6th August 2015, 10:55 | #2121 | Link |
Did some testing on power usage on DXVA scaling by looping a 4Mbit/s 720p h264 video upscaled to 1080p for a few hours and logging the battery level. Also tested different decoding methods (in LAV).
CPU: i5-4200U. Laptop power usage in Watts. Code:
native copy-back software 5.3 5.5 5.5 - EVR (DXVA scaling) 5.1 - EVR-CP (bilinear) 6.3 - EVR-CP (bicubic) 5.9 6.1 6.2 - madVR (DXVA scaling, trade quality for perf.) 5.9 - madVR (bilinear, trade quality for perf.) 2.7 - idle Last edited by ajp_anton; 6th August 2015 at 13:37. |
7th August 2015, 19:13 | #2122 | Link |
Not sure if it was asked, Ive been using mpc-hc internal sub renderer for out of video frame sub (by using screen alignment and margin and untick relative to video frame). Sometime I have 2 line'd subs, which I cant vertically center in the black space if I put setting(bottom margins ) for 1 line'd sub, vice versa. Any workaround to display both 1 line and 2 line'd subtitle vertically center in black space?
10th August 2015, 04:43 | #2124 | Link |
I just found a new issue, though it is kind of moot. If I move my cursor into the red area (or the taskbar), volume control via mouse wheel will stop working. I think this might be a W10 issue because I don't remember this happening before upgrading from 8.1.
10th August 2015, 06:46 | #2125 | Link | |
10th August 2015, 18:00 | #2126 | Link | |
/人 ◕ ‿‿ ◕ 人\
It has something to do with W10, they changed mousewheel behaviour (now it scrolls windows that you hover, not the active one). Last edited by vivan; 10th August 2015 at 20:02. |
12th August 2015, 12:19 | #2127 | Link |
sending standard window messages to madVR through WebUI
I have asked similar question in the madVR thread, but didn't got an answer, but maybe this is the right place to ask.
So, I'm using (more than that I have modded it to add 2 more buttons for subtitle delays, and small other mods ) Remoti.co on Android to remote control mpc-hc. https://play.google.com/store/apps/d...emote&hl=en_GB It communicates generally through the provided WebUI and with the command numbers. Can I send standard window messages (like WM_COMMAND) to MadVR through MPC_HC through it's webinterface? I'd like to change the input level (CRTL+SHIFT+ALT+I) remotely. I tried to capture the hotkeys (CTRL+J, CRTL+SHIFT+ALT+I , etc) in WindowDetective , but mpc-hc doesn't have a clue about them. I took a quick look in the mpc-hc source (WebServer.cpp and WebClientSocket.cpp), and the implementation would be easy IF mpc-hc could talk to madVR somehow. Any idea how to do this? Thank You and for your continous work!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
12th August 2015, 13:26 | #2129 | Link |
12th August 2015, 18:15 | #2130 | Link |
New ASIO Plugin for MPC-HC x64
Hello folks,
great news! Today I got news from Surodev. They sends me a link for the new Surodev ASIO Plugin for mpc-hc x64! Please run register.bat in a command shell as an administrator to properly use the renderer. DOWNLOAD: http://surodev.com/downloads/AsioRendererx64.zip It works fine with my Asus Xonar essence! If you like it too, please donate a little for the project on surodev Website! Last edited by vogelscheuche; 12th August 2015 at 20:13. |
12th August 2015, 20:08 | #2132 | Link |
For ASIO you need Asio drivers. Xonar Cards for example have ASIO drivers. Then you install the surodev Asio plugin as discribed and then you can select it in the mpc-hc options.
In my ears Asio has the best audio quality. For WASAPI Im not 100% shure, but I believe to have read you should use the intern MPC-HC decoder which works with WASAPI. Maybe someone else would know this better. Last edited by vogelscheuche; 12th August 2015 at 20:11. |
12th August 2015, 20:58 | #2134 | Link |
Rather in your mind.
I bet you wouldn't know any difference as long as you don't know the renderer. Like listening to gold-plated digital cables with oxygen-free copper. Bust be better than any standard digital cable. The advantage of ASIO is usually to have a small granularity, so a low latency when changing audio parameters. Interesting for musicians. Less important for sequentially listening. Last edited by LigH; 12th August 2015 at 21:00. |
12th August 2015, 21:33 | #2135 | Link | |
Δ
13th August 2015, 08:24 | #2140 | Link | |
Or at least change your privacy statement to clarify that in some cases data will be sent without the users consent. |
dxva, media player classic, mpc, mpc-hc |
