Thread Tools Display Modes
Old 20th January 2026, 09:00   #1  |  Link
musiclover
How do I bypass the track menu?
I have made a blu-ray with TMPGEnc Authoring Works 7. The blu-ray has six tracks. The topmenu points to the 6 track menus. But I would like it when two of them would bypass the track menu and start playing the video without first going to the track menu. I see no option to do this within TMPGEnc Authoring Works 7. How would I go about it to change the blu-ray menu with BDedit to make this happen?
musiclover is offline   Reply With Quote
Old 20th January 2026, 09:52   #2  |  Link
TR-9970X
TR-9970X's Avatar
I think you should post this on TMPENG's site/forum !!!!
Main Systems:-
9970X on Gigabyte TRX50 AERO D
7970X on Asus Pro WS TRX50-Sage WiFi
9950X3D on MSI Carbon X670E
7950X on Gigabyte Aorus Elite B650
i9-13900KF on MSI Tomahawk B660
TR-9970X is offline   Reply With Quote
Old 20th January 2026, 12:19   #3  |  Link
musiclover
Are you saying it couldn't be done with BDedit?
Old 20th January 2026, 12:25   #4  |  Link
TR-9970X
TR-9970X's Avatar
Sorry, can't help, I stopped playing around with DVD's & Bluray's, years ago.
Main Systems:-
Old 27th January 2026, 17:37   #5  |  Link
ocean
Hi musiclover, you can try working on playlists with BDedit:
Play PL: Starts playback of a playlist
O: 0x22000000: Operand is defined by the register.
0x22800000: Operand is an immediate value.
D: Playlist ID
S. -
Play PlatPI: Starts playback of a PlayList on PlayItem
O: 0x42010000: Operand1 and Operand2 are defined by the register.
0x42810000: Operand1 is an immediate value.
0x42410000: Operand2 is an immediate value.
0x42C10000: Operand1 and Operand2 have an immediate value.
D: PlayList ID (123 if you want to play 00123.mpls)
S: Game Item ID
Play PlatMK: Starts playback of a PlayList on PlayList Mark
O: 0x42020000: Operand 1 and Operand 2 are defined by the register.
0x42820000: Operand 1 is an immediate value.
0x42420000: Operand 2 is an immediate value.
0x42C20000: Operand 1 and Operand 2 have an immediate value.
D: Playlist ID
S: PL_mark_id
Terminate PL: Ends playback of the current PlayList
O: 0x02030000 D: - S: -
PI Link: Changes the playback position in PlayItem
O: 0x22040000: The operand is defined by the register.
0x22840000: Operand is an immediate value.
D: Item ID to be played
S: -
MK Link: Changes the playback position in PlayListMark
O: 0x22050000: Operand is register-defined.
0x22850000: Operand is an immediate value.
D: PL_mark_id
S: -
ocean is offline   Reply With Quote
Old 27th January 2026, 18:17   #6  |  Link
musiclover
@ocean
Thank you for your trouble. But I don't see what I must do to make playlists 00004.mpls and 00005.mpls start without first going to the track menu. Where must I make changes? I cannot find your items on the playlist.
Old 27th January 2026, 18:25   #7  |  Link
ocean
I think the menu created by TMPGEnc Authoring Works 7 is IGS, not Java.
You should locate where the track menu is called, replacing it with direct tracks.
In the programming menu, you can enter a command to recall playlists with tracks. Obviously, it must be entered in the correct position.
But I'm writing this without seeing it; I could be wrong.
Old 28th January 2026, 18:59   #8  |  Link
musiclover
Playlist 00005 is one of the tracks that I would like to play from the topmenu without going first to the trackmenu.
Attachments Pending Approval
File Type: jpg 1.JPG
File Type: jpg 2.JPG
Old 29th January 2026, 16:20   #9  |  Link
ocean
Try clicking the "Play PL 5" command if it takes you back to mpls 00005.
Old 29th January 2026, 17:15   #10  |  Link
musiclover
Yes it goes to playlist 5
So how do I bypass that command?
Old 29th January 2026, 17:23   #11  |  Link
ocean
Great, for GoTo 22, always make a backup before making changes, just to be safe.
You can try deleting the command by selecting the line containing the command and pressing the - button in the top right. Then save in the bottom left.
It's not certain that it will work, because we don't know how the menu will be programmed.
Old 29th January 2026, 17:30   #12  |  Link
musiclover
No that did not work. The menu works the same as before.
But thanks for trying. I guess it's to hard from a distance.
Old 29th January 2026, 17:41   #13  |  Link
ocean
Can you upload the folders to me, without the main movie to lighten the load, on host so I can try it.
Old 29th January 2026, 19:09   #14  |  Link
musiclover
I send you a private message
Old 30th January 2026, 14:33   #15  |  Link
ocean
Thank you musiclover, unfortunately all igs menus are multiplexed, Video+audio+graphics, BDedit does not work these menus.
Old 31st January 2026, 08:16   #16  |  Link
musiclover
Would it help if I removed the audio from the two to bypass track menus?
Old 31st January 2026, 15:08   #17  |  Link
ocean
Unfortunately, I don't think musiclover is enough, because in 01000.m2ts and 01010.m2ts you have video + audio + graphics.
BDedit should only have the menu as shown in the picture:
Old 31st January 2026, 17:45   #18  |  Link
musiclover
There is always video in the menus that ''TMPGEnc Authoring Works'' makes. It's a pity BDedit can do nothing with it.
Old 31st January 2026, 20:20   #19  |  Link
taurusus
Hi musiclover
You need to use the Kite program. In it, you will disassemble your blu-ray disc and then, using the built-in IGEditor, you can open the ies menu files and edit them.
taurusus is offline   Reply With Quote
Old 31st January 2026, 21:54   #20  |  Link
musiclover
Originally Posted by taurusus View Post
Hi musiclover
I don't own the Kite program and I can't find it anywhere.
Thread Tools
