0,
                "resume_mask": 0,
                "move_up_selected_button_mask": 0,
                "move_down_selected_button_mask": 0,
                "move_left_selected_button_mask": 0,
                "move_right_selected_button_mask": 0,
                "select_button_mask": 0,
                "activate_button_mask": 0,
                "select_button_and_activate_mask": 0,
                "primary_audio_stream_number_change_mask": 0,
                "reserved01": 0,
                "angle_number_change_mask": 0,
                "popup_on_mask": 0,
                "popup_off_mask": 0,
                "PG_textST_enable_disable_mask": 0,
                "PG_textST_stream_number_change_mask": 0,
                "secondary_video_enable_disable_mask": 0,
                "secondary_video_stream_number_change_mask": 0,
                "secondary_audio_enable_disable_mask": 0,
                "secondary_audio_stream_number_change_mask": 0,
                "reserved02": 0,
                "PiP_PG_textST_stream_number_change_mask": 0,
                "reserved03": 0
            "reserved02": 0,
            "PlayList_random_access_flag": 0,
            "audio_mix_app_flag": 1,
            "lossless_may_bypass_mixer_flag": 0,
            "MVC_Base_view_R_flag": 0
        "PlayList": {
            "reserved01": 0,
            "PlayItem": [
                    "Clip_Information_file_name": "00018",
                    "Clip_codec_identifier": "M2TS",
                    "ref_to_STC_id": 0,
                    "reserved01": 0,
                    "is_multi_angle": 0,
                    "connection_condition": 1,
                    "IN_time": 27167041,
                    "OUT_time": 49802154,
                    "UO_mask_table": {
                        "stop_mask": 0,
                        "pause_on_mask": 0,
                        "resume_mask": 0,
                        "reserved01": 0,
                        "popup_on_mask": 0,
                        "reserved02": 0,
                        "reserved03": 0
                    "PlayItem_random_access_flag": 0,
                    "reserved02": 0,
                    "still_mode": 0,
                    "still_time": 0,
                    "STN_table": {
                        "reserved01": 0,
                        "number_of_PiP_PG_textST_stream_entries_plus": 0,
                        "stream": [
                                "type": 1,
                                "pid": 4113,
                                "stream_coding_type": "H.264",
                                "video_format": "1080p",
                                "frame_rate": "23.976",
                                "reserved01": 0
                                "type": 1,
                                "pid": 4352,
                                "stream_coding_type": "AC-3",
                                "audio_presentation_type": "Stereo",
                                "sampling_frequency": "48 kHz",
                                "language_code": "fra"
                                "type": 2,
                                "subpath_id": 0,
                                "subclip_id": 0,
                                "pid": 5120,
                                "stream_coding_type": "IGS",
                                "language_code": "eng",
                                "reserved01": 0
            "SubPath": [
                    "reserved01": 0,
                    "SubPath_type": 3,
                    "reserved02": 0,
                    "is_repeat_SubPath": 0,
                    "reserved03": 0,
                    "SubPlayItem": [
                            "Clip_Information_file_name": "00016",
                            "ref_to_STC_id": 0,
                            "reserved01": 0,
                            "is_multi_Clip_entries": 0,
                            "sp_connection_condition": 1,
                            "SubPlayItem_IN_time": 27000000,
                            "SubPlayItem_OUT_time": 27001876,
                            "sync_PlayItem_id": 0,
                            "sync_start_PTS_of_PlayItem": 0
        "PlayListMark": [
                "reserved01": 0,
                "mark_type": 1,
                "ref_to_PlayItem_id": 0,
                "mark_time_stamp": 27167041,
                "entry_ES_PID": 65535,
                "duration": 0
                "reserved01": 0,
                "mark_type": 1,
                "mark_time_stamp": 49800277,
                "duration": 0
I believe this issue can only be resolved by a reverse conversion of the JSON file back into an MPLS playlist after BD-RB’s work.
Old 8th September 2024, 21:45   #31992  |  Link
jdobbs
There is other useful information in the log... for example, was it a full backup or a movie-only? But I guess you decided it wasn't needed and provided something I didn't ask for instead.
Old 8th September 2024, 21:58   #31993  |  Link
Hooman
Sorry, didn't realize the log was needed.
It was a full backup.
Here is the log:
[09/06/24]BD Rebuilder v0.61.28
[08:59:11] Source:  JOB_TITLE
  - Input BD size: 43.72 GB
  - Approximate total content: [04:58:08.562]
  - Target BD size: 24.30 GB
  - Windows Version: 6.2 [9200]
  - Quality: High Quality (Default), Two Pass
  - Decoding/Frame serving: DGDecNV
- Resuming from previously started job.
[08:59:14] PHASE ONE, Encoding
 - [08:59:14] Processing: VID_00003 (2 of 9)
 - [08:59:14] Extracting A/V streams [VID_00003]
 - [09:04:03] Reencoding video [VID_00003]
   - Rate/Length: 23.976fps, 83,529 frames
   - Bitrate: 11,188 Kbs
 - [09:04:03] Reencoding: VID_00003, Pass 1 of 2
 - [09:39:03] Reencoding: VID_00003, Pass 2 of 2
 - [11:18:34] Video Encode complete
 - [11:18:34] Processing audio tracks
   - Track 4353 (eng): Keeping original audio
   - Track 4354 (eng): Keeping original audio
 - [11:18:34] Multiplexing M2TS
 - [11:22:17] Processing: VID_00004 (3 of 9)
 - [11:22:17] Extracting A/V streams [VID_00004]
 - [11:22:57] Reencoding video [VID_00004]
   - Rate/Length: 23.976fps, 18,152 frames
   - Bitrate: 9,249 Kbs
 - [11:22:57] Reencoding: VID_00004, Pass 1 of 2
 - [11:30:10] Reencoding: VID_00004, Pass 2 of 2
 - [11:48:50] Video Encode complete
 - [11:48:50] Processing audio tracks
 - [11:48:50] Multiplexing M2TS
 - [11:49:04] Processing: VID_00007 (4 of 9)
 - [11:49:04] Extracting A/V streams [VID_00007]
 - [11:49:20] Reencoding video [VID_00007]
   - Rate/Length: 23.976fps, 22,315 frames
   - Bitrate: 2,527 Kbs
 - [11:49:20] Reencoding: VID_00007, Pass 1 of 2
 - [11:55:16] Reencoding: VID_00007, Pass 2 of 2
 - [12:03:24] Video Encode complete
 - [12:03:24] Processing audio tracks
 - [12:03:24] Multiplexing M2TS
 - [12:03:31] Processing: VID_00011 (5 of 9)
 - [12:03:31] Extracting A/V streams [VID_00011]
 - [12:03:50] Reencoding video [VID_00011]
   - Rate/Length: 29.970fps, 25,111 frames
   - Bitrate: 4,040 Kbs
 - [12:03:50] Reencoding: VID_00011, Pass 1 of 2
 - [12:14:52] Reencoding: VID_00011, Pass 2 of 2
 - [12:39:37] Video Encode complete
 - [12:39:37] Processing audio tracks
 - [12:39:37] Multiplexing M2TS
 - [12:39:48] Processing: VID_00012 (6 of 9)
 - [12:39:48] Extracting A/V streams [VID_00012]
 - [12:40:00] Reencoding video [VID_00012]
   - Rate/Length: 23.976fps, 8,578 frames
   - Bitrate: 3,527 Kbs
 - [12:40:00] Reencoding: VID_00012, Pass 1 of 2
 - [12:42:43] Reencoding: VID_00012, Pass 2 of 2
 - [12:49:50] Video Encode complete
 - [12:49:50] Processing audio tracks
 - [12:49:50] Multiplexing M2TS
 - [12:49:56] Processing: VID_00013 (7 of 9)
 - [12:49:56] Extracting A/V streams [VID_00013]
 - [12:50:20] Reencoding video [VID_00013]
   - Rate/Length: 23.976fps, 8,660 frames
   - Bitrate: 12,251 Kbs
 - [12:50:20] Reencoding: VID_00013, Pass 1 of 2
 - [12:54:11] Reencoding: VID_00013, Pass 2 of 2
 - [13:05:50] Video Encode complete
 - [13:05:50] Processing audio tracks
 - [13:05:50] Multiplexing M2TS
 - [13:06:03] Processing: VID_00018 (8 of 9)
 - [13:06:03] Extracting A/V streams [VID_00018]
 - [13:06:19] Reencoding video [VID_00018]
   - Rate/Length: 23.976fps, 12,060 frames
   - Bitrate: 5,119 Kbs
 - [13:06:19] Reencoding: VID_00018, Pass 1 of 2
 - [13:11:19] Reencoding: VID_00018, Pass 2 of 2
 - [13:22:34] Video Encode complete
 - [13:22:34] Processing audio tracks
   - Track 4352 (fra): Keeping original audio
 - [13:22:34] Multiplexing M2TS
 - [13:22:42] Processing: VID_00019 (9 of 9)
 - [13:22:42] Extracting A/V streams [VID_00019]
 - [13:24:16] Reencoding video [VID_00019]
   - Rate/Length: 29.970fps, 104,046 frames
   - Bitrate: 7,172 Kbs
 - [13:24:16] Reencoding: VID_00019, Pass 1 of 2
 - [14:06:15] Reencoding: VID_00019, Pass 2 of 2
 - [15:58:16] Video Encode complete
 - [15:58:16] Processing audio tracks
 - [15:58:16] Multiplexing M2TS
[15:59:29]PHASE ONE complete
[15:59:29]PHASE TWO - Rebuild Started
 - [15:59:29] Rebuilding BD file Structure
[16:00:04] - Encode and Rebuild complete
[16:00:04] JOB: JOB_TITLE finished.
and the inf:
[Status]
LABEL=JOB_TITLE
VERSION=v0.61.28
SOURCE_SIZE=46943731324
SOURCE_VIDEO_SIZE=44934285312
TARGET_SIZE=26088570880
REDUCTION=.535874214996572
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=all
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=-1
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=9
REBUILD_COMPLETE=1
[00002]
AUDIO=111
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=9246285730
RATE=11507
SPLITS=1
NSTART=27000000
NEND=204107555
NSIZE=8848588800
FLINK=0
MLINK=0
[00003]
AUDIO=111
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=8327054407
RATE=11188
SPLITS=1
NSTART=27000000
NEND=183773491
NSIZE=7944744960
FLINK=0
MLINK=0
[00004]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=969496565
RATE=9249
SPLITS=1
NSTART=27000000
NEND=61069035
NSIZE=948553728
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=350516679
RATE=2527
SPLITS=1
NSTART=27000000
NEND=68882465
NSIZE=343523328
FLINK=0
MLINK=0
[00011]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=486022446
RATE=4040
SPLITS=1
NSTART=27000000
NEND=64704166
NSIZE=474673152
FLINK=0
MLINK=0
[00012]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=182880271
RATE=3527
SPLITS=1
NSTART=27000000
NEND=43099833
NSIZE=179073024
FLINK=0
MLINK=0
[00013]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=676139437
RATE=12251
SPLITS=1
NSTART=27000000
NEND=43253737
NSIZE=662796288
FLINK=0
MLINK=0
[00018]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=364861714
RATE=5119
SPLITS=1
NSTART=27000000
NEND=49635113
NSIZE=358785024
FLINK=0
MLINK=0
[00019]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=3475867620
RATE=7172
SPLITS=1
NSTART=27000000
NEND=183225069
NSIZE=3390314496
FLINK=0
MLINK=0
Old 8th September 2024, 22:11   #31994  |  Link
Lathe
Lathe's Avatar
Well, I probably missed this being covered before, and if so, my humble apologies...
Can you use BDRB to convert from a UHD/HDR source to a playable SDR 1080 Blu-ray? Is there any adjustment for changing the color filter to BT709 or any other parameters that allow this?
Or, sort of conversely (not really) can you also simply convert any UHD source using x264 to make a playable Blu-ray? It seems that whenever I try to convert HEVC to x264 it always throws an error. Any secret settings in the configurations? I've tried using both alternate movie only format and archive format (AVC/AC3) neither seem to work for this.
Thanks!
Old 8th September 2024, 23:15   #31995  |  Link
jdobbs
Thanks!
Right now there isn't an easy way to go from UHD to HD. There will probably never be a way to do a full backup -- that's because of differences in v2 and v3 file formats/types.
I'm looking at the possibility of adding a movie-only and/or quick-menu type backup.
Right now you'd have to create an alternate backup in 1080p and then import it.
Old 8th September 2024, 23:47   #31996  |  Link
Lathe
Lathe's Avatar
Okidoke, thanks JD! So, I CAN import either the full UHD blu-ray (m2ts) or 2160 HEVC file and use alternate movie only backup? Would I then be selecting HEVC (it's original format) or can I choose x264? I'm a little fuzzy about the exact steps to use after importing the file...
And, I'm assuming there is no ability to use a BT709 filter to convert it to SDR either, right?
Old 9th September 2024, 01:25   #31997  |  Link
gonca
You might be able to input a tonemapping filter with the avisynth tweaks setting
gonca is offline   Reply With Quote
Old 9th September 2024, 01:28   #31998  |  Link
jdobbs
You can choose X264 for the output to alternate (or any other H264 encoder for that matter). Then when you import, you won't have to encode again (unless you decide to do a near-identical [low CRF] encode during the alternate phase) -- that way after importing you can reencode again.
If you decide to do only on encode (alternate), add ALTERNATE_BLURAY=1 to your REBUILDER.INI. That way the alternate encode will be forced to meet Blu-Ray requirements (making it possible to import without reencoding a second time).
Old 9th September 2024, 02:28   #31999  |  Link
Lathe
Lathe's Avatar
Ah yes, I was thinking about that...
Old 9th September 2024, 02:30   #32000  |  Link
Lathe
Lathe's Avatar
Ah, good, thank you Sir!
