Thread Tools Display Modes
Old 18th January 2026, 11:24   #1  |  Link
Lucho
It doesn't start the chapters
Hello everyone.
I'm having trouble changing the subtitles on this Blu-ray disc.
I'm replacing the subtitles on this Blu-ray with Spanish subtitles using Kite. Once the Blu-ray disc is mounted, I test it.
Everything looks perfect on my PC, but on my PS4, I can't start any chapter. I can select everything through the menu, but the chapter doesn't start. I should also mention that I modified the instructions, which were similar to this: `SetStreamGPR6,GPR1,(0),(0)`, because on the mounted Blu-ray disc, they appeared like this: `SetStreamGPR6,GPR11,0,0`.
The region protection is removed with anydvd 8.1.7.0
I've attached images of the original and the edited Blu-ray disc to see if you can help me.
Regards, Lucho
Lucho is offline   Reply With Quote
Old 18th January 2026, 13:14   #2  |  Link
taurusus
Hi Lucho.
Your screenshot shows 00000.mpls, but what does it include?
If this is the disk menu, then it is unclear why so many m2ts are written in the third screenshot,
I see from 0 to 7 m2ts there, but in the same place in the SubPath tab it is indicated that IGMenu is located at 00030.m2ts.
Although the fourth screenshot shows 00000.clpi and there is no IGMenu in it.
It's hard to tell from the screenshots what's wrong, so send the disc without the movie so you can check it out.
taurusus is offline   Reply With Quote
Old 19th January 2026, 13:17   #3  |  Link
Lucho
Thanks for your reply, @Taurusus.
Just so you know, screenshots 1, 3, and 5 are from the original Blu-ray, while screenshots 2, 4, and 6 are from the modified version.
The mpls 00000 file contains the 13 episodes of the series, and the other 17 files are between mpls00001 and mpls0007.
I've included images of mpls00000 and playst 00001 so you can verify that there are no alterations to the records of either.
Here's a RAR file with the disc without streams, as you requested.
https://mega.nz/file/dnFkmDob#GHFlV0...BK-6eD5kIfzbQM
Best regards, Lucho
Old 19th January 2026, 14:59   #4  |  Link
taurusus
You've removed all the m2ts files, but how do I open this disc on the player?
It was necessary to leave the menu files and the splash screen for the menu.
If this is a TV series, then you need to add at least two more episodes.
Old 19th January 2026, 16:52   #5  |  Link
Lucho
Link to the original file.
https://mega.nz/folder/ZyFTBZZA#8ti9UL0GA2VU2Ry7vAGnjg
Link to the modified file.
https://mega.nz/folder/orlVkZyT#0r4seZs02PEmLTRtzljiCA
File link modified and corrected
Old 31st January 2026, 23:32   #6  |  Link
Lucho
I decided to burn the file I have on my PC (with the menus changed) onto a BD-RE DL and a BD-R DL. Both discs have been tested on a PS4 and a Sony S1700/K player, and the result is the same: the BD plays with its intros fine, but when it gets to the menu, the screen goes black. I also tried these two discs on my PC with PowerDVD 14, and it does the same thing. However, with the file on my PC, there's no problem at all. I use Leawo Play, and I can see the menu, select everything, and start a chapter.
If I only want to change the subtitles...
Thread Tools
