13th August 2015, 20:10 | #2141 | Link |
4:2:0 hater
Hi there guys. I got a problem to report after upgrading to the lastest nightly in order to try the new audio renderer.
EVR-CP stutters when a combination of LAV Video DXVA2-CB and VSync enabled is used. Steps to reproduce:
It seems that with DXVA Native it also stutters, but a lot less. Using the builds provided here I have located the first nightly that has the issue:
Looking at the log history, several changes were made to EVR-CP between those revisions, so probably one of those caused the issue. If you need more info or testing let me know. Specs in sig. I'll open a ticket too. |
14th August 2015, 09:56 | #2144 | Link | ||
https://github.com/alexmarsev/sanear/releases |
14th August 2015, 20:17 | #2146 | Link | |
4:2:0 hater
15th August 2015, 19:58 | #2147 | Link |
The new sanear Audiorenderer works great here (DVBViewer, LiveTV). Thanks for your work.
Any chance to add some Options (Buffer size, exclusive Mode on/off) to the Audiorenderer directly? For external application this would be a better solution. |
18th August 2015, 02:01 | #2148 | Link |
Karaoke .kar files
Hi guys,
Is there a way to view karaoke MIDI lyrics in MPC-HC? I installed the karaoke for DirectX filter from this link: http://sourceforge.net/projects/karaoke-dx/ Karaoke files now play perfectly with the lyrics displayed in RealTimes 18 and Windows Media Player 12 on Windows 10. However, all MPC-HC does is crash. Is there a way to fix this? Or is there a way to make .kar lyrics display using LAV filters? I attached a sample .kar file. |
18th August 2015, 14:32 | #2149 | Link | |
Thanks
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
18th August 2015, 19:12 | #2150 | Link |
I believe it refers to the "Common Gateway Interface", a way to communicate with applications on the server. Some script languages like Perl or PHP may be used as CGI service (among other ways to use them). I believe that configuring CGI handlers means to describe in which server path the interpreter for which script format, according to its filename extension, is located.
19th August 2015, 09:55 | #2153 | Link | |
I'll try it out during the weekend.
22nd August 2015, 16:51 | #2154 | Link |
1.Internal Audio Renderer wasapi exclusive - stutters
2.Internal Audio Renderer wasapi exclusive and madvr -when connecting an external audio track for a long time thinking, or a black screen and silence. Win 7 64bit audigy Rx mpc-hc 1.7.9.145 |
22nd August 2015, 20:06 | #2157 | Link | |
Wasn't it "always" available? Is your sample 8 bit? Current internal LAV does not allow HEVC 10 bit using DXVA2 native but external nightly already has it activated. So it should be available in MPC-HC in the near future if the renderer supports it. |
22nd August 2015, 20:47 | #2158 | Link |
Yeah you're right
Yeah my source was 8-bit I just checked with my anime 10-bit source I still need dxva-cb to play that back using hardware acceleration. It's nice to know I won't need to do that soon though thanks.
23rd August 2015, 19:07 | #2160 | Link | ||
I'm using Windows Host Script (which comes with newer Windows, >Win7, I think), which should be run with 'cscript.exe': - cgi script receives 1 url encoded argument (the keystroke), url decode it, then send it to the foreground application. MPC-HC web interface setup: - x Serve pages from: ./webroot (we don't have to change Default page value (default is: 'index.html;index.php')) - CGI handlers: '.vbs=c:\Windows\System32\cscript.exe' Save this into file called 'sendkeys.vbs' in 'webroot' subdirectory of directory of MPC-HC (you don't have to deploy anything else to here, all the other pages will be served as well if you need them). The file extension does matter! Code:
'!c:/windows/system32/cscript //nologo ' Toggle source level in MadVR (CTRL+SHIFT+ALT+i = ^+%i = %5e%2b%25i) ' get shell object Set WshShell = WScript.CreateObject("WScript.Shell") ' get Process array that includes the query string Set wshUserEnv = WshShell.Environment("Process") ' urldecode querystring param = unescape(wshUserEnv("QUERY_STRING")) ' send keystroke WshShell.SendKeys param ' delete used objects Set wshUserEnv = Nothing Set WshShell = Nothing ' quit script with exit code 0 Wscript.Quit 0 Code:
http://192.168.1.6:13579/sendkeys.vbs?%5e%2b%25i - since it can only send keystrokes to the foreground application, and I don't include a check whether it is MPC-HC (i tried, and it worked, but it was so slow, that the whole thing became unusable), so you can get some funky stuff Good thing: - it won't kick out MadVR from Fullscreen Exclusive mode Can I have a feature request to implement this sendkeys feature into MPC-HC's web interface itself? (if it's not hard to do.) In that way we can circumvent the foreground limitation. PS: So I finished modifying Remoti.co Lite Android app (without having the source code, just some silly skinning remained), if somebody interested in it, I can upload it somewhere. - added 2 buttons for subtitle delay - added 1 button to change source level with MadVR - fixed and refactored the after playback entries - modded the default skip interval from 5 sec to 10 sec - switched the size and location of the FF/RW with PrevTrack/NextTrack buttons in portrait mode, since we use them more frequently - added new skin(s)
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 23rd August 2015 at 19:24. |
dxva, media player classic, mpc, mpc-hc |
