25th December 2021, 09:43 | #31001 | Link |
So, I thought I would try something else. The disc's 2nd audio stream is a descriptive track. Therefore the plan was to replace the 2nd stream with a DD5.1 stream that doesn't have Cinavia. While BDRB ws recoding the video, I replaced the audio stream in the workfiles directory. It has the same PID as the file that was replaced.
After BDRB was finished, I used BDEdit to fix the chapter marks and remove the listing of audio streams that are not there. The disc refuses to let the player select the audio stream by pushing the "Audio" button. Even if you use the menu to select the descriptive track, only the TrueHD track is played. No idea why the DD5.1 track can't be played. Update: I took the M2TS file that BDRB created and fed it to tsMuxer. I had it create a BD ISO. That played just fine, allowing me to switch between audio tracks. As this is a UHD disc, there are no special features, so I'll just use BDRB to create a disc with a simple menu.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 25th December 2021 at 11:38. |
25th December 2021, 11:02 | #31002 | Link |
Life's clearer in 4K UHD
Dolby TrueHD audio streams can be encoded with or without a 'lossy' Dolby Digital core. But just as with Dolby Digital Plus, a 'lossy' Dolby Digital core is a mandatory requirement of the Blu-ray disc specification.
26th December 2021, 02:42 | #31004 | Link |
Well, creating a UHD disc with a simple menu is currently a bust. It is because of the issue whereby BDRB wants to re-encode TrueHD audio to plain AC3 audio, even though the Keep HD audio is set to 1. Plus, the re-encode AC3 is set to 0.
26th December 2021, 04:10 | #31005 | Link |
North Shore - Processed then attempt to make MKV
Hello All, Happy Yuletide.
I've noticed this problem with several BDs...some of I've processed a long time ago, so I reripped my originals to check. The processing (blanking) part seems to go fine. It's when I have BD-RB make MKVs from the processed BD that this error happens. There's an "Error: -2" that happens with some. I've reripped with MakeMKV and DVDFab..doesn't matter which one. Code:
[12/25/21] BD Rebuilder v0.61.25 [16:59:50] Source: NORTH_SHORE - Input BD size: 29.84 GB - Approximate total content: [02:17:35.638] - Target BD size: 46.26 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Auto Quality: Very Good (Very Fast), 1-Pass VBR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [16:59:50] PHASE ONE, Encoding - [16:59:50] Processing: VID_00000 (1 of 6) - [16:59:50] Extracting A/V streams [VID_00000] - [16:59:53] Reencoding video [VID_00000] - [16:59:53] Keeping original video (no reencode) - [16:59:53] Processing audio tracks - [16:59:53] Multiplexing M2TS - [16:59:57] Blanking: VID_00001 (2 of 6) - [16:59:57] Blanking: VID_00002 (3 of 6) - [16:59:57] Processing: VID_00004 (4 of 6) - [16:59:57] Extracting A/V streams [VID_00004] - [17:07:27] Reencoding video [VID_00004] - [17:07:27] Keeping original video (no reencode) - [17:07:27] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [17:07:27] Multiplexing M2TS - [17:28:26] Blanking: VID_00007 (5 of 6) - [17:28:26] Processing: VID_00010 (6 of 6) - [17:28:26] Extracting A/V streams [VID_00010] - [17:28:30] Reencoding video [VID_00010] - [17:28:30] Keeping original video (no reencode) - [17:28:30] Processing audio tracks - [17:28:30] Multiplexing M2TS [17:28:33]PHASE ONE complete [17:28:33]PHASE TWO - Rebuild Started - [17:28:33] Rebuilding BD file Structure [17:29:00] - Encode and Rebuild complete [17:29:00] JOB: NORTH_SHORE finished. [12/25/21] Checking System Settings ---------------------- [12/25/21] BD Rebuilder v0.61.25 [17:30:30] Source: NORTH_SHORE_00004 - Input BD size: 27.31 GB - Approximate total content: [01:35:52.663] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video, Intact Audio - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [17:30:34] PHASE ONE, Encoding - [17:30:34] Processing: VID_00010 (1 of 3) - [17:30:34] Extracting A/V streams [VID_00010] EXIT CODE: -2 - Extracting video streams [VID_00010] - Extracting audio/subtitle streams [VID_00010] EXIT CODE: -2 - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: L:\NORTH_SHORE\BDMV\\STREAM\00010.m2ts - Extracting audio streams [VID_00010] EXIT CODE: -2 - Error in attempt to extract audio. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: L:\NORTH_SHORE\BDMV\\STREAM\00010.m2ts - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: L:\NORTH_SHORE\BDMV\\STREAM\00010.m2ts [18:10:12] - Failed to retrieve audio, aborted Code:
[Options] VERSION=0.61.0.25 ENCODER=0 MODE=3 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 TARGET_SIZE=47366 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 MOVIEONLY_TYPE=28 ALTCRF=23 ALT_TARGET=1024 ALT_CRF_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 ENABLE_TEST=1 ENABLE_BLANKING=1 QUICK_EXTRAS=0 [Paths] SOURCE_PATH=L:\NORTH_SHORE\ WORKING_PATH=L:\
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
26th December 2021, 05:51 | #31006 | Link |
Oops...it's having problems creating an MKV from a fresh rip also.
26th December 2021, 15:18 | #31008 | Link | |
No. Not set up for H265 encoding. I suspose I could use VideoReDoPro to do it, but it would be a guess as to what to configure it for in order to come out with the right size. Also, it would be a software encoding and therefore take a coon's age to do it.
26th December 2021, 15:32 | #31009 | Link |
I use the approach I described and it never re-encodes my thd files.
It just demuxes and remuxes them You can always try x264 launcher (it does hevc as well) It will enter the basic settings for you but you can enter all the custom command switches you want If you have a feature capable NVidia card you can use NVEncc Last edited by gonca; 26th December 2021 at 15:38. |
26th December 2021, 21:17 | #31010 | Link | |
28th December 2021, 18:17 | #31012 | Link | |
I've personally created dozens of UHD discs using BD-RB, many with TrueHD. So I wouldn't say "creating a UHD disc with a simple menu is currently a bust" would be an accurate statement either. Trying to push for something you want by making misleading statements doesn't work with me. So the concept of creating a hidden flag to keep EAC3 streams is off the table. It was a bad idea anyway. Last edited by jdobbs; 28th December 2021 at 18:21. |
28th December 2021, 23:25 | #31014 | Link | |
Some are just lucky he has mellowed with age. In the old days...strikes may have rained down. |
29th December 2021, 05:59 | #31016 | Link | |||
Here is the MediaInfo about the TrueHD stream: Code:
Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : MLP FBA AC-3 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Muxing mode : Stream extension Codec ID : 131 Duration : 1 h 56 min Bit rate mode : Variable Bit rate : 640 kb/s Maximum bit rate : 8 229 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossless Stream size : 532 MiB (3%) Service kind : Complete Main Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE Quote:
Since this UHD disc doesn't have any special features (most don't), I decided to create a simple menu of the M2TS file. First I put the M2TS file into tsMuxer so that I could get rid of unwanted audio and sub-title streams and add in the wanted audio stream. I also had to set the language for the audio and subtitles. I created a project for this job: Code:
[Options] VERSION=0.61.0.25 ENCODER=1 MODE=0 TARGET_SIZE=23500 AUTO_BURN=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=0 SD_TO_1080=0 IGNORE_3D=1 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=2 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=2 SUBTITLE_TRACK_LIMIT=4 CUSTOM_TARGET_SIZE=23500 MENU_BACKGROUND=E:\BD-Rebuilder\Passengers\Passengers-bkg.jpg IMPORT_THRESHOLD=0 QUICK_PLAY_THRESHOLD=0 MENU_AUTO_BACKGROUND=0 MENU_AUTO_DVDAUDIO=1 MENU_FORCE_QUICK=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 IMPORT_VFR_SCAN=0 FORCE_NOENCODE=0 MENU_FONT=Helvetica MENU_FONT_BOLD=1 MENU_FONT_ITALIC=0 MENU_VERTICAL=850 MENU_HORIZONTAL=850 MENU_ACTIVE_COLOR=0xCFCFCF MENU_CUSTOM_COLOR= MENU_INACTIVE_COLOR=0x808080 MENU_BACKDROP_OPACITY=0 MENU_ROLLOVER=1 MENU_ITEMS_PAGE=10,12 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 IMPORT_VFR_FILM=0 AVSFilter01=selectevery(2,0) IMPORT_PREPARE_MKV=0 UHD_CONVERT_ENABLE=1 UHD_V3_MODE=1 NVENC_CAPABLE=1 MIN_M2TS_SIZE=600 MENU_AUDIO=C:\BD_Rebuilder-0.61.25\tools\blankclip\blank.ac3 [Paths] WORKING_PATH=E:\BD-REBUILDER\WORK\ SOURCE_PATH=E:\BD-REBUILDER\WORK\IMPORTS\00001.\ DGIndexNV=C:\Program Files (x86)\DGAVCDecNV\DGIndexNV.exe DGDecNV=C:\Program Files (x86)\DGAVCDecNV\DGDecodeNV.dll Code:
[20:43:09] Importing: 00001. - [20:43:21] Importing video file: (1 of 1) - Preparing M2TS for processing... - Collecting audio/video streams from source... - Converting audio, Track #2, THD to AC3... - Integrating into pseudo-BD structure... - [21:08:30] Creating Quick-Play Menu... - Encoding menu background... - Building menu structure... [21:08:33] Video import completed successfully. In order to make sure that tsMuxer didn't screw something up, I ran the original M2TS file thru the same project and got: Code:
[21:14:06] Importing: 00001. - [21:14:25] Importing video file: (1 of 1) - Preparing M2TS for processing... - Collecting audio/video streams from source... - Converting audio, Track #2, THD to AC3... - Integrating into pseudo-BD structure... EXIT CODE: -1 - Source issue found, attempting correction... [22:35:19]ERROR: Removing compression. Aborted. So, for me, it was indeed a bust. Quote:
29th December 2021, 13:19 | #31018 | Link | |
You can see my config file. I do File->Video Files->M2TS file It would take a special compile of the program so that it listed in the log file as to the choice(s) it took to decide to recode the audio.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 29th December 2021 at 13:22. |
29th December 2021, 18:54 | #31019 | Link | |
With that said... what am I going to lose -- my virtually non-existent income (all of which gets spent [acually more] to buy discs that people report they have issues with)? I don't do this for any reason other than to help people back up their discs. Smart ass comments and complaints from those who use it are just a sign of modern times, I guess. Last edited by jdobbs; 29th December 2021 at 19:05. |
29th December 2021, 18:56 | #31020 | Link | |
