5th January 2006, 19:21 | #61 | Link | |
I have the following comments and questions: - Sometimes I need to manually position a bunch of SPUs away from the text/graphics in the video. The SPUs were usually sequential in this case, but the change steps had to be repeated for each SPU, and this got hard on the hand. Can you add a button to "Apply last value" for the position box?. - The position slider is good for large adjustment but awkward for small one. Can you add left/right arrows for fine adjustment? - The Sub display position changed in 4:3 TV. Is there a way to preview the Sub position for 4:3 TV screen? - Questions: can Sub font size/type be changed? Thanks and keep up the good work. |
5th January 2006, 19:55 | #62 | Link | ||||
jean
A few PgcEdit guides. DVDSubEdit a free tool to edit subtitles directly inside the vob. Last edited by jeanl; 19th January 2006 at 01:23. |
6th January 2006, 19:11 | #63 | Link | ||
6th January 2006, 19:21 | #64 | Link | |
Jeanl
A few PgcEdit guides. DVDSubEdit a free tool to edit subtitles directly inside the vob. |
6th January 2006, 19:27 | #65 | Link |
Here's an unofficial release, beta 0.72 with the following improvements:
Let me know what you think! Thanks! Jeanl
7th January 2006, 12:26 | #66 | Link |
@Jeanl
Hi. Here is a question... Do you plan to add in DVDSubEdit such features as editing times or delay of SPUs? Or it's impossible because it will require remuxing of VOB?
Кайда барасын, Пятачок? ...let me see you stripped... |
7th January 2006, 16:26 | #68 | Link |
PgcEdit daemon
But you cannot display the subpic before the pack in which it is defined is encountered. I guess you need demuxing if you want full control. It should be possible however to fine tune the delays w/o demuxing.
7th January 2006, 19:34 | #69 | Link | |
But IMHO, the better way to do it is to remux, in place if possible... jeanl
A few PgcEdit guides. DVDSubEdit a free tool to edit subtitles directly inside the vob. Last edited by jeanl; 7th January 2006 at 19:37. |
8th January 2006, 06:09 | #70 | Link |
@Jeanl
Did you think about something like editing demuxed subtitles (.sup)?
Кайда барасын, Пятачок? ...let me see you stripped... Last edited by Sajan; 8th January 2006 at 06:15. |
8th January 2006, 06:30 | #71 | Link |
mmm, no I didn't. There's many tools for that... Do a search on subpic or subtitles in the videohelp tool section, and you'll see!
jeanl
8th January 2006, 19:04 | #72 | Link | |
reMember
8th January 2006, 20:10 | #73 | Link |
Yes, SubtitleCreator is the almost one program that allow this (maybe srt2sup too, I didn't try it yet). But SubtitleCreator still have some bugs... I dont' know any other program that can edit SUP. That's why I'm still looking for a such prog.
8th January 2006, 20:46 | #74 | Link |
Sajan, what are you trying to do to your subpics?
jeanl
8th January 2006, 21:55 | #75 | Link | |
reMember
9th January 2006, 16:51 | #76 | Link | ||
10th January 2006, 09:59 | #77 | Link |
Hi Sajan.
For basic manipulations of sup files, I had recently some nice experience using DvdSupTools: http://web.quick.cz/FKasparek/Softwa...VDSupTools.htm The interface is very poor (command line based) but it very easily allows to decode the sup titles, generating a txt file and, optionally, a very small bitmat for each subtitle. These files can be changed via standard text and graphic editors. Then the new subtitles can be encoded again in the native format via the Subtitle Encoder... Edit: by the way, sorry being definitely off topic... and many, many thanks to jeanl for his excellent tool... Last edited by Sir Didymus; 10th January 2006 at 10:37. |
10th January 2006, 23:06 | #78 | Link |
I have a question for you dedicated users
I've had a couple requests to add regular movie playback so the subs show as the movie plays. That's relatively easy with the preview code (based on dvd2avi), but the problem is, it's without audio!!!! My feeling is that it's nearly useless if you can't hear the audio at the same time you see the subs. How else would you check good synchronization... Do you guys agree? If you do, I probably won't implement the "playback" idea.... Not until dvd2avi can playback audio (which isn't in a while!). jeanl
10th January 2006, 23:16 | #79 | Link | |
Ridendo Castigat Mores
THat way, users could demux the audio track and then load it.
None is as blind as those that don't listen. www.dvdrebuilder.com RME Rockas Software |
11th January 2006, 00:11 | #80 | Link |
Straight to video
On the Hong Kong Legends PAL (R2, R4) disc of Mr. Vampire I have, both subpicture streams have 0-value contrast on all SPUs (b=0 p=0 e1=0 and e2=0) They need to be b=0 p=15 e1=15 and e2=15.
I went about fixing this in DVDSubEdit 0.73, but for some reason, the changes are not being saved to the VOBs. Here's my workflow for reference: 0) Rip to directory on NTFS drive. 1) File | Open full domain | select "VTS_01_1.VOB" 2) Wait for SPUs to load (there's 2 streams, about 2000 total subpics) 3) Edit current subpic | p | move slider to 15 4) Click apply to all selected. 5) repeat steps 3 and 4 for e1 and e2. 6) Click Save All Changes. The progress meter in the status box that opens doesn't "progress", although the preview and subpic info parts of the main window redraw repeatedly for about 1/2 a minute, indicating some sort of activity is going on After the save status box closes itself, the SPUs show that my changes have been applied... but when I re-open DSE and reload the vobs, the contrast values are all back to 0. thanks Edit: Here's what a typical SPU info looks like, after applying changes: Code:
SPU# = 530 StreamID = 0x21 LBA = 36803 V/CID = 1/7 Duration = 3.675s DCSQT: 0 Set Color: e2=1 e1=1 p=2 b=3 Set Contrast: e2=15 e1=15 p=15 b=0 Set Display Area: sx=0 ex=719 sy=2 ey=574 Set field indexes Start End of commands DCSQT: 1 -- Delay 0.034s Set Color: e2=1 e1=1 p=2 b=3 Set Contrast: e2=15 e1=15 p=15 b=0 End of commands DCSQT: 2 -- Delay 3.630s Set Color: e2=1 e1=1 p=2 b=3 Set Contrast: e2=15 e1=15 p=15 b=0 End of commands DCSQT: 3 -- Delay 3.675s Set Color: e2=1 e1=1 p=2 b=3 Set Contrast: e2=15 e1=15 p=15 b=0 Stop Last edited by kumi; 11th January 2006 at 01:34. |
