30th March 2017, 14:15 | #1 | Link | ||
Matroska find' ich toll
IFO parsing - Audio+Sub StreamID's
Hi all
PGC Title 3 uses for the first audio stream a streamID 3 (0x83) and normally is this audio track 4 but there is no audio track 4. The streamID 3 is used for audio track 1(ID 0). However, my main question is which Bytes reads IfoEdit to get info which streamID correspond to an audio/subtitle track. Last edited by hubblec4; 30th March 2017 at 14:18. |
30th March 2017, 16:17 | #2 | Link |
You got the answer in the gleitz forum.
The properties are common for all 3 PGCs that are there. In PGCedit you should have a better view of what's there (at least for me it's much better presented there than in IFOEdit). So, there are streams 0 and 2 for probably DE and EN, as you said and yet another one, #1 which appears to be the director's comment, according to you. The whole problem comes from the fact that the first and only stream of the last PGC is again EN but has a different stream ID, to be differentiated from the original EN one. As Ligh explained to you in the same thread, the streams are numbered from 80 for AC-3, so the first 0 is 80, the second is 81 and so on... In your case the first PGC has the audio 1 as stream 0 and audio 2 as stream 2. The second PGC has 3 audio tracks, streams 0, 2 and 1 in this order. The last PGC has only one audio, but it has stream ID 3. Is this you wanted to know?
Born in the USB (not USA) |
31st March 2017, 08:46 | #3 | Link |
PgcEdit daemon
Yep, Ghitulescu is right. Apparently, in its summary, IfoEdit groups together the tracks with the same language. It's somewhat confusing, as it seems that there are only 2 tracks but 3 physical streams, but when you examine the Domain Track Attributes with PgcEdit, you see that indeed there are 3 tracks, with two tracks in English plus one in German. They are really 3 different tracks, and not two tracks with one bizarre track with two physical streams, as suggested by IfoEdit.
Nothing to worry about. This DVD is perfectly legit. Here is the list of the tracks of Title 2 (the main movie) as displayed by PgcEdit's Info -> PGC. The PGC uses 3 audio tracks, as you can see in red. Note the stream numbers (0, 2 and 1). They are not in the usual order, but that's perfectly legit. Since the 3 tracks are encoded in AC3, you have to add 0x80 to obtain the stream IDs (0x80, 0x82 and 0x81). The ID can be deduced from the track status (bits 8-15). That corresponds to the info displayed by IfoEdit, although I don't think that grouping the tracks by language is a good thing. Code:
VTST 1 , 2 TTN 2 (2:28:05) Title 2 - Chapters: 44, Programs: 44, Cells: 103 Playback time: 02:28:05.14 (at 25 fps) PG Playback mode: sequential PUOs: 4194304 (0x00400000) - Angle change (0x00400000) NextPGCN: 0 PrevPGCN: 0 GoUpPGCN: 0 PGC Still Time: 0 Audio track 1 status: 0x00008000 (stream=0) Audio track 2 status: 0x00008200 (stream=2) Audio track 3 status: 0x00008100 (stream=1) Subpic track 1 status: 0x80000000 (streams for 4:3=0, wide=0, letterbox=0, pan&scan=0) Subpic track 2 status: 0x80010100 (streams for 4:3=0, wide=1, letterbox=1, pan&scan=0) Subpic track 3 status: 0x80020200 (streams for 4:3=0, wide=2, letterbox=2, pan&scan=0) Subpic track 4 status: 0x80030300 (streams for 4:3=0, wide=3, letterbox=3, pan&scan=0) Subpic track 5 status: 0x80040400 (streams for 4:3=0, wide=4, letterbox=4, pan&scan=0)
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 31st March 2017 at 08:51. |
31st March 2017, 11:21 | #4 | Link |
Hi r0lZ
Title 1 and Title 2 are ok, all streamID's match to an audio track where I can find more info(channels, codec etc.). Title 3 has one audio with streamID 0x83 (33536) which means audio track 4, but there is no audio track 4. Title 3 uses audio track 1(ID 0). Same thing with the last Subtitle stream from PGC-Title 1: you find the streamID 5 which means subtitle track 6 but there is not present (track 5 will be used). |
31st March 2017, 14:08 | #5 | Link |
PgcEdit daemon
Oh, yes, it seems that the audio track of Title 3 uses stream 0x83. That's bizarre and probably an authoring error, but that doesn't mean that that physical stream doesn't exist in the VOBs. Use VobEdit to verify. If it exists and can be played, then I suppose that the best thing to do is to leave it as it is. Else, try to replace it with stream 0, 1 or 2, until you find the correct audio stream. Anyway, title 3 is very short (26 seconds) and is probably just a studio logo. If I were you, I would just bypass it or remove it completely.
For the last subtitle track of title 1, it's the same thing. If stream 0x25 doesn't exist in the VOB and you are sure that stream 0x24 has the right content, just fix the stream number. It's easy with PgcEdit.
31st March 2017, 14:23 | #6 | Link |
He confounds the streamIDs with their corresponding order. And this is why he's confused. It's not an authoring error.
streamIDs are given only to help separate the streams from each other. A stream may contain whatever one wants. This is a double indexing. That's why one has to look in the tables to see "who's who". Otherwise one would simply needed only to parse the PS by itself, without the need for the PGC tables.
31st March 2017, 15:07 | #7 | Link |
PgcEdit daemon
I agree, although usually the ID corresponds to the stream number. But in this DVD, things are complex and not really well done. In the case of the short title 3, it is surprising that a new physical stream is created just for that track. It could have used one of the existing streams. Furthermore, 3 tracks are defined in the Domain Track Attributes, but only title 2 uses them all. That means that there are unused tracks in Title 1 and 3, and they are normally visible in the list of audio tracks shown by the player, although they are not connected to a real physical stream. The presence of "gaps" in the tracks is well known to cause problems with some players. Therefore, if it's not really an authoring error, it's at least a good example of what should never happen. Ideally, the 3 titles should have been authored in different titlesets, with a correct mapping of tracks and physical streams, and the exact number of really available tracks, without ambiguity.
31st March 2017, 15:26 | #8 | Link | |||
I can't edit the IFO's from a physical disc. Quote:
And when I have such DVD's with "streamID-issues" the mkv-creating process is then maybe not correct. PgcDemux handle this DVD correct and the streamID's are identical to IFOEdit (so I think it is not an authoring error, or both programs uses the same workaround). Log for Title 3 -> VobID 67 Code:
[General] Total Number of PGCs in Titles=3 Total Number of PGCs in Menus=36 Total Number of VobIDs in Titles=67 Total Number of VobIDs in Menus=70 Total Number of Cells in Titles=139 Total Number of Cells in Menus=70 Demuxing Mode=by VOB Id Demuxing Domain=Titles Total Number of Frames=671 Selected VOBID=67 Number of Cells in Selected VOB=1 Selected PGC=None Number of Cells in Selected PGC=None [Demux] Number of Video Packs=9088 Number of Audio Packs=640 Number of Subs Packs=0 Number of Nav Packs=45 Number of Pad Packs=0 Number of Unkn Packs=0 [Audio Streams] Audio_1=None Audio_2=None Audio_3=None Audio_4=0x83 Audio_5=None Audio_6=None Audio_7=None Audio_8=None [Audio Delays] Audio_4=-32 [Subs Streams] Subs_01=None Subs_02=None Subs_03=None Subs_04=None Subs_05=None Subs_06=None Subs_07=None Subs_08=None Subs_09=None Subs_10=None Subs_11=None Subs_12=None Subs_13=None Subs_14=None Subs_15=None Subs_16=None Subs_17=None Subs_18=None Subs_19=None Subs_20=None Subs_21=None Subs_22=None Subs_23=None Subs_24=None Subs_25=None Subs_26=None Subs_27=None Subs_28=None Subs_29=None Subs_30=None Subs_31=None Subs_32=None The audio stream control mechanism is for me like the same in Matroska "ChapterTrackNumber" mechanism. 3 physical audio streams but only 2 streams are availble for this Title. I'm right? |
31st March 2017, 15:41 | #9 | Link | |
Exactly, and I would like to know how IFOEdit(and PgcDemux) parse this. In IFOEdit's "VTS Overview" has the first audio stream 2 ID's and this info I need too. |
31st March 2017, 15:56 | #10 | Link | |
Title 1 is the Theatrical edition with 2 Audios(en,de), Title 2 is the Director's Cut and has 3 Audios(en,de,en-comment). Like you said, all 3 audios are available/selectable in a player for Titel 2 only. IFOEdit/PgcDemux reads this info from the IFO. When I parse the Audio Stream Control of PGC-Title 3 and I get 0x83 as streamID, what I have to do to know which audio track is used? |
31st March 2017, 16:15 | #11 | Link | ||
PgcEdit daemon
Title 1 has only 2 (real) tracks, and they use streams 0x80 and 0x82. Some players (or muxers) will show the track 3, but it cannot be played because it is not linked to any physical stream. It's why I don't like at all that kind of authoring, although it is legit. Title 2 uses the 3 first physical streams and it's correct. The mapping is somewhat unusual (0x80, 0x82, 0x81) but that should never be a problem. AFAIK, all players will play the correct stream. I don't know if all muxers will include the tracks in the right order, but that's another problem, not related to the DVD itself. Title 3 is the most bizarre. It uses only a single track (and has therefore 2 useless tracks that may be displayed anyway by bad players or muxers), and that track is linked to the fourth physical stream (0x83). That means that the two long tracks 1 and 2 must have a (probably silent) fourth audio stream, just because it is necessary for title 3. IMO, that's really bizarre, and I would have authored that 3 titles in different VTSs, just to define exactly the number of tracks that are really useful. That would have been much more easy to understand, and almost all DVDs are authored that way. But that doesn't mean that this DVD is not legit. It's just stupid. BTW, the confusion of the track as seen by the user (with a specific language and perhaps additional info such as "director comments") and the physical streams in the VOBs (identified by its stream ID, like 0x80) is mainly due to the extremely confusing names given to them by the "experts" who have created the DVD-Video specs. The tracks and streams are called with the same word: stream! And you can read absurd things like "A subtitle stream can be made of one or several streams." 1 = 2! It's why I prefer to use the terminology adopted by mpucoder for muxman: "track" for the logical stream presented to the user, and "stream" (or, better, "physical stream") for the real stream muxed in the VOB. The VTSI_MAT table in the IFO defines the tracks, and the PGC table links that tracks to the physical stream in the VOB. The unusual thing with your DVD is that there are tracks defined in the VTSI_MAT table but that are not linked to a physical stream in the PGC. It's extremely rare, extremely confusing, extremely stupid, but not illegal.
31st March 2017, 16:28 | #12 | Link | |
PgcEdit daemon
The PGCs are defined in the VTS_PGCITI table (for the titles) and VTSM_PGCI_UT table (for the menus). Each stream has simply a single value (called by IfoEdit "stream status"). Bits 8-10 contain the stream number. Bit 15 is set to 1 to mean "enabled". For example, if you examine the PGC of Title 1 in IfoEdit, you will see that the two defined streams have values 0x8000 and 0x8200. Their numbers are therefore 0 and 2, and since they are AC3 streams, they have the stream IDs 0x80 and 0x82. The 6 other audio streams are not used and have a status of 0. (The "bad" players or muxers should simply verify if bit 15 is set for a specific stream, and if it's not the case, that mean that it is not used, and it should of course not be presented in the list of available streams or muxed in the final MKV.) Since there are 4 different display modes for the subtitles, there are also 4 streams, and the status is a 32-bit number. Bit 31 is the "enabled" flag, and the other bits contain that stream numbers for the 4 possible display modes.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 31st March 2017 at 16:36. |
31st March 2017, 17:21 | #13 | Link | ||
The other one has only 2 of them because it uses also cells that have only 2 audio streams in their payload and nobody knows what would happen when the player, set to play the third track, reaches one of these cells: mutes, skips, stops, locks down, loops indefinitely looking for an $83 packet that never comes etc etc etc.... Quote:
I repeat: why? You want to demux them? If so, then use PGCdemux and live happily ever after... DVDshrink can do it too (stripping one language)
31st March 2017, 18:30 | #14 | Link |
@ r0IZ
Many thanks for your explanations. Yes this DVD seems very special authored and now I know that mpc-hc is a "bad" player. PgcDemux should not demux the 3. audio(directors comment) for Title 1 but it does. MKVToolNix(MTX) identify mode recognize all 3 audio tracks and set the correct streamID's. All 3 audios are in the vobs for all VobID's of Title 1 and 2 available, I expect no muxing errors while appending the vob's in MTX. It seems to me that audio 3(en-DC'comment) is simple disabled for Title 1 but it exists as real track. This behavior is implemented in Matroska. @Ghitulescu PGCdemux is used for demuxing, right, but without correct track order for audio and subs it will be hard/not possible to create multi-edition-mkv's. My DVD2mkv editor is not so good like makemkv, I need extern programs and so on, but makemkv will be never able to mux such multi-edition-mkv's. For Bluray is it much more simple and works already. |
1st April 2017, 18:55 | #15 | Link | |
But anyway, should this be the case, just edit the DVD in PGCEdit and remove the offending PGC3. Or blank it in VobBlanker or or or or...
2nd April 2017, 11:19 | #16 | Link | |
To remove/blank something is not the right solution. The Alien1-4 DVDs are crazy authored and mkvmerge has a bit problems with the sound tracks. A mux with MTX (direct from dvd), results with asynchronous audio. For my tests I use makemkv and there are no sound problems, and for the Directors Cut the commentary audio track available only(not for the theatrical version). (really nice) A demux with Pgcdemux (option: create PGC-vob) have the same sound problems, so I guess such complicated authored DVD's can not correct handled(MTX, PGCdemux...). |
2nd April 2017, 12:45 | #17 | Link |
PgcEdit daemon
If I understand correctly the problem, you want to keep Title 1 and Title 2 in a multi-edition MKV, and you need the same tracks in the two titles as otherwise you can't combine the two titles in the same MKV. Right?
Try to define the missing audio track in Title 1. That should be easy with PgcEdit. Of course, you have to copy (or decrypt) the DVD to HDD first, but anyway, working on a physical DVD is never easy, and is even impossible if it is encrypted. Open the DVD in PgcEdit and double-click the PGC in the left pane to open the PGC Editor. In the "Audio Track to Stream Map" section, click the third button (#2, the first button with the label "none"), move the slider to 1 and click Set. OK the PGC Editor. Save the IFOs. That's it. Now, PGC 1 and 2 have exactly the same number of audio tracks, in the same order. It should be trivial to mux them to the multi-edition MKV, with your usual tools. Of course, the content of the third audio stream may be bizarre when you play Title 1, but it should be OK when playing the director's cut. BTW, when you are in PgcEdit, you can also delete Title 3 if it causes other problems (but I don't think it's necessary). If you do it, you can ignore the problems of the broken navigation, since you will never play the edited DVD. You just need the correct PGC structures.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 2nd April 2017 at 12:47. |
2nd April 2017, 17:52 | #18 | Link | ||
PgcDemux and MKVToolNix(MTX) (identify mode) gives me the same stream ID's with the same order. This info's are different to info in the IFO. For Title 1 and 2 are all 3 audio tracks available while demuxing with PgcDemux or direct muxing with MTX (but with a different order). My second test with the first Alien DVD is more confusing. The 4. audio track is a dts stream with 0x89 as ID, but I can't found this ID in the Audio Stream Control Table. In my old DVD2mkv editor I use from the VTSI_MAT table all info for audio and sub tracks (order, codec etc.) But the order don't match for the Alien DVD's and now I will recode it so it will work. Quote:
2nd April 2017, 18:12 | #19 | Link |
PgcEdit daemon
I don't understand why you need the streams in a specific order. Anyway, as we have explained above, the tracks are just soft links to the real physical streams, and are what the player should present to the user. In your case, they are: English, Deutsch, English (director's comments, although it's not specified in the IFO).
They map respectively to the physical AC3 streams 0, 2 and 1, in that strange but legit order. Therefore, the English audio has the ID 0x80, Deutsch 0x82 and DC 0x81. If the program you use to demux or remux the tracks gets them directly from the VOB without taking the IFO into account (bad!), chances are that they will be presented in the order EN, DC, DE. Anyway, if after having created the MKV, you find that the language code or track labels are not correct, it is easy to change them with MkvPropEdit (from MTX). I'm not sure you need to create the missing track link as explained in my previous post, since apparently all tools find the 3 (or 4?) streams anyway. If you do it, you have to use PgcEdit, and no, it's not a CLI tool. Again, I don't understand why you want to use the CLI for such a simple process. Apparently, you need to make things much more complex than they are. Or is it because you work under Linux? In that case, use Wine HQ. PgcEdit works correctly under Wine (but you may have to change the default fonts, and the preview doesn't work.)
2nd April 2017, 18:24 | #20 | Link | |||
The Alien disc is not crazy authored. It is authored as any other big projects that have to be flexible for being launched on several incompatible markets in short times one after the other. That you do not understand the logic is not their fault - remember, the studios check every project for 100% compliance with the DVD specs, some even have various DVD players for an extra check. Maybe your methods, I am still on serious doubts on what you intend to achieve, are "crazy" because they do not cope with the reality ? PS: some features of the DVDs cannot be replicated or worked by no consumer tools, and some cannot be replicated by any tool except those two used in studio (neither is Scenarist, to prevent any misunderstandings). If any of such discs is worked outside that restrictive world, one has to take a decision on which features have importance, which cannot be done and which can be dropped. Multiangle for instance can only be managed by changing the container as no muxer today can do it properly. I have no problems with this: I pick up the director's cut when available or the extended cut against theatrical one, and the original movie "angle" (mostly used to display an alternate credits).
