9th October 2022, 01:35 | #1 | Link |
Compile issue with aom-av1-lavish
I download this code from https://github.com/Clybius/aom-av1-lavish and compile this code, get a bug report.
~/av1-lavish$ make ~/aom-av1-lavish/test/quantize_func_test.cc: In member function ‘void {anonymous}::QuantizeTestBase<CoeffType, FuncType>::InitQuantizer()’: ~/aom-av1-lavish/test/quantize_func_test.cc:123:24: error: too few arguments to function ‘void av1_build_quantizer(aom_bit_depth_t, int, int, int, int, int, QUANTS*, Dequants*, int)’ 123 | av1_build_quantizer(bd_, 0, 0, 0, 0, 0, &qtab_->quant, &qtab_->dequant); | ~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from ~/aom-av1-lavish/av1/encoder/encoder.h:36, from ~/aom-av1-lavish/test/quantize_func_test.cc:23: ~/aom-av1-lavish/av1/encoder/av1_quantize.h:99:6: note: declared here 99 | void av1_build_quantizer(aom_bit_depth_t bit_depth, int y_dc_delta_q, | ^~~~~~~~~~~~~~~~~~~ make[2]: *** [CMakeFiles/test_aom_encoder.dir/build.make:1140: CMakeFiles/test_aom_encoder.dir/test/quantize_func_test.cc.o] Fehler 1 make[1]: *** [CMakeFiles/Makefile2:2777: CMakeFiles/test_aom_encoder.dir/all] Fehler 2 make: *** [Makefile:136: all] Fehler 2 |
29th November 2022, 19:36 | #4 | Link |
Bug issue
Encoder crash at 143301 of 169800 frame with following command: pass 1: Code:
~/av1-lavish$ ./aomenc --deltaq-mode=0 --cpu-used=0 --enable-restoration=0 --tune-content=psy --enable-cdef=0 --tune=lavish --usage=2 --good --row-mt=1 --tile-columns=2 --tile-rows=1 --arnr-strength=1 --arnr-maxframes=2 --end-usage=q --cq-level=0 --threads=32 --bit-depth=8 --lag-in-frames=120 --input-bit-depth=8 --passes=2 --pass=1 --fpf=pass.stat --width=1920 --height=1080 --kf-max-dist=240 --kf-min-dist=0 --enable-fwd-kf=1 --fwd-kf-dist=1 --enable-dnl-denoising=0 --denoise-noise-level=2 -o output-feature.webm input-feature.y4m Code:
~/av1-lavish$ ./aomenc --cpu-used=4 --enable-restoration=0 --enable-cdef=0 --tune=lavish_fast --aq-mode=2 --deltaq-mode=0 --usage=2 --good --row-mt=1 --tile-columns=2 --tile-rows=1 --auto-alt-ref=1 --cq-level=13 --end-usage=q --lag-in-frames=120 --passes=2 --pass=2 --fpf=pass.stat --width=1920 --height=1080 --kf-max-dist=240 --kf-min-dist=0 --enable-fwd-kf=1 --fwd-kf-dist=1 --bit-depth=8 --input-bit-depth=8 --buf-sz=6 --buf-initial-sz=4 --buf-optimal-sz=5 --arnr-strength=1 --arnr-maxframes=2 --enable-dnl-denoising=0 --profile=0 --mv-cost-upd-freq=2 --mode-cost-upd-freq=1 --enable-qm=1 --minsection-pct=15 --maxsection-pct=10000 --noise-sensitivity=0 --enable-tpl-model=1 --quant-b-adapt=1 --enable-chroma-deltaq=1 --i420 --threads=32 --sb-size=dynamic -o output-feature.webm input-feature.y4m Pass 2/2 frame 143301/143181 982:33 7021839 KB 2.43 fps 9406.6 Kbps memory access error (memory dump written) Last edited by 2160p; 29th November 2022 at 19:41. |
