Old 20th November 2014, 14:42   #1  |  Link
l35633
x264, problems about high444 encodes 16bits gray image into Y and U channels
Using x264 as encoder for 16bits depth gray image, high 8bits into Y , low 8bits into U, zeros into V. The configuration is below:
x264_param_default_preset(pX264Param, "medium", "zerolatency");
pX264Param->i_threads = X264_SYNC_LOOKAHEAD_AUTO;
pX264Param->i_keyint_max = 1; //IDR
pX264Param->rc.f_rf_constant = 0; //crf
pX264Param->i_fps_den = 1;
pX264Param->i_fps_num = 30;
pX264Param->i_timebase_den = pX264Param->i_fps_num;
pX264Param->i_timebase_num = pX264Param->i_fps_den;
//high444
x264_param_apply_profile(pX264Param, x264_profile_names[5]);
The debugging information:
profile High 4:4:4 Intra, level 3.0, 4:2:0 8-bit,
x264 encoding and ffmpeg decoding are both OK. Seperately show Y, it is right! If add the low 8bits data from U channel, the image result is obviously wrong, i.e, the U channel data is changed too much. what and where is wrong? NEED YOU HELP, MY FRIEND.
l35633 is offline   Reply With Quote
Old 20th November 2014, 19:09   #2  |  Link
MasterNobody
You encoding in 4:2:0 colorspace where U plane is 4 times smaller then Y plane. So make sure that this not the cause of you problem.
You have to use
pX264Param->i_csp = X264_CSP_I444;
for 4:4:4 colorspace encoding which you probably want.
MasterNobody is offline   Reply With Quote
Old 20th November 2014, 21:45   #3  |  Link
l35633
after adding, still error
I added pX264Param->i_csp = X264_CSP_I444, but still error below:
x264 [info]: profile High 4:4:4 Intra, level 3.0, 4:4:4 8-bit
x264 [error]: Invalid input colorspace
would you please give more advices?
Thank you very much!
Old 20th November 2014, 22:28   #4  |  Link
MasterNobody
This mean that while you changed encoder to encode 4:4:4 colorspace you are still trying to send it 4:2:0 colorspace image in x264_encoder_encode (x264_picture_t *pic_in argument). If you are using x264_picture_alloc to allocate pic_in then you should use correct colorspace there also.
Old 20th November 2014, 23:03   #5  |  Link
l35633
Yes, you are right! I really forgot modifying x264_picture_alloc.
Now encoding with x264 is no problem. But after decoding with ffmpeg, the Y channel data is right! But U channel data changed so much! so many data changed to value 205. I am not sure something is wrong with encoder or decoder?
Would you please give me more nice advices?
Old 20th November 2014, 23:09   #6  |  Link
MasterNobody
I am out of ideas without code snippets. But are you sure that you correctly fill pic_in planes?
Old 21st November 2014, 10:57   #7  |  Link
l35633
Thank you so much for your warm reply!
Now I think it is the problem of ffmpeg decoding, but I am not totally sure, I just show the result I test.
First I use ffmpeg command line to decode yuv444 encoded file test444.264:
./ffmpeg -f h264 -i test444.264 output.yuv
some errors happened:
[h264 @ 0x252ff40] top block unavailable for requested intra mode at 0 0
[h264 @ 0x252ff40] error while decoding MB 0 0, bytestream (58749)
[h264 @ 0x252ff40] number of reference frames exceeds max (probably corrupt input), discarding one
[h264 @ 0x252ff40] concealing 1200 DC, 1200 AC, 1200 MV errors
But if I use ffmpeg lib and function to decode test444.264, though no error printed, the result of U is not right. How do I use ffmpeg lib to decode,I show below:
AVCodec* pCodec = NULL;
avcodec_register_all();
av_register_all();
pCodec = avcodec_find_decoder(CODEC_ID_H264);
if(pCodec != NULL)
pCodecCtx = avcodec_alloc_context3(NULL);
pCodecCtx->time_base.num = 1;
pCodecCtx->time_base.den = 30;
pCodecCtx->bit_rate = 0;
pCodecCtx->frame_number = 1;
pCodecCtx->codec_type = AVMEDIA_TYPE_VIDEO;
pCodecCtx->width = width;
pCodecCtx->height = height;
if(avcodec_open2(pCodecCtx, pCodec,NULL) >= 0)
pAvfFrame = avcodec_alloc_frame();// Allocate video frame
AVPacket pkt;
av_init_packet(&pkt);
pkt.data = (unsigned char*)pSrcData;
pkt.size = dwDataLen;
avcodec_decode_video2(pCodecCtx,pAvfFrame,(int*)(&get),&pkt);
if(get != 0)
for(int i=0,nDatalen=0; i<3; i++)
int nShift = (i==0)?0:1;
uint8_t* pYUVData = (uint8_t*)pAvfFrame->data[i];
for(int j=0; j<(pCodecCtx->height>>nShift); j++)
memcpy(&pDeData[nDatalen],pYUVData,(pCodecCtx->width>>nShift));
pYUVData += pAvfFrame->linesize[i];
nDatalen += (pCodecCtx->width>>nShift);
return true;
else
return false;
That is what I did. Would you please give me more advices?
Old 21st November 2014, 19:07   #8  |  Link
MasterNobody
I am dunno about ffmpeg decoding but ffmpeg warnings sounds like your output stream is broken. I was more interested in you libx264 use code snippet and also muxing (writing to file) code. Small output sample can be useful for analyzing what you done wrong. Also you can try to create your yuv sample file and feed it to x264 CLI (instead of your libx264 code) to encode to see if it would output it correctly and would ffmpeg be able to decode it.
Old 24th November 2014, 12:55   #9  |  Link
l35633
Now I have a high444 yuv file, I encoded by x264 command below,no error happend, but I cannot open the 264 file by vlc player, and decoded by ffmpeg is wrong! Would you please tell me where is wrong with my command?
./x264 vga_640x480.yuv --preset medium --tune zerolatency --input-csp i444 --keyint 1 --crf 0 --fps 30 --profile high444 --output-csp i444 -o test.264
Old 24th November 2014, 18:24   #10  |  Link
MasterNobody
l35633
What do you mean by "decoded by ffmpeg is wrong"? Wrong output or errors during decoding? Can you upload encoded sample to any file sharing service so I can look at it.
Old 24th November 2014, 18:52   #11  |  Link
l35633
hello,dear friend.
What I mean, when I use command below:
./ffmpeg -f h264 -i test.264 output.yuv
errors below:
[h264 @ 0x1e55f60] concealing 99 DC, 99 AC, 99 MV errors
[h264 @ 0x1e55f60] top block unavailable for requested intra mode at 0 0
[h264 @ 0x1e55f60] error while decoding MB 0 0, bytestream (41380)
[h264 @ 0x1e55f60] number of reference frames exceeds max (probably corrupt input), discarding one
Now links below is repectivly a yuv444 test file, and encoded result by my command:
https://www.dropbox.com/s/bgt80xnswi...6x144.yuv?dl=0
https://www.dropbox.com/s/7j9vh0ovye4t3xn/test.264?dl=0
Thank you very much! I now don't make clear it is encoder command has problem or decoder command has problem.
Old 24th November 2014, 19:35   #12  |  Link
MasterNobody
l35633
Update your ffmpeg or try avconv (libav). It decodes correctly (and bit exact to input) here with both JM (ldecod) and with your ffmpeg command line.
Old 24th November 2014, 20:22   #13  |  Link
l35633
Dear MasterNobody, thank you so much!
I think you are Master of me!
Would you please tell me your ffmpeg version and JM version? I will try in my machine later!
Thank you for your warm help!
Old 24th November 2014, 20:46   #14  |  Link
MasterNobody
I tested with JM 18.4 and with Latest Zeranoe FFmpeg Build Version: git-5182a2a (2014-11-24)
Old 24th November 2014, 20:55   #15  |  Link
l35633
16bits, ffmpeg, gray, high444, x264
