Old 23rd March 2022, 10:23   #1  |  Link
donnje
donnje's Avatar
DVDStyler
I have 2 problem with this app:
1 - I would like to create a single PLAY button that if not selected would remain white, if selected blue and if clicked red, setting in this way when I open the DVD the button is already blue and not white if instead I create two buttons there is no problem, to get around the problem I inserted a first button that is always transparent and the second the one I would like to change color and so it works, is there any other way to solve?
2 - I created two different buttons to combine with two audio tracks with the following commands
audio = 0; jump title 1;
audio = 1; jump title 1;
doing different tests with different players VLC, MPC, Goplayer etc
they never work properly, without logic sometimes the same audio always starts or other times in an inverted way, apparently I think it's something to set in the players because if I check the source video file the two audio tracks are correct,
these are the examples
https://wetransfer.com/downloads/9f9...1183604/1e22ee
anyone have any idea how to fix?
Thanks
donnje is offline   Reply With Quote
Old 23rd March 2022, 18:31   #2  |  Link
rjd0309
Wanted Dead or Dead
rjd0309's Avatar
DVDStyler help forum:
https://sourceforge.net/p/dvdstyler/discussion/
rjd0309 is offline   Reply With Quote
