#61 | Link | |
- Extracted about 34 minutes of the John Mayer Blueray disk using the Avisynth TRIM function in a script (to avoid wasting 30+ hours again in reencoding 2.5+ hours of video) - Re-encoded , used today (oct 19) updated Standalone-HD-DVD profile in MeGUI. - Made same section of audio and converted into, 16b48k, AC3 2ch 448kbps with delaycut. - Tested the output files by muxing everything into MKV and playing in mplayer. - Muxed with V0.3 of the tool. Tool runs and ends normally - Burned with Nero, UDF 2.5 on 4x DVD-RW like instructed. >>UDF 2.5 on DVD structure seems not to work in Toshiba HD-A1 player... Player says HD-DVD -> Play -> hangs - Burned same structure again, but now with 'XBOX compatible' setting on UDF DVD-ROM. Now disk plays perfectly in my HD-A1...!!! no stutters... perfectly in sync... nice quality also. Edit: After playing the whole video without issue, my A1 player tries to read beyond the end of the file, resulting in a error message. Seems there is no end-of-stream marker. Will convert the whole video later for final test. Thanks for the tool! Things most needed in my view for future versions - Chapter support, e.g. by importing chapter file - Support for 1080p30 (I have a lot of concert disks and those are often 1080i60, which I normally de-interlace to 30p) - A method to include higher quality audio than AC3 Last edited by shanghai2004; 20th October 2008 at 06:27. Reason: Add more results |
#62 | Link |
hey, so glad i was linked to this thread.
i have been having some problems when using HDDVDmux, it keeps crashing as soon as i start the process. ive even downloaded the Visual basics pacakage but that didnt help either. can anyone help me on this? |
#64 | Link |
@Undead Sega
Hi! I think it's an abandoned project... BTW - In my effort to track down similar software, I wrote to the author of "EVO Demux", asking if he/she would be willing to enhance the program to include conversion from BluRay format (or MKV, M2TS, or TS) to HD-DVD compliant "package"/format. The author stated that he/she had neither the time nor the inclination to do so... |
#65 | Link |
ohh that is such a shame!
![]() im pretty sure HDDVDMux is good, but i just dont knwo why it wants to crash after 0.6%? and says the program is not responding. Wasnt there a reason why it was doing this? Probably because i changed the video stream file extension from .h264 to .264? |
#66 | Link |
This was another phantom project. Can't you see that?
#67 | Link | |
Aging Video Hobbyist
![]() Have you tried at least using the source the author has posted? That source works with the tool; I just tried it--at least it doesn't crash. But it crashes with some other .264 and .ac3 I have here after a few milliseconds. Since others here have had success with it, I'm guessing that it is looking for 14 frame GOPs and maybe some other params as per the "suggested settings". Maybe if you make all your encodings to HD DVD spec the tool might work. But clearly the author is long gone, not having posted here since last October. Thus the tool is as dead as or deader than the format!
#71 | Link | ||
Again, that's why I said re-read my earlier post, in which I said: Quote:
#72 | Link |
ohh right...i understand now, its a shame that the author has no interest
maybe alittle bit of flash of (small) cash might do the trick? ![]() this has also lead me to another theory, if we could take either a .h264 or .264 file and transcode it under HD DVD standards and not really touching the bitrate and size and so on, would that probably help things? |
#76 | Link | |
| Thread Tools | |
| Display Modes | |
