Old 13th May 2004, 16:30   #1  |  Link
jggimi
Moderator Emeritus
jggimi's Avatar
--->>> Sticky Archive <<<---
In order to reduce clutter, a number of threads are no longer sticky, though they are of value to the forum:
Words About IVTC and frame schema
Fair Use Q&A
Tips and tricks for Xmpeg 4.5
GOP's: I, P, and B frames explained...
Manual way to make a comp. test with DivX (can be used with other codecs too)
"It is easier for a camel to pass through the eye of a needle if it is lightly greased."
Kehlog Albran, The Profit
jggimi is offline
