29th August 2022, 17:19 | #361 | Link | |
Interesting, so it seems that my TV completely ignores the RPU and just plays back the BL, but your player recognizes the RPU and tries to interpret the BT.2020 colorspace as Profile 5, which results in those weird colors. Thanks for checking it out! |
29th August 2022, 23:43 | #362 | Link | |
And again, thank you for the L6 Demuxer script. Works as expected, and I am using the Match L6 option in Injector with successful hybrids as a result. |
30th August 2022, 00:49 | #363 | Link | ||
Would I then convert the Profile 7 8.1 RPU to 8.4? |
31st August 2022, 11:49 | #365 | Link |
There's no point in attempting to convert to profile 8.4 as Apple devices don't support the dynamic metadata.
The only way seems to be tricking the device into thinking the file is profile 5, there's some script on MakeMKV for that.
LG C2 OLED | GitHub Projects |
1st September 2022, 06:26 | #366 | Link | |
Link? |
1st September 2022, 10:26 | #367 | Link |
Unless I'm mistaken, quietvoid is refering to the scripts created by RESET_9999. You'll find the link "DoVi Scripts" in his signature.
Major Dolby Vision thread at MakeMKV: https://forum.makemkv.com/forum/view...602&start=7290 |
1st September 2022, 12:50 | #368 | Link |
A more in-depth guide also exists: https://www.avsforum.com/threads/app...ision.3252865/
I think it requires MP4 files as final video.
2nd September 2022, 10:44 | #370 | Link | ||
QfG Group Germany
if you have a "REMUX" of an UHD, simply use the Demuxer and check the Options for Saving BL and EL (you can turn off RPU extracting, not needed for this operation). now you can Build a UHD with this, for example with TS-Muxer. Quote:
I can add Apple DoVi Injection in future Updates.
2nd September 2022, 11:34 | #371 | Link | |
4th September 2022, 21:02 | #373 | Link | |||
Could someone clarify how I'd get started converting either a Profile 7 or Profile 8.1 file to this fake Profile 5? Also, am I correct in understanding that these Profile 5 files are essentially using Rec2020 colorspace and the same RPU metadata as a Profile 8.1 file? Thanks |
5th September 2022, 17:45 | #374 | Link | |
From there choose further, depending on what kind of source-file, and output wishes. |
7th September 2022, 11:21 | #375 | Link |
https://forum.makemkv.com/forum/view...122442#p122442
https://1drv.ms/v/s!Ahh4FiB9hIuT-EK3...b3amj?e=RKiQG4 How was this created? Was it some real Dolby Vision HLG show and someone just delayed RPU to check the applying of it? Does BBC already Dopby vision hlg on satellites? Last edited by Balling; 7th September 2022 at 11:23. |
7th September 2022, 22:43 | #376 | Link |
Hey, I'm trying to inject an RPU into a HDR file which has a VBR video stream. After injecting, the resulting MKV file has the video stream as CBR and the audio and video is super async.
Any ideas on how to fix this? Thanks! |
8th September 2022, 12:19 | #380 | Link | |
QfG Group Germany
Apple: Many of my P8 Mixes tested succesfully with an Apple TV 4K and Infuse Player.
