Thread Tools Display Modes
Old 17th October 2024, 18:24   #1  |  Link
malimuc
malimuc's Avatar
Trouble with Dolby Atmos?
Hello. I’ve encountered an issue with two movies already: when I process a movie with tsmuxer that has audio English Dolby Atmos, the audio becomes unsynchronized with the subtitles, as if the audio is ahead of the subtitles. What am I doing wrong? I would appreciate your help.
This only happens with Dolby Atmos audio, Dolby Digital 5.1 working fine.
Thank you and have a nice evening.
malimuc is offline   Reply With Quote
Old 17th October 2024, 19:37   #2  |  Link
ocean
Hi malimuc, try using DGDemux to see if it solves the problem.
ocean is offline   Reply With Quote
Old 18th October 2024, 19:19   #3  |  Link
malimuc
malimuc's Avatar
Hi, ocean!
"Now that I've demuxed the audio with DGDemuxGui, I got three files: the first one has the extension thd+ac3, the second one is thd, and the third one is ac3. Which file should I insert into tsmuxerGui to create a file that matches the original? And thanks for the help."
Old 18th October 2024, 19:35   #4  |  Link
ocean
If I remember correctly tsMuxeR accept Dolby True HD (for streams with AC3 core only).
Old 8th September 2025, 16:36   #5  |  Link
malimuc
malimuc's Avatar
Hi all!
Has anyone managed to demux the THD audio from this movie: Jurassic.World.Rebirth.2025?
I'm attaching a link:
https://www.mediafire.com/view/9yacb...ssx/1.PNG/file
After demuxing, I end up with two files:
13488 PID 4352 48000 8ch eng DELAY 0ms.thd
13488 PID 4352 embedded eng DELAY 0ms.ac3.**
When I use the first file (13488 PID 4352 48000 8ch eng DELAY 0ms.thd) in tsmuxerGUI while remuxing the movie, the audio doesn't work properly and it's not in sync with the subtitles.
However, if I use the second audio file (13488 PID 4352 embedded eng DELAY 0ms.ac3), the audio and subtitles are perfectly synchronized.
I demuxed the audio using DGDemux 1.0.8.1, but after muxing (with latest tsMuxerGUI), it doesn’t work correctly!
Any advice on how to demux and keep the 7.1 audio untouched?
Thanks to everyone for any help. Best regards
Old 8th September 2025, 19:07   #6  |  Link
ocean
Hi malimuc, If I'm not mistaken, tsMuxer Dolby True HD (for streams with AC3 core only); when demuxing with DGDemux, it selects THD Full.
Old 9th September 2025, 17:38   #7  |  Link
malimuc
malimuc's Avatar
Thanks ocean, it works as you wrote.
Thread Tools
