Thread Tools Display Modes
Old 21st January 2016, 20:36   #261  |  Link
qyot27
qyot27's Avatar
Originally Posted by perforator View Post
I just wonder if one can run all scripts made for Avisynth in Avxsynth ? Or is it perhaps more depending on different plugins?
No, it cannot. Only *maybe* five plugins were ever ported to AvxSynth. Only the core functions mostly work (although a couple are disabled).
More precisely these made by "videoFred" http://forum.doom9.org/showthread.php?t=144271
And I don't think any of those plugins were the ones that did get ports.
You're best off installing AviSynth and plugins under Wine and then either encoding with Windows builds of FFmpeg, x264, etc. or piping to native Linux builds of those tools with avs2pipemod or a Windows build of FFmpeg. Or trying to replicate those scripts in Python with VapourSynth and its plugins (which are available natively).
Old 21st January 2016, 20:56   #262  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
This project is as dead as it gets; VapourSynth is a Linux-compatible replacement. The scripts aren't Avisynth compatible, but yours likely can easily be reworked into VS scripts, most of the common plugins have been ported. As a side benefit, it's a lot faster than Avisynth.
Thread Tools
