Thread Tools Display Modes
Old 22nd August 2008, 23:53   #21  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Have you heard about troyan horse ?
Old 22nd August 2008, 23:57   #22  |  Link
rica
Yes, i live where it is
really...
Next to Troy, just 300 km.
EDIT: Correction; Istanbul-Troy is 407 km
rica is offline   Reply With Quote
Old 23rd August 2008, 00:08   #23  |  Link
ReferenceDivx
ReferenceDivx's Avatar
Rica - it looks like you are entering the right info into the command line. It looks like the bug is not specific to xp. I'll try to put up the debug version which is slower but might work better in the mean time. Check my site for debug version in a little while.
I'm sorry it hasn't worked well so far. The program consists of thousands of lines of code and extremely complicated. The output might not be compatible with some demultiplexers.
The program does not create an ifo folder as this is not needed. Only two directories are needed HVDVD_TS and ADV_OBJ.
ReferenceDivx is offline   Reply With Quote
Old 23rd August 2008, 00:13   #24  |  Link
rica
But even EVO exists, it doesn't work as standalone...
Old 23rd August 2008, 00:20   #25  |  Link
ReferenceDivx
i have found the standalone evo files do not work, especially if they contain avc video. They need the two files HV001I01.IFO and HV000I01.IFO to play back correctly.
Old 23rd August 2008, 00:26   #26  |  Link
rica
OK, it's time to show you are on the horse, not inside of her
Old 23rd August 2008, 00:34   #27  |  Link
Atak_Snajpera
I see only excuses and nothing else! Come on. You and your wonder group have been developing this "tool" for long time and you had not discovered that????
Our group has been working on a Hd-dvd authoring program for some time.
ALL my original decrypted EVOS taken from HD-DVD play on HC-MPC (with haali media spliter) only with sound (no picture) but they are correctly detected by eac3to. Your "trailer" plays in MPC but it's not detected by eac3to. This very weird. I can't wait to see your next excuse
Old 23rd August 2008, 00:54   #28  |  Link
ReferenceDivx
As I stated above: "The output might not be compatible with some demultiplexers" It was designed for playback in software and hardware players. The program is only in its alpha stage and continues to get better as I get feedback from testers here.
Thanks for your feedback Rica and others
Old 23rd August 2008, 01:00   #29  |  Link
rica
Do not worry, just keep going.
Old 23rd August 2008, 01:17   #30  |  Link
ReferenceDivx
Rica have you had a chance to download the debug version from my site. It should output the two missing files. However, it give a memory stack error when finished.
Old 23rd August 2008, 03:03   #31  |  Link
setarip_old
setarip_old's Avatar
@ReferenceDivx
1) After reading all the posts in this thread thusfar, it appears that your program's development hasn't progressed very much since the previous thread you started here in June (Which was closed for being SPAM by a moderator because you were attempting to charge $29.99 for it). In that June thread, you indicated that your "group" had already been working on the program for more than 6 months:
http://forum.doom9.org/showthread.ph...74#post1150274
In this current thread, you refer to your present version as being in the "alpha" stage. If that's the case, what could you have possibly tried to sell back in June?
2) Earlier in this thread I asked you, "What's your source for this data?" and you said, "Derived from the best parts of nero and scenarist".
Does your response mean that in your program, you've incorporated code from both NERO and Scenarist?
3) Is it your intention to maintain this program as FREEWARE throughout the course of its development?
setarip_old is offline   Reply With Quote
Old 23rd August 2008, 07:11   #32  |  Link
Atak_Snajpera
Another excuse! Hahahah. Why do you release something what does not work?!?!?!?!? This tool is fake!
Old 23rd August 2008, 10:29   #33  |  Link
rica
Two files are still missing...
Old 23rd August 2008, 11:01   #34  |  Link
oldpainless
mmmmm
oldpainless is offline   Reply With Quote
Old 25th September 2008, 17:52   #35  |  Link
jofarmer
Once this app works it will be exactly what I have been looking for for quite some time.
@ReferenceDivx: thank you for trying to offer those who bought HD-DVD-players a way to use them.
jofarmer is offline   Reply With Quote
Old 26th September 2008, 07:06   #36  |  Link
ReferenceDivx
Cool. Thanks.
I plan to fix the bugs and release a new version in the next few days. I got a little frustrated when I could never get the chapters to work correctly on my standalone hd-dvd player. I think my program would be an awsome addition to megui. I would ask for money but I wouldn't know what to do with it.
Future plans include:
1. Fix the memory errors.
2. Release the code so we can get more developers involved.
3. Decrease the time it takes from 30 minutes to 7 minutes to mux a hd-dvd.
Old 26th September 2008, 22:44   #37  |  Link
Atak_Snajpera
Don't praise day before dusk.
You better convince us that this thing even works.
Old 26th September 2008, 23:52   #38  |  Link
ReferenceDivx
Ok. I just released my new version. Hopefully this will fix a few problems.
http://www.hddvdstrikesback.com/vers/hddvdmux021.zip
Changelog
1. Increased the memory size of one variable.
2. Fixed crashing on termination of program.
3. Should now output the two files that some people were missing on crash. HV000I01.IFO and HV001I01.IFO
3. Now supports both Standalone-HD-DVD and Standalone-HD-DVD-Fast x264 settings.
Future fixes
1. Change how files are inputed
2. drop need to input ac3 bitrate
3. add a percentage done bar -done 09/27/08
Btw I really like what neuron2 has done with DGAVCDecNV and will send him some money when he gets the whole megui thing figured out.
Old 27th September 2008, 10:56   #39  |  Link
jofarmer
crashes in WinXP32 running inside virtualbox in Ubuntu - who would have thought ;-) Will try later in Vista...
Old 27th September 2008, 11:35   #40  |  Link
ReferenceDivx
Ok. I just released a new version that adds a progress bar.
I have tested it in windows xp and vista
Enjoy
Thread Tools
