Old 1st May 2020, 18:50   #1  |  Link
jlw_4049
How to properly crop/encode DVD films?
I've been googling and reading for about 6 hours now and I am getting information all sorts of ways.
I'm currently encoding two DVD sources for a friend. I generally only encode BluRay and upon reading about DVD's it's a different process apparently.
Source #1 is 720x576.
Source #2 is 720x480. I understand 1 is PAL and 1 is NTSC.
However, what's unclear to me is the proper method of cropping away the edges. Apparently it changes the picture, unlike cropping away the black pixels on a BluRay.
Ive read different things like cropping the sides and resizing to 480p.
I've also read things like leaving the original resolution/cropping/adding black borders via avisynth.
I've done several tests, but I just want to know the "BEST" way that the OG's in here would recommend. Before I take the plunge and encode many seasons lol.
I don't know if this matters, but it's getting encoded for a Plex server. However, I would like to make this the best for maximum playback compatibility.
I appreciate the help!
jlw_4049 is offline   Reply With Quote
Old 1st May 2020, 19:11   #2  |  Link
stax76
stax76's Avatar
I think it's one of the favorite topics of hello_hello, maybe here:
https://forum.doom9.org/showthread.php?t=163218
Old 1st May 2020, 19:16   #3  |  Link
jlw_4049
Thanks as usual Stax!
Old 5th May 2020, 15:09   #4  |  Link
Ghitulescu
Ghitulescu's Avatar
Since both DVD and BD have a fixed frame size, "cropping" away won't result in any standard DVD/BD if we stick to the definition in the dictionary. If you want compatibility you have to stay with 720 (or 704)x480 and 1920x1080.
The best does not exist here and it depends anyway on what you want to do. Cropping away is not only not the best but it is also illegal by the book.
Born in the USB (not USA)
Old 6th May 2020, 07:41   #5  |  Link
hello_hello
Time for a shameless plug.... assuming you're using Avisynth.
https://forum.doom9.org/showthread.php?t=176667
There's usage examples in the second post, but if you're wanting to resize to square pixel dimensions here's a short(ish) explanation. To stretch the width without resizing the height, you'd specify zero for both the width and height, followed by your desired cropping, followed by the DVD's display aspect ratio or sample/pixel aspect ratio, followed by the argument for disabling height resizing. The script will take care of the rest.
CropResize(0,0, 6,20,-8,-22, InDAR=16.0/9.0, ResizeWO=true)
If you're not fussed about having specific output dimensions but you want to resize to a specific width, you can specify the width and any cropping etc, and the script will take care of the height.
CropResize(1024,0, 6,20,-8,-22, InDAR=16.0/9.0)
If you want specific output dimensions you need to remember the script will crop to prevent aspect error, but if you want every encode to have the same dimensions... for example 1024x576, which is 16:9.... the script will apply any specified cropping, then any extra cropping required so the remaining picture is 16:9 (any specified cropping is the minimum cropping), then it'd resize to 1024x576.
CropResize(1024,576, 6,20,-8,-22, InDAR=16.0/9.0)
Normally if your cropping didn't result in the cropped picture having the appropriate aspect ratio, the resizer would stretch or squish it. CropResize crops instead to prevent that. Often it's only necessary to specify a width and/or use ResizeWO mode, but specifying both a width and height makes it easy to ensure a bunch of related encodes have the same dimensions, without having to calculate aspect error for each one and adjust the cropping to minimise it.
Personally, I either resize to square pixel dimensions or I don't resize at all (just crop) and keep the original pixel aspect ratio when encoding. That's generally fine for x264 but it's probably better to resize to square pixel dimensions for Xvid. Keep in mind, stretching the width before encoding will mean there's more video to encode than if you encoded anamorphically, so the resulting file size will be greater for a particular encoding quality.
As for the pixel aspect ratios.... there's an explanation in the help file under the InDAR description, and a link to the table here.
https://forum.doom9.org/showthread.p...27#post1058927
You generally only need to decide between using a generic aspect ratio or an mpeg4 aspect ratio, but instead of using the pixel/sample aspect ratios you can specify the display aspect ratio for CropResize. So for a generic pixel aspect ratio you'd specify InDAR=16.0/9.0 or InDAR=4.0/3.0. For an mpeg4 pixel aspect ratio it's InDAR=20.0/11.0 or InDAR=15.0/11.0. That applies to both PAL and NTSC.
If you resize with the script, you must specify an input DAR or SAR for DVDs, because the shape of the pixels needs to be factored into the resizing calculations. You can also specify an OutDAR or OutSAR rather than resize to "square pixel" dimensions, and the script can add borders if need be, but unless you're encoding for an industry format such as DVD, I'd just crop the black and resize.
PS. Always use InDAR=15.0/11.0 for 4:3 DVDs. If there's not much black down each side of a 16:9 DVD, InDAR=16.0/9.0 is more likely to correct, especially for newer DVDs. For older DVDs or DVDs with a substantial amount of black on the sides, InDAR=20.0/11.0 is a safer bet. The difference isn't huge anyway. Around 2%.
Cropping DVDs works the same as for cropping Bluray. If you only crop, the pixel/sample aspect ratio doesn't change because the pixels are still the same shape, but there's less picture so the display aspect ratio changes. Resizing, at least for the purpose of this discussion, changes the pixel/sample aspect ratio, but it shouldn't change the display aspect ratio. ie
A 16:9 PAL DVD is 720x576 but the player will resize it to 16:9, so it's display dimensions are 1024x576. Therefore if you resize to 1024x576 and encode, the display aspect ratio hasn't changed, but the shape of the pixels did (and there's more of them). Obviously if you resize 1920x1080 to 1280x720 the display aspect ratio remains the same, and because the widths and heights have same proportions, the PAR didn't change either.
Old 11th May 2020, 20:52   #6  |  Link
orion44
None
orion44's Avatar
When resizing the DVD, what should be the minimum multiple for width and height (32, 16, 8, 4, 2)?
I'm planning to encode with Xvid/Divx. Is it allowed to go as low as 2 or 4?
orion44 is offline   Reply With Quote
Old 12th May 2020, 07:19   #7  |  Link
kalehrl
I think some Xvid dvd player have problems with mods below 16.
16 is OK, 32 is overkill.
kalehrl is offline   Reply With Quote
Old 12th May 2020, 11:36   #8  |  Link
hello_hello
32 is mod16.
As kalehrl said, it depends on the player. You'll need to test it. The mod16 thing probably only applies to old DVD players capable of playing AVIs etc. A modern player should be happy with mod4, but if you're using a modern player, why encode with Xvid?
Old 12th May 2020, 18:03   #9  |  Link
orion44
None
orion44's Avatar
I don't like the look of x264 encoded movies, even with low deblock settings.
To me, DivX/Xvid gives more "warmth" to the video and higher fidelity.
Old 12th May 2020, 19:07   #10  |  Link
videoh
Useful n00b
Any way to quantify that, or are we doing the feelings thing?
Old 12th May 2020, 20:55   #11  |  Link
orion44
None
orion44's Avatar
Can't explain it. DivX/XviD always looked better to me when archiving DVDs.
I only use x264 for youtube uploads, because file sizes are smaller and the quality doesn't matter that much.
Old 13th May 2020, 11:38   #12  |  Link
Boulder
Pig on the wing
Boulder's Avatar
For DVDs it could well be true, although it would be interesting to see a comparison of XviD and x264 using the same bitrate for the same video. And post the settings as well, easier to see if there's anything to be done.
Old 23rd May 2020, 08:59   #13  |  Link
Katie Boundary
Katie Boundary's Avatar
By "warmth" he means macroblocking and JPEG noise. Those always make me feel warm and fuzzy.
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
