14th March 2020, 13:24 | #961 | Link |
2020 matrix is a known issue, I'll add it when I can.
VirtualDub2 |
17th March 2020, 11:38 | #963 | Link |
LoadVirtualDubPlugin:- http://avisynth.nl/index.php/Plugins
EDIT: For usage, Advanced Search for "LoadVirtualDubPlugin" , select 'posts', not 'threads', and in Avisynth 'Usage forum'.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 17th March 2020 at 14:00. |
17th March 2020, 14:54 | #964 | Link |
But ... for many VirtualDub(2) plugins, there are equal (if not even superior) AviSynth plugins available, often for VapourSynth as well. Loading VirtualDub plugins in AviSynth is only recommendable for those without a match.
18th March 2020, 04:10 | #966 | Link |
I want to load the VirtualDub2 Plugin "Deinterlace-Blend fields-Keep top fields,interpolate/discard bottom fields" to my avs script,
but I can't find its vdf file and don't know how to set the filtername for its plugin function. +++++++++++++++++++++++ Would anybody give me a hand,please? Last edited by hintlou; 18th March 2020 at 04:15. |
18th March 2020, 09:08 | #967 | Link |
I believe such basic functions are not a plugin, but in the application core.
Apart from that, discarding and interpolating one field can be achieved easily with AviSynth core functions (SeparateFields, SelectOdd/Even, *Resize). And it would be one of the worst methods to deinterlace. Why waste quality intentionally (except for academic purposes, to show how bad this result is)? Recommendable deinterlacers which don't discard a field but use adjacent fields to reconstruct content are, from fast to precious: Yadif(mod), TDeint, QTGMC (that one has a complex installation but will be worth the efforts). |
18th March 2020, 13:57 | #968 | Link |
Thanks for your advice.
I know it's not a modern deinterlacing method. But the Blend fields plugin of VirtualDub2 can offer me the effect I need in some dvdripping cases. So can the plugin be loaded in avs scripts? I really really need it be loaded in my avs scripts instead of being loaded in VirtualDub2 only. I want to separate the different parts of pictures in video for differently deinterlaced. Last edited by hintlou; 18th March 2020 at 14:01. |
19th March 2020, 08:13 | #969 | Link |
For the "deinterlace" filter, the responsible "Module" is "(internal)", so it is not a plugin but code in the EXE.
If it is not a plugin, it cannot be loaded. But it can be executed equivalently with AviSynth core functions. Last edited by LigH; 19th March 2020 at 08:16. |
21st March 2020, 16:35 | #972 | Link |
Thanks.I tried them:
"FieldDeinterlace(blend=true,full=true)" : the deinterlacing quality is bad... "TDeint(mode=2)" this is a blend mode: the deinterlacing quality is ok,but the blending effect is different from the Blend fields plugin of VirtualDub2. I don't have 32bit softwares so "SmoothDeinterlace()" isn't suitable. |
25th March 2020, 03:54 | #976 | Link |
Is it not possible to use CineForm in a .mov using fast recompress? I have AVIsynth spitting out V210 and CineForm is set to 10-bit 4:2:2 and says it will use V210 with no conversion and I get a Video format negotiation failure when using fast recompress. It tells me to use normal recompress or full processing mode.
25th March 2020, 04:49 | #977 | Link | |
The short version - nothing funky is going on with full recompression. Make sure you set it up as 10bit in the cineform configuration and YUV 422 10bit. You're actually sending p210 (planar 10bit 4:2:2) with avs script (check with vdub2's file=>file information) and it'a a conversion to v210. It's a lossless re-arrangement of pixel format required for cineform which does not support p210 If you use vapoursynth, there is an enable_v210 switch that sends v210 instead of p210, and you can use fast recompress |
25th March 2020, 09:30 | #978 | Link | |
No idea if this helps:- http://avisynth.nl/index.php/Interna...PT_Enable_V210
25th March 2020, 15:09 | #979 | Link | |
25th March 2020, 16:04 | #980 | Link | |
