Old 19th January 2020, 19:43   #1  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
[HELP] DVD incorrect schema
Hi, folks.
I have original DVDs and using Ripit4Me, was created ISO files. When I want playback, when finishing VTS_02_1.VOB should jump to main menu on VIDEO_TS.VOB, however the video stops.
I try VTSFix but dont fix it. With IFOEdit could be solved?
Thanks in advance.
Links for testing:
https://drive.google.com/file/d/11pqXTia1yhhpV_kfkRCVNiVm7SPQIlWP/view?usp=sharing
https://drive.google.com/file/d/14eGghM_YhkbX3FHFHU6dOCjP15vVRUyF/view?usp=sharing
https://drive.google.com/file/d/1YjBA1v2yltBScehaC6T0is1KNLv0mjkA/view?usp=sharing
https://drive.google.com/file/d/1bljN5M1z1ijruvRTfiTrzwz84W2nmD5G/view?usp=sharing
https://drive.google.com/file/d/1eF0tHjxuy2_LyqMy3SW-zMgoeh_qh5x-/view?usp=sharing
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 23rd January 2020, 21:56   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Maybe using mega.nz ? I seem to hesitate subscribing to Big G anway...
Old 25th January 2020, 15:45   #3  |  Link
Overdrive80
Anime addict
Could try it now?? Thanks. I changed rights access.
Old 27th January 2020, 21:44   #4  |  Link
Sir Didymus
Hi Overdrive80... :-)
I made a quick check and it seems to me the structure of your DVD is OK. Perfectly OK, I would say...
VTS_02_1.VOB contains title2, which is just a 18 sec. "manga films" splash clip.
After this there is a 17 sec. copyright note.
Afterwards the navigation jumps to the Root Menu of the VTS_02 which jumps to the VMGM title menu, as it should, and as you are expecting...
Which player are you using? It's a SW player right? Change it! :-)
P.S. Ha, forget about IfoEdit, OK? The right tool to analyze and edit the DVD navigation is PgcEdit, thanks to r0lz, who spent years and years of dedition to produce this fundamental instrument for the benefit of the community...
Cheers,
Sir Didymus is offline   Reply With Quote
Old 27th January 2020, 22:29   #5  |  Link
Overdrive80
Anime addict
I am using MPC software, although I had tried PowerDVD and the issue is not raise. Surely, MPC doesnt read properly schema of DVD. Thanks you all.
