Thread Tools Display Modes
Old 5th May 2004, 07:10   #601  |  Link
oddball
ogo has switched his attention to the forums here http://www.avsforum.com/avs-vb/showt...08#post3736708
He seems to be ignoring Doom9 at present for some reason
oddball is offline   Reply With Quote
Old 6th May 2004, 15:59   #602  |  Link
Orezza
hello
In first I wanted to congratulate you for your program reclock, essential
After an idea has to subject to you in the same kind but the with dimensions one of l'image, on the sacades of the traveling due to the passage of the 25 images to the 75Hz explanation here http://www.trimension.com/index.php?page=downloads.html
you think what of it?
@+ ;o)
bad translation sorry , just for lock the rule (#13);o)Wilbert
salut
En premier je voulais te féliciter pour ton programme reclock ,indispensable
Ensuite une idée a te soumettre dans le meme genre mais du coté de l'image,
sur les sacades du traveling due au passage du 25 images au 75Hz explication
ici http://www.trimension.com/index.php?page=downloads.html
tu en penses quoi ?
@+ ;o)
Orezza is offline   Reply With Quote
Old 6th May 2004, 16:03   #603  |  Link
Wilbert
Super Moderator
Please read the forum rules (#13). I suggest you add an english translation/summary.
Old 6th May 2004, 16:09   #604  |  Link
Wilbert
Super Moderator
Btw, I saw him posting this on the avs forum:
Blight: i'm quite surprised. I just tried to play a DRM file (scooby doo 2 trailer) with reclock + WMP9, and to my big surprise reclock is able to use vsync tools with DRM content. I may sound uninteresting, but it means something very important : reclock can access all the video frames in unencrypted format
Indeed i could extend reclock to become a media "(re)encoder". Simply you take any player with any media you want (DVD, streamed media, DRM) , even put ffdshow to tweak or resize the picture if you want, and then reclock could be used as an encoding engine : it would let you choose the codec you want, would be able to reencode at a different framerate, etc ... It could even be used to make 2 pass encoding i believe.
Sounds nice
Old 6th May 2004, 16:49   #605  |  Link
ogo
@oddball : i'm back on doom9 forums Sorry for the inconvenience. I'm aware of audio timestretch bad quality, and i'll probably try again soundtouch library for the next release.
@Orezza: i already know trimension. In fact its quite funny, because trimension was created by the very same philips engineers that creation "digital natural motion" for philips tv sets. I have one of those tv sets, and the reason i wrote reclock in the first place, is that the "trimension" algorithm in my tv was not making its job because of stutter. You can also find another software "motion perfect" that does the same thing as trimension but not in realtime. I think a trimension like algorithm in reclock would be indeed THE solution, but this is a patented software, and i've never been able to understand what is hidden behind and how it works exactly ...
@Mark Rejhon : thanks a lot for your donation I have made you a response on AVS about testing with Powerstrip API. For now, i have tried scanlines add/remove method, but as i was expecting it, my video card (a geforce 3) show artifacts when modifying the scanlines number. For example, if i modifying the scanline number, then wait a few scanlines, and modify scanline number to original values, i get artifacts (whole screen vibrating). Did you have a change to test on geforce cards ?
@clehner : i'm not sure it can work with version 4.0. You will have to switch to 5.0 ...
@Cyberace : i'm not against giving you the source code of reclock to understand how it works, provided you don't give away the source code. But i'm not sure it will help you to develop your xbox player. You said me that this player does not use directshow, but reclock heavily depends on directshow to work ...
@Bitmonster : could you activate logging and send me a logfile ?
I'm our of business for one week (vacation ) so don't expect any response for one week
http://ogo.nerim.net/reclockfilter
ogo is offline   Reply With Quote
Old 6th May 2004, 18:03   #606  |  Link
ogo
@Wilbert : yes it's interesting ...
Old 6th May 2004, 18:26   #607  |  Link
kallekill
I think Philips natural motion looks bad. It gives a kind of artificial look to the picture and it looks like all movies are shot on video. The motion looks more fluid, but it also looks like scenes move faster that they are supposed to.
kallekill is offline   Reply With Quote
Old 7th May 2004, 09:47   #608  |  Link
Bitmonster
@ogo
After I tried to send it to you, I got the following mail error:
maildir delivery failed: Sorry, the user's maildir has
overdrawn his diskspace quota, please try again later.
Bitmonster is offline   Reply With Quote
Old 7th May 2004, 09:56   #609  |  Link
Cyberace
Originally posted by ogo @Cyberace : i'm not against giving you the source code of reclock to understand how it works, provided you don't give away the source code.
Hi Ogo, that would be great as it's more than worth a good look I promise I will only share it internaly to the the Teams developers working on the issue and only for guideline/idea use, please e-mail it to me (link) or upload it here (link)
PS! a few team devs have mentioned ideas about a implementing DirectShow framework for XBMC
Cyberace is offline   Reply With Quote
Old 8th May 2004, 08:16   #610  |  Link
oddball
I'm interested in what that dscaler dude is doing. His idea for realtime genlock sounds intriguing (If somewhat technical for me). Could this be used in ReClock at some later stage do you believe?
Old 13th May 2004, 18:56   #611  |  Link
Ryokurin
since Besweet now has the soundtouch option http://dspguru.doom9.org/soundtouch.html for files, theres yet another time stretching program to check. With so many people working on it, its just a matter of time of someone getting it done correctly.
Ryokurin is offline   Reply With Quote
Old 14th May 2004, 23:05   #612  |  Link
oddball
Yeah! Yeah! Stick it in ReClock!
Old 20th May 2004, 15:34   #613  |  Link
Lobuz
Lobuz's Avatar
@ogo
I'd like to ask again if there is any chance to get rid of that VMR9 renderless vsynch tearing? With VMR7 everything is ok even without reclock.
About Trimension there was an old thread
and at the last post there is a link to some papers of patented algorythms.
Regadrs
Lobuz
Lobuz is offline   Reply With Quote
Old 10th June 2004, 10:44   #614  |  Link
marcobdivax
reclock and power dvd 4.0
@ogo: I've tried to use reclock with pdvd4, but it doesn't start (I've enable logging, but no log files); any suggestion?
Thanks
Marco
Proc.: AMD AthlonXp 1700+ Motherboard: DFI AD75Pro RAM: 512 Mb 333Mhz Disks: MAXTOR 60GB+IBM 40GB IDE-Ata133 Graphic card: Sparkle Geforce4 MX440 (with s-video) Audio card: Extreme 5.1 Nr. of speaker: 6 DVD: LG 16x CD-RW: Liteon 40x10x48x Monitor: Nokia 447S+LCD videoprojector O.S.: Windows 2000 Prof. SP3
marcobdivax is offline   Reply With Quote
Old 11th June 2004, 12:15   #615  |  Link
Cyberace
Hi Ogo, we're still waiting patiently for the source code (still haven't received them, maybe you forgot? )
Old 11th June 2004, 20:30   #616  |  Link
oddball
Re: reclock and power dvd 4.0
Thanks
Marco
Don't use PowerDVD.
Old 13th June 2004, 11:16   #617  |  Link
marcobdivax
reclock and powerdvd
Good answer, but "powerdvd buyed, and reclock set to use it" is another good answer.
bye
Marco
Old 18th June 2004, 13:00   #618  |  Link
demonslayer
Re: reclock and powerdvd
Actually "bought PowerDVD and set reclock to work with it" would be a good answer.
DeMoN
demonslayer is offline   Reply With Quote
Old 19th June 2004, 20:51   #619  |  Link
Cyberman
Cyberman's Avatar
Well, I guess it doesn´t entirely fit in here, but since the symptons are similar to what ReClock cures, I´ll write.
I thought my system had that the timer were asynchronous, but as it turns out it rather was/is Windows default Video renderer. When I switched from "System Default" to "Old Renderer"(Media Player Classic, Options->Playback=>Output), the video ran smoothly.
Cyberman is offline   Reply With Quote
Old 22nd June 2004, 15:39   #620  |  Link
marcobdivax
Re: Re: reclock and powerdvd
DeMoN
Very useful, thanks demon. This is a helpful thread.
Thread Tools
