Thread Tools Display Modes
Old 18th June 2025, 02:51   #1  |  Link
parasense
MPLS MVC (3d) extension documentation?
Hey Gang!
I'm writing an MPLS decoder/parser in GO lang, and looking for any information about the MVC (3D) extension.
So far libbluray [0], from VideoLan [1] project, has been a great reference implementation. But regrettably libbluray does not currently support the MVC extension [2].
My Google searching leads me to an old Doom9 forum post:
https://forum.doom9.org/showthread.php?t=171140
The information there was helpful towards my understanding, reverse engineering, and I was able to make progress. I'm still not able to process IGs or PGs after parsing the MVC STN, and that's where I have lots of confusion. Many times I have leftover bytes after the STNs, but seemingly not enough for PGs or IGs, say 6 bytes leftover.
Another point of confusion is the weirdness of MVC data on my limited collection of 3D discs. Some of them have all zeros filling the entire length of uint16 (aka 65 thousand bytes of zero padding). Others have strange tail padding after the STN table... like, alternating "255 0 255 0 255 0 ...", almost as if the software encoders are doing something silly.
Does anybody here have code I can look at, or some implementation notes, or anything like that? I'd appreciate any hints you folks might have.
[0] https://code.videolan.org/videolan/libbluray
[1] https://www.videolan.org/developers/libbluray.html
[2] https://code.videolan.org/videolan/l...pe=heads#L1074
parasense is offline   Reply With Quote
Thread Tools
