Thread Tools Display Modes
Old 28th May 2015, 00:51   #2301  |  Link
Zachs
Suptitle, MediaPlayer.NET
@AnimeViewer
BTW, the dump file is located in %localappdata%\MediaPlayerDotNet.exe.dump
Can you check if you have such a file please?
Zachs is offline   Reply With Quote
Old 28th May 2015, 00:53   #2302  |  Link
Zachs
Originally Posted by Anime Viewer View Post
I paused a scene where there are a couple of different shades of red, but I'm not seeing a difference between it being enabled/disabled.
Does the video have to be running in Full Screen Exclusive Mode for the improvement to happen?
How about settings? Any particular ones that might make it stand out more, or where other effects might make it less noticeable? (For example: with or without render scripts running, with or without debanding, with or without dithering, with any particular Presentation API (D3D 11, 10.1, 9Ex), with any particular color settings (ex: PC Range BT 601, 709 or 2020, Full or Limited Output, 8,10,or 16 bit bit depth, using any particular up/down scalers?
Run it without render scripts. Bright fully saturated red is the easiest to see the changes.
EDIT: This is assuming the proper colorimetric has been used. If the encoder lied about it then that's a separate issue.
Old 28th May 2015, 00:56   #2303  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
Originally Posted by Zachs View Post
@AnimeViewer
Ah ha! I found it there. Here is the dump which I opened and copied from Notepad:
*** Thread 1 ***
Stack Trace:
Mpdn.VideoFrameServices.DxgiPresenter.DxgiPresentEx(IntPtr, Int32)
DomainBoundILStubClass.IL_STUB_PInvoke(IntPtr, Int32)
Mpdn.D3D9VideoRenderer.FrameComposer.Dx11.FrameComposer.Present(Int64 ByRef)
Mpdn.D3D9VideoRenderer.VideoRenderer.PresentInternal(Int64 ByRef)
Mpdn.D3D9VideoRenderer.VideoRenderer.Present(Boolean, Boolean, SharpDX.Result ByRef, Int64 ByRef)
Mpdn.VideoPlayer.VideoPlayer.Present(Boolean, SharpDX.Result ByRef, Int64 ByRef)
Mpdn.VideoPlayer.VideoPlayer.WaitAndPresent(Int64, Int64, Boolean, Boolean, Int64 ByRef)
Mpdn.VideoPlayer.VideoPlayer.Present(Int64, Int64, Boolean, Int64 ByRef)
Mpdn.VideoPlayer.VideoPlayer.Present()
Mpdn.VideoPlayer.VideoPlayer.PresentSample(Mpdn.VideoPlayer.MediaSample)
Mpdn.VideoPlayer.VideoPlayer+<>c__DisplayClass2.<set_EnableFullScreen>b__0(Boolean)
Mpdn.VideoPlayer.VideoPlayer.SyncRendererInvoke(System.Action`1<Boolean>)
Mpdn.VideoPlayer.VideoPlayer.set_EnableFullScreen(Boolean)
MediaPlayerDotNet.MainForm.†††
†††‡ˆŽ(System.Object, System.Windows.Forms.MouseEventArgs)
System.Windows.Forms.Control.WmMouseUp(System.Windows.Forms.Message ByRef, System.Windows.Forms.MouseButtons, Int32)
System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
DomainBoundILStubClass.IL_STUB_ReversePInvoke(Int64, Int32, Int64, Int64)
System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
DomainBoundILStubClass.IL_STUB_PInvoke(MSG ByRef)
System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
†††‡•š.†††
†††‹•(System.Object)
†††‡•š.†††
†††‡•›(System.Object)
<PrivateImplementationDetails>{B078818A-34A0-41B9-9995-5CD01146F517}.Main(System.String[])
*** Thread 2 ***
Stack Trace:
*** Thread 4 ***
Stack Trace:
System.Threading.WaitHandle.WaitOneNative(System.Runtime.InteropServices.SafeHandle, UInt32, Boolean, Boolean)
System.Threading.WaitHandle.InternalWaitOne(System.Runtime.InteropServices.SafeHandle, Int64, Boolean, Boolean)
Mpdn.Threading.TaskThread.DoWork()
System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
System.Threading.ThreadHelper.ThreadStart()
*** Thread 10 ***
Stack Trace:
System.Windows.Forms.UnsafeNativeMethods.WaitMessage()
*** Thread 13 ***
Stack Trace:
System.Threading.WaitHandle.WaitMultiple(System.Threading.WaitHandle[], Int32, Boolean, Boolean)
System.Threading.WaitHandle.WaitAny(System.Threading.WaitHandle[], Int32, Boolean)
Mpdn.VideoPlayer.DirectShowVideo.HandleEvents(Microsoft.Win32.SafeHandles.SafeWaitHandle, Microsoft.Win32.SafeHandles.SafeWaitHandle)
Mpdn.VideoPlayer.DirectShowVideo.HandleEvents(System.Object)
Mpdn.Threading.WorkerThread+<>c__DisplayClass6.<.ctor>b__4(System.Object)
System.Threading.ThreadHelper.ThreadStart(System.Object)
*** Thread 14 ***
Stack Trace:
Mpdn.VideoPlayer.VideoPlayer.PresentLoop()
Mpdn.Threading.WorkerThread+<>c__DisplayClass2.<.ctor>b__0()
*** Thread 15 ***
Stack Trace:
System.Threading.Monitor.Enter(System.Object)
Mpdn.VideoPlayer.VideoPlayer.RenderLoop()
*** Thread 18 ***
Stack Trace:
Mpdn.VideoPlayer.VideoPlayer.UpdateVideoFrame(Mpdn.VideoPlayer.MediaSample)
Mpdn.VideoPlayer.DirectShowVideo.Mpdn.VideoPlayer.ICallbackFilterCB.SampleCb(Int64, DirectShowLib.IMediaSample)
DomainBoundILStubClass.IL_STUB_COMtoCLR(Int64, IntPtr)
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Anime Viewer is offline   Reply With Quote
Old 28th May 2015, 01:01   #2304  |  Link
ryrynz
ryrynz's Avatar
I've just done a number of comparisons on fairly red scenes and the changes are made on edges mostly. I've found the changes on either brownish or whiteish edges/areas, but yeah the changes are very subtle.. most of the time you actually won't notice them.
Old 28th May 2015, 01:06   #2305  |  Link
Zachs
Right. Just as I feared.
I'll continue this in PM with you since it looks like it's specific to your Optimus system only.
Old 28th May 2015, 01:29   #2306  |  Link
ryrynz
ryrynz's Avatar
This is the best example of the changes chroma reconstruction makes I've seen so far. The changes are certainly more noticeable with sharper resizers (lanczos, NNEDI3) These were taken using Lanzcos 16 tap AR.
The whites really do lighten up here, probably one of the best examples I could have hoped to find as all other changes have been relatively minor.
http://screenshotcomparison.com/comparison/128955
Old 28th May 2015, 01:38   #2307  |  Link
so it tries to counter the tons of artifacts from lanczos 8/16?
Old 28th May 2015, 01:45   #2308  |  Link
Zachs
No. It uses the information that would've otherwise been disposed off so it gives better quality.
Old 28th May 2015, 01:49   #2309  |  Link
why is lanczos 16 is needed than to show something off there must be better examples.
Old 28th May 2015, 01:57   #2310  |  Link
Zachs
Lanczos 16 causes more values to go out of range after scaling so the effect is more profound.
Old 28th May 2015, 02:07   #2311  |  Link
Zachs
As long as I set the Video Input Colormetric to one of the PC Ranges it looks fine, but if my system mis-detects the video, and sets it to one of the TV Ranges (while set to automatic) then I get the results I previously posted.
Righto! I found a bug in MPDN's automatic colorimetric detection logic! Specifically if the 720p clip doesn't have actual a height of 720 pixels, it assumes it's not HD!
This has been fixed in the next release.
Many thanks to ryrynz for discovering this.
Old 28th May 2015, 02:10   #2312  |  Link
does it work with RGB sources or 4.4:4 source?
Old 28th May 2015, 02:22   #2313  |  Link
here an extreme example:
http://screenshotcomparison.com/comparison/128957
i crippled a RGB source to 4:2:0 to make it work.
it turns some pixel totally black that shouldn't be black but i guess it gives an idea what it does.
Old 28th May 2015, 02:23   #2314  |  Link
Zachs
Depending on how you're scaling your chroma. If you scale it to target size directly with something like lanczos 16 then it may have some effect. I suspect you won't be able to see any difference but I haven't tested this myself.
Old 28th May 2015, 02:25   #2315  |  Link
Zachs
Is your RGB source closer to CR on or off?
EDIT: If you look closely at the disabled icons on the sidebar, you'll find CR on to do exactly what was intended to. There's no colour bleed at all and it shows a clear alternating pattern that I would image what the original looked like.
Old 28th May 2015, 02:28   #2316  |  Link
yes and no.
the luma is closer the chroma is way off with CR on
EDIT: let me say it with other more correct words.
it removes chroma bleeding and under saturates chroma. most parts where chroma details shouldn't by they are not there anymore so the "luma" looks way more correct.
Old 28th May 2015, 02:37   #2317  |  Link
Zachs
Well it's done its job then!
But can you post the RGB and crippled version of that clip somewhere so we could take a look at it to see if we could improve it?
Old 28th May 2015, 02:38   #2318  |  Link
ryrynz
ryrynz's Avatar
Hey Huhn can you link the 4:2:0 and the RGB source? I think that might be useful for tweaking chroma.
I guess ideally I'd really like to get my hands on a proper chroma test pattern to compare in that way to find accurate to the source chroma upscaler settings.
Old 28th May 2015, 02:43   #2319  |  Link
here is the RGB version.
http://www.file-upload.net/download-...0-001.mkv.html
i forced lavfilter to NV12 output to get a 4:2:0 video of this so i don't have an encode of it.
but not sure if a normal video should be judge on a pixel art video like this.
Old 28th May 2015, 02:45   #2320  |  Link
Zachs
The same principal applies to normal video - chroma bleed is never desirable.
direct3d, mpdn, nnedi3, opencl, reclock
Thread Tools
