Thread Tools Display Modes
Old 9th October 2025, 22:20   #1401  |  Link
Hellboy.
Never had any problems using tsMuxer on disks with multiple m2ts.
Hellboy. is offline   Reply With Quote
Old 10th October 2025, 15:14   #1402  |  Link
Columbo
Sorry, I am not familiar with tsmuxer.
Columbo is offline   Reply With Quote
Old 22nd October 2025, 13:24   #1403  |  Link
DanDare1983
Someone told me that if I create a main movie blu-ray from mpls/m2ts file I'll get identical file. However if I demux from original blu-ray folder with eac3to the ac3 track is +7ms cannot be fixed, whearas if I demux the tsmuxer made file with eac3to I get +8ms cannot be fixed. I know it's only 1ms but tsmuxer must be doing something as I expected things to be identical. I'm using the exact m2ts file so no playlists with added m2ts files.
DanDare1983 is offline   Reply With Quote
Old 22nd October 2025, 22:26   #1404  |  Link
Hellboy.
I never demux with eac3to, especially ac3. I demux with MKVToolNix - gMKVExtractGUI or tsMuxer.
Old 7th November 2025, 14:46   #1405  |  Link
Columbo
That's not always true, because the disk structure can define in/out times for the M2TS files. If you create from only the M2TS files then these times are not honored, and the results can differ.
Thread Tools
