21st July 2013, 15:21 | #82 | Link | |
There are also wipe effects (used for karaoke). One thing to consider when choosing to make subtitles "white" is if you intend to display them on a TV you should not make them 100% opaque and 100% white because it will look blindingly bright if the movie background is dark and you're watching in a dark room. Better use a light grey color and make the subtitles slightly translucent so that they can adapt to the brightness of the movie background to some degree. My recommendation based on my exhaustive subtitle creations is a color of around 230,230,230 and an opacitiy of 66-75%. When it comes to visibility I'm 50/50 about white vs yellow. Both can be read equally well from all kinds of backgrounds if only the (black!) outline is thick enough which from what I've seen is rarely the case unfortunately. My recommendation for outline width: about as thick as a stroke of the characters used. |
21st July 2013, 15:44 | #83 | Link | |
SuperVirus
But I agree, it would be very-nice if (xy)VSFilter had an option for easily overriding the color palette from the IDX files. While this doesn't happen, you could give a try to Mplayer --- because Mplayer completely ignores the color palette from the bitmap subs and gives you "simple white fonts" all the time Last edited by filler56789; 22nd July 2013 at 22:37. Reason: typos, argh :-( |
21st July 2013, 17:44 | #84 | Link |
Thanks for your effort to bring us this software, works great.
While testing various files, I've encountered a rather curious behavior. I have a file that has crazy subs effects (around 10k lines in ~7 seconds), after adjusting madVR CPU queue to 24 this effects plays fine on my PC, with no dropped frames, but ~25 seconds later (with only simple text on screen) the playback freezes completely for a few seconds, also freezing the player controls, the sound plays fine. The playback then recovers with ~150 dropped frames. What's curious is it only freezes if you play the file without pausing and seeking. If you seek somewhere between the heavy effects and the moment it freezes the playback goes over this part flawlessly as expected. It might be caused by the caches being emptied all at once. I'm not opening a bug report, since I would like to confirm first, whether it's XySubFilter or madVR causing this. Below is my system config: Code:
Intel Core i5-3570K Intel HD4000 16GB RAM Windows 7 x64 MPC-HC 1.7.0.7646 (f6f1b82) (official nightly build) LAVFilters 0.58.1 (official release) XySubFilter 3.0.546 (official beta release) madVR v0.86.10 (official release)
Link to the file in question: Code:
http://www.mediafire.com/download/cl9plddqpfa0c80/Shingeki_subs_test.zip I know the subs in this file are crazy, but inspecting this might help improve performance in other extreme cases. Thanks for your time and please tell me, if I've overlooked some important info. |
21st July 2013, 20:13 | #86 | Link |
I must admit I snickered when I saw the filename. So I guess Commie's typesetting make intel CPUs stutter as well :P
Before that, Koharubi's bakemonogatari ep02 @1080p was my benchmark for subtitle renderer performance, but xySubFilter masters that one thanks to the cache (it had a half second alternation of two typesets covering the whole screen) |
21st July 2013, 20:58 | #87 | Link | ||
Wouldn't it make more sense to keep all subtitle options out of madvr to reduce user confusion? There currently is one but wouldn't it be better for subfilter to instruct madvr how to handle that code instead?
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
21st July 2013, 22:11 | #89 | Link | |
But if you want help, press ctrl+j to bring up madvr info, and look down to the queue information. During playback watch the queues, problems usually occur when they fall to very low values (0) - you'll likely find frames dropped/delayed when that happens. If so, try increasing those queue sizes. If not it may be a memory flushing thing which I have no clue whatsoever about. Edit: I can reproduce the problem, both in the file you gave me and in Commie's Shingeki ep1v2 - the one with 90k lines - a completely different file. Same thing happens, video freezes and subtitle queue just empties. Other queues are fine. Xy-vsfilter is the old one and has a stable release, xy-subfilter is the new, improved version but is currently in beta testing, and can only be used with madvr. Last edited by Moragg; 21st July 2013 at 22:23. |
21st July 2013, 22:32 | #90 | Link | |
2) If I want to use xysubfilter is it necessary to have xyvsfilter installed or not? 3) What are the ameliorations in comparaison with xyvsfilter? |
21st July 2013, 23:00 | #91 | Link |
Software Developer
This is just a heads-up to Zoom Player users,
I plan to add support for this interface in the next release, you will probably see a beta within the next month as I'm currently focusing most of my time on Zoom Commander and other non-coding chores. |
21st July 2013, 23:20 | #92 | Link | |
2)No. 3)Not entirely sure, but perhaps: better colour accuracy, faster. I know it renders subs at a different res. And in madvr you can make it optimize performance if you have a slow CPU. |
22nd July 2013, 02:10 | #93 | Link |
Any reason why xySubFilter would work flawlessly for files with subtitles in the container, but refuses to show up for files with only external subs? In some rare cases it does show up, but I have no idea why it won't always show up.
Any ideas? My setup: Win 8 x64 MPC-HC 1.7.0.7646 madVR 0.86.10 LavFilters 0.58.1 xy-vsFilter not installed (didn't work even if installed) |
22nd July 2013, 04:11 | #94 | Link | |
Broadband Junkie
I noticed this exact same issue with the original script in your sample the other day. Not sure what causes it at the moment, we are looking into it. I'll attach the sample you provided to the issue, but at this point I'm more interested in obtaining any other scripts which are able to trigger this bug. |
22nd July 2013, 04:17 | #95 | Link | ||
2.) Correct. (no) 3.) The main difference between the two is that xy-vsfilter sits in the DirectShow chain as a link between video decoder and the video renderer. It overlays subtitles onto the video frames it receives from the video decoder and then passes the result on to the video renderer. This is has following disadvantages for the typical end-user: - the subtitles will be rendered at the video resolution (and with chroma sub-sampling if applicable), so for videos whose resolutions are much lower than the display resolution they may look blurry or aliased. - DXVA2 (native) does not work because it requires a direct connection between the video decoder and the video renderer. - rendering in the black bars can be problematic, because xy-vsfilter does not really know the target rectangle and changing resolutions during runtime may introduce some problems. XySubFilter on the other hand renders at the display resolution (without chroma sub-sampling) by default, which makes the subtitles always look sharp. It is not connected to the video decoder at all, but only sits between the splitter and the renderer. Since the video decoder can now directly connect to the video renderer again DXVA2 (native) will work fine. Concerning colors: xy-vsfilter will also have "correct" color handling (similar to XySubFilter) - or rather has the most important stuff already. This is more of an advantage of XySubFilter over MPC-HC's internal renderer (this is related to historic limitations of the old vsfilter, which didn't know anything but limited range BT.601 colors, resulting in obscure workarounds which break colors with MPC-HC's internal renderer/VLC and a bunch of others. A new extension of the ASS "spec" is supposed to harmonize the different renderers again to some extent.) Any performance differences should ideally only be related to the different resolutions/color spaces at which they render by default - so new optimizations will likely be used in both versions. The madVR performance trade off option should not make XySubFilter faster than xy-vsfilter - it just relegates some color conversion stuff from madVR to XySubFilter, which uses some simpler conversion on the CPU instead of the GPU like madVR (nothing to worry about - that's why it's on by default. cyberbeing's more technical explanation). xy-vsfilter always has to do these things itself since it does not pass on the subtitles through a separate pin to the renderer but overlays them onto the video itself. About rendering in the black bars: While the new subtitle interface that connects XySubFilter and madVR has been designed with enabling subtitle rendering in the black bars in mind (if the user wishes so), this has not yet been implemented. Last edited by sneaker_ger; 22nd July 2013 at 04:20. |
22nd July 2013, 04:40 | #96 | Link | ||||||
Broadband Junkie
If not, please provide a sample which easily reproduces the issue. Quote:
XySubFilter Requires madVR (or other Subtitle Consumer supporting SubRenderIntf.h) Higher Quality RGB Subtitles Renders subtitles after scaling is performed by the video render (allows high resolution subtitles) Subtitles alpha-blended on the GPU Image based subtitles are scaled to any video resolution Works with DXVA Decoding Allows Deinterlacing via bitstream flags Compatibility option to support anamorphic video Allows all colorspaces supported by the video renderer to be used xy-VSFilter (VSFilter.dll) Works with any video renderer. Lower Quality Usually YCbCr Subtitles Renders subtitles prior to scaling at original video resolution Subtitles alpha-blended on the CPU Image based subtitles are not scaled and must match video resolution Breaks DXVA Decoding Blocks Deinterlacing bitstream flags Requires all subtitles scripts be compensated for VSFilter behavior with anamorphic video Only a more restrictive set of colorspaces supported by xy-VSFilter can be used by the video renderer Quote:
2) Update to the latest MPC-HC x86 nightly build and both filters can co-exist, but it is not required to have both installed. XySubFilter will be used with madVR, while xy-VSFilter will be used by all other renderers. Quote:
Are you positive the external subtitle files have an identical file name to your video? Please double-check by renaming one to the other with copy/paste (not including file extension). Last edited by cyberbeing; 22nd July 2013 at 05:12. |
22nd July 2013, 06:47 | #97 | Link | |||
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 22nd July 2013 at 06:58. |
22nd July 2013, 07:12 | #98 | Link |
Question to developers:
1 - can you merge this 2 menu items section : Then it would be convenient to switch the built-in and external subtitles in the menu 2 - Where can be find source(full or just for interfaces)? It's need for better integration with MPC-BE.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
22nd July 2013, 08:10 | #99 | Link |
I have a file that causes both MPC and madVR to crash when using XySubFilter but works fine when using xy-VSFilter, no crash occurs when subtitles are disabled
10 Second sample- here
I5 3570k OC @4.5Ghz, EVGA GTX 1080 FTW Oced, Asrock Z77 Extreme4, 8GB DDR3 @ 1600Mhz |
22nd July 2013, 08:29 | #100 | Link | ||
Broadband Junkie
Override Style 1) Open your sample in MPC-HC 2) Pause video 3) Right-click MPC-HC window -> Filters -> XySubFilter -> Properties 4) Click "Styles" 5) Click the "Default" tab 6) Edit to bogus value like "Border Width = 10" 7) Click "Ok" to style Dialog 8) Click "Apply" to main setting dialog [note: the need to press Apply here first seems to be a bug] 9) Click "Okay to main setting dialog 10) Style with "Border Width = 10" is applied to subtitles. OR Force Default Style 1) Open your sample in MPC-HC 2) Pause video 3) Right-click MPC-HC window -> Filters -> XySubFilter -> Properties 4) Click "Styles" 5) Click the "Global Default" tab 6) Edit to bogus value like "Border Width = 10" 7) Click "Ok" to style Dialog 8) Check "Force Default" in main setting dialog 9) Click "Okay to main setting dialog 10) Style with "Border Width = 10" is applied to subtitles. 11) Exit MPC-HC 12) Re-open your video 13) "Border Width = 10" is still applied to subtitles Quote:
madVR has much to do with the subtitle interface used by XySubFilter. Unless madVR adds such code to madVR, and offers a way for us to trigger such functionality, there is nothing we can do. You need to make a case to madshi for why he should support such a feature in madVR and the subtitle interface. |
