Thread Tools Display Modes
Old 26th June 2012, 22:07   #121  |  Link
qyot27
qyot27's Avatar
On the System Setup page on Github, both FFmpeg and FFMS2 have full checkinstall commands. And while the instructions there are geared toward the release tarballs and therefore have simple version numbers to parse, AvxSynth itself is left with a plain sudo make install.
The below is the checkinstall line I've been using for AvxSynth:
sudo checkinstall --pkgname=avxsynth --pkgversion="1:$(grep "Version" avxsynth.pc | \
    cut -f2 -d " ")+$(git rev-list HEAD | wc -l)-$(git rev-list HEAD -n 1 | cut -c 1-7)-$(date +%Y%m%d)" \
    --backup=no --deldoc=yes --fstrans=no --default
which results in:
$ sudo apt-cache show avxsynth
Package: avxsynth
Status: install ok installed
Priority: extra
Section: checkinstall
Installed-Size: 11356
Architecture: i386
Version: 1:4.0+137-b2eb3c3-20120625-1
Provides: avxsynth
Description: Package created with checkinstall 1.6.2
Old 26th June 2012, 22:38   #122  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Hmm, that's a useful command you got there qyot27. I'll probably steal it once I get my new i7 Ubuntu rig up.
Old 26th June 2012, 23:00   #123  |  Link
sl1pkn07
Pajas Mentales...
@qyot27: ubuntu?
to build package in ubuntu/debian: "dpkg-buildpackage -b" in avxsynt folder.. avxsynth have all to build package without checkinstall
sl1pkn07 is offline   Reply With Quote
Old 27th June 2012, 12:01   #124  |  Link
qyot27
qyot27's Avatar
I know about the buildpackage support, but I can't be bothered to use it. The only users who should really care about making repository-safe packages are those maintaining a repo, not the casual user that just wants it logged in the package manager.
It still doesn't change the fact that if it were so important to use the 'Debian way' to build the package (which it really isn't, aside from repo maintainers), then it still doesn't explain why it's not given as the final step on the installation page, with make install used instead. And considering said installation page assumes the use of an Ubuntu system (as that's the distro AvxSynth development is targeted to anyway), either packaging method would be valid and superior to a plain make install.
Old 27th June 2012, 14:31   #125  |  Link
sl1pkn07
Pajas Mentales...
is it more difficult:
dpkg-buildpackage
cd ..
sudo dpkg -i libavxsynth* avxedit*
instead of:
autoreconf -i
./configure
make
Use checkinstall instead of make install, because if you use make install, when deleting sources you may need to uninstall 2 method:
Rebuild sources and make uninstall (in the same prefix) or delete files installed one by one.
Using checkinstall (and dpkg-buildpackage) is easier than removing/updating the build using the system package updater. (apt-get, dpkg, packagekit,synaptic, etc)
Old 28th June 2012, 01:33   #126  |  Link
I like the IDEA of LINUX, and the demise of MS, but really, not gonna happen any time soon.
If only Linux could differentiate between eg a word processor program and some other.
Under Windows, you might have a program called eg Office stuff, under Linux
it will almost certainly be called giraffe or duck billed or whatever..
I hate Windows, and Linux, but not in equal measure.
Old 28th June 2012, 01:37   #127  |  Link
sl1pkn07
Pajas Mentales...
openoffice, libreoffice calligra.....
Old 28th June 2012, 01:46   #128  |  Link
Can you suggest a solution for those unfortunate giraffe fixated users amongst us.
Old 28th June 2012, 01:51   #129  |  Link
Let's stay on topic, guys.
Old 28th June 2012, 01:51   #130  |  Link
sl1pkn07
Pajas Mentales...
oh. sorry (the offtopic). giraffe is a circuit simulator?
ktechlab?
Old 28th June 2012, 01:54   #131  |  Link
sl1pkn07
Pajas Mentales...
okidoki
Old 28th June 2012, 02:10   #132  |  Link
sl1pkn07, Open source?
Maybe like Spice. Nice Spice simulator would be well good.
Old 26th July 2012, 16:37   #133  |  Link
e1897876
Hello,
Does someone know if it is somehow possible to get the following AviSynth script working with AvxSynth (or which lines will work at least)? The functions (.avsi) used here are attached. I think, the video source could be modified as ffdshow tryouts doesn't exist under Linux.
setmtmode(5,0)
SetMemoryMax(512)
video=ffdshow_source().changefps(ffdshow_source(), linear=true)
A=video
setmtmode(2)
SetMemoryMax(712)
B=a.SPresso_JD()
C=a.SeeSaw_JD(B).LimitedSharpenFaster_JD(strength = 11)
return C
GetMTMode(false) > 0 ? distributor() : last
The other way round would be OK, too: will
- RemoveGrain-1.0
- masktools-v2.0a35
- mvtools-v2.5.11.3
- VariableBlur040
- warpsharppackage_25_dll_20031103
somehow be available with AvxSynth? That would be great!
If that should be a dead end, has someone an idea which combination of ported filters (Built-in-Functions) would offer similar functionality?
Thanks for helping and regards.
e1897876 is offline   Reply With Quote
Old 2nd August 2012, 15:32   #134  |  Link
e1897876
Really guys, no ideas?
Old 2nd August 2012, 15:54   #135  |  Link
sl1pkn07
Pajas Mentales...
- RemoveGrain-1.0
- masktools-v2.0a35
- mvtools-v2.5.11.3
- VariableBlur040
only exist port for Removegrain and masktools, but don't work
to load video use ffmpegsource instead ffdshow (only windows)
all "set" modes don't exist in avxsynth
Old 2nd August 2012, 19:30   #136  |  Link
e1897876
OK for now, thanks for those hints.
Old 14th October 2012, 08:30   #137  |  Link
btb
AvxSynth working on OSX, for anyone interested
https://github.com/avxsynth/avxsynth/issues/83
btb is offline   Reply With Quote
Old 17th October 2012, 15:43   #138  |  Link
videophool
Excellent contribution. Thanks.
videophool is offline   Reply With Quote
Old 6th November 2012, 22:59   #139  |  Link
Adub
Adub's Avatar
Hmm, I'm currently doing some research on the innards of AvxSynth, specifically the Cache and InternalCache mechanisms. Is there any documentation anywhere about their internal use for the built in functions? Is the Cache used by default throughout the full filter chain, or is it a more pick and choose situation per filter?
For context, I'm going to start work on porting some of the built in functions to CUDA (specifically the ones with disabled MMX and SSE) for some academic research, and if I can modify the internal cache in such a way so that I can keep the frame data on the GPU as long as possible, the greatest performance gains will be achieved. Otherwise if we are sending the frames back and forth across the bus, we lose a lot of speed due to the extra transmission overhead.
Old 7th November 2012, 02:09   #140  |  Link
mandarinka
mandarinka's Avatar
If you care about unix environments, Vapoursynth is probably much more viable project to contribute to: http://forum.doom9.org/showthread.php?t=165771
mandarinka is offline   Reply With Quote
Thread Tools
