#202 | Link |
Glad you showed up. Will x264 perform well enough in a VM? Would I have to use something like kvm or xen for decent performance? Also, I don't mean to be a skeptic, but with a set of IVTC filters (I'm assuming that's what decomb is) working in avxsynth, do I -really- need anything else for dealing with a simple transport stream or DVD?
#203 | Link |
unsigned int
You should know that if you have several vobs that go together (as DVDs do), ffms2 is not all that good. It will lose and/or duplicate a frame or a few at the points where one vob ends and the next one begins. You can probably work around this problem by concatenating the vobs (a simple "cat" command) and feeding the result to ffms2.
Buy me a "coffee" and/or hire me to write code! |
#204 | Link | |
If you want to do special filtering (smoothing, masking, etc.), then you're better off just using AviSynth through Wine, and giving it to Windows builds of x264 and FFmpeg, also under Wine. It works fine, and only a couple of things that get too Windows-specific won't work that way (like DirectShowSource). Wine's really not that magical. I use it fairly often to do encodes with HCenc on our iMac, and have used x264 on occasion on there for some anime encoding - it works without issues.
The only tricky part is setting up ffdshow's VFW interface correctly, which you have to do through Wine's version of Regedit by exporting your settings under Windows and then importing them under Wine after you've installed ffdshow (you may also need it to add stuff to Wine's PATH, but there are GUI utilities that can do that, or you could just throw everything in ~/.wine/drive_c/windows). If all there is is opening a file, performing IVTC, and resizing or similar things that are included in the core itself, then AvxSynth is fine. Quote:
#205 | Link |
I'll probably stick with AvxSynth then. If I'm just dealing with a DVD or transport stream its probably best if I didn't do anything but IVTC it and encode. If someone wants motion sickness inducing interpolation and added banding from sharpening filters they can do it themselves during playback.
#206 | Link |
Hello, I did some testing playing with the instruction left by qyot27.
I got two questions. * I compiled mplayer with fffmpeg support, avxframeserver works with a test file and starts mplayer correctly, now when i try to open it directly with mplayer, it fails while it works if i use ffmpeg to encode directly.. Code:
avxFrameServer version.avs # works mplayer version.avs # does not works, open nothing. ffmpeg -i version.avs version.avi (...) # works and encode correctly * When the avisynth script has a wrong syntax or an error in it, the test will not work, but it will not display any error. Anyway to have the "error back"?
http://esby.free.fr/ |
#208 | Link | |
mpv (and mplayer2) removed this discrete demuxer and rely only on libavformat's AviSynth capability. It should work in mpv just as it does in ffmpeg (or ffplay). Just don't try to seek in your script unless you're using FFmpeg 2.1.1. |
#209 | Link |
@qyot27: thx for the answer, the feature seems unsupported for mplayer, even with -demuxer lavf. Since I can open it with avxFrameServer it's not a big issue.
I also discovered that commenting out LOG_PATH=... in ~/.avxsynth/avxsynthlog.conf displayed the information on the error in the script on stderr. Maybe this should be worth putting somewhere in the documentation...
#210 | Link |
I am bumping the thread, but because I got two questions to ask:
* trying to use avxsynth again, the video will not load using mplayer and avxFrameServer. (under debian 7 - 64 bits) Code:
$ avxFrameServer version.avs No valid avxsynth log path found in <snip> INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1332,Type=Info,Message=Loading core built-in plugins INFO : Module=builtinfuncs::entryPoint,Address=builtinfunctions/src/AllBuiltInPluginsEntryPoint.cpp:649,Type=Info,Message=AddAviSynthBuiltInFunctions INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:783,Type=Info,Message=StringDump: Allocating new stringblock. INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1219,Type=Info,Message=Plugins Dir: /opt/ffmpeg/lib/avxsynth/ INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1219,Type=Info,Message=Plugins Dir: /opt/ffmpeg/lib/avxsynth/ INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1219,Type=Info,Message=Plugins Dir: /opt/ffmpeg/lib/avxsynth/ INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1491,Type=Info,Message=Examining plugin /opt/ffmpeg/lib/avxsynth//libavxframecapture.so INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:341,Type=Info,Message=Prescanning plugin: /opt/ffmpeg/lib/avxsynth//libavxframecapture.so INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1491,Type=Info,Message=Examining plugin /opt/ffmpeg/lib/avxsynth//libavxsubtitle.so INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:341,Type=Info,Message=Prescanning plugin: /opt/ffmpeg/lib/avxsynth//libavxsubtitle.so INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1491,Type=Info,Message=Examining plugin /opt/ffmpeg/lib/avxsynth//libautocrop.so INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:341,Type=Info,Message=Prescanning plugin: /opt/ffmpeg/lib/avxsynth//libautocrop.so INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1491,Type=Info,Message=Examining plugin /opt/ffmpeg/lib/avxsynth//libavxffms2.so INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:341,Type=Info,Message=Prescanning plugin: /opt/ffmpeg/lib/avxsynth//libavxffms2.so INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:1219,Type=Info,Message=Plugins Dir: /opt/ffmpeg/lib/avxsynth/ INFO : Module=core::expression,Address=core/src/core/parser/expression.cpp:551,Type=Info,Message=Call: version INFO : Module=core::text-overlay,Address=core/src/filters/text-overlay.cpp:1206,Type=Info,Message=ApplyMessage::ApplyMessage INFO : Module=appInterface,Address=frameserverlib/src/avxSynthAppInterface.cpp:193,Type=Info,Message=MPlayer command line: mplayer -flip -demuxer rawvideo -rawvideo w=896:h=176:format=bgr24 - 1> /dev/null No stream found. ERROR : Module=appInterface,Address=frameserverlib/src/avxSynthAppInterface.cpp:213,Type=Error,Message=mplayer process exited INFO : Module=core::avxsynth,Address=core/src/core/avxsynth.cpp:769,Type=Info,Message=StringDump: DeAllocating all stringblocks. Any explanation of what is happening? I compiled again *everything*, no success here... (I have more or less the same configuration at home and it works fine ~~) Edit: I updated mplayer (was using svn version) and it is working again. * I am lacking a correct deinterlacer, I am trying to handle rushs coming from my Panasonic GH2 camera, (avchd) which are interlaced, I'd use yadiff under ffmpeg or avisynth to treat these, but I can't with avxsynth, as far I know. How hard would it be to create an avxsynth external plugin for that purpose? Is there any documentation on this? Any alternate options (eg: using ffmpeg to deinterlace or coding something that relay on ffmpeg like ffmpegsource)? Thanks in advance.
http://esby.free.fr/ Last edited by esby; 18th April 2014 at 17:50. |
#211 | Link |
One of the few plugins that was ported to AvxSynth was Decomb, so you could try to do field matching before or in lieu of giving it to FFmpeg's yadif filter.
avxFrameServer has been pretty much irrelevant for a little over a year, simply because the support in x264 and FFmpeg have eclipsed it. If you need to pipe the script around (which is all avxFrameServer does), use FFmpeg with -f yuv4mpegpipe to do it. Code:
ffmpeg -i version.avs -f yuv4mpegpipe - | mplayer - I'll also reiterate that mpv will work fine for playing back the scripts (with audio, too) if you build it against the working copy of FFmpeg. |
#212 | Link |
Assuming FieldDeinterlace must be used in this case, but it is just crashing (SIGSEV) when I try to use it.
I guess I'll have to transcode and deinterlace the videos using ffmpeg (since I want to do transitions...) prior loading them with avxsynth...
http://esby.free.fr/ Last edited by esby; 21st April 2014 at 12:55. |
#213 | Link |
TIVTC Support
OK, dumb question, but is it possible to use any of Tritical's filters (specifically looking for TIVTC package) in avxsynth? Based on previous posts, it sounds like only Decomb has been ported, but not sure if that's current info.
I've always found tfm + tdecimate to be superior to telecide + decimate in avisynth, so wondering if I can harness that power in Linux. |
#214 | Link |
Thanks for the info, helped getting things setup and almost working perfect
![]() my goal is simply to encode an avs from ffmpeg . Right now, this works OK I am able to load a video + audio, audiodub them and feed it to ffmpeg. However, whenever I try to trim something that starts 15 frames after the beginning, it seems to be redoing the index (or at least, it takes a long while before the encode starts). if on the other hand I use trim(0,100) for example, the encode starts right away. Eventually the encode does work, but it's either reading the full video / redoing the index each time. Maybe when doing a trim from 0 to 14 frames it doesn't use the index and starts fast, but anything after that will use the index? When building the ffms2 package from Git, I am getting the following error though ... could be the cause : Code:
ffms2 # make CXXLD src/index/ffmsindex libtool: link: warning: `-version-info' is ignored for programs src/core/.libs/libffms2.so: undefined reference to `av_frame_free' src/core/.libs/libffms2.so: undefined reference to `av_frame_unref' src/core/.libs/libffms2.so: undefined reference to `av_frame_alloc' collect2: ld returned 1 exit status make: *** [src/index/ffmsindex] Error 1 ![]() EDIT1 : I just launched another test with normal length files (10-20 mins files) being joined as such : Code:
fadeio(out1,10).trim(100,200)++fadeio(out2,10).trim(100,200)++fadeio(out3,10).trim(100,200)++fadeio(out4,10).trim(100,200)++fadeio(out5,10).trim(100,200) it took about 24mins to start encoding, compared to instant if I take off the trims. When doing a test with a <60s file, it goes through with the encode eventually, but taking a while. with a 19 seconds sample, it took 13s to start encoding. with a 73s sample, it took 54.6s to start encoding I tried with audio joined through audiodub on the 73s sample, it took 55s so negligible difference. EDIT 2 : Actually, none of these encode anything after a more thorough review.,, then end with an unknown error occurred. I did some more tests, for instance using a trim(0,100) everywhere and this works 100%. However, if I use trim(0,100) then a trim(100,200) then a trim(0,100) again, it will start encoding instantly on the first portion, but then stops at the second one AND fail with error : FFAudioSource: ReadPacket unexpectedly failed to read a packet If I remove the audio part, there's no error in ffmpeg but it doesn't process the frames with the trim starting at 100 Last edited by magnatique; 12th May 2014 at 19:36. Reason: more info |
#215 | Link | |
But you're not providing other necessary information: FFmpeg/Libav version, which distro, the full script. Whether or not you rebuilt avxffms2 after building FFMS2 from Git... Remember, it's far less of a hassle to just use ffmsindex -t -1 inputfile.ext before trying to load the script anywhere than letting it generate when the script loads. |
#216 | Link |
Hi folks,
I would like some details about TIVTC-Linux: https://github.com/fundies/TIVTC-linux Do you have any idea if it's compatible with the last avxsynth and how to use it? Someone already asked on the git, but still no answer. If not, what are you using to perform IVTC? manma wrote about decomb I know. (I'm using a dedicated server without graphic interface, debian weezy) cheers |
#217 | Link | |
Professional Code Monkey
2. If you want a TIVTC like filter on linux there's VIVTC (TIVTC lite) available as an integrated filter in FFmpeg and also included with VapourSynth. 3. Just let AvxSynth rest in peace, FFmpeg can do just about everything on AvxSynth can on its own...
#218 | Link | |
First of, FFMpeg has some issues for decoding .mpv (MPEG2 HDTV) with glitch and broken frames.
Secondly, I'm aware that ffmpeg can deal with that but here is a thing. I want to encode using the tMod version of x264 through .avs. You see know why I need to IVTC in .avs. Because I can't compile ffmpeg with tMod support. I must to patch ffmpeg first (like that: https://astrataro.wordpress.com/2014...d/#comment-783) but it's out of date and some parametres are missing. VapourSynth ins't available for Linux. Am I right? |
#220 | Link | |
Posts: n/a
No, you're not. Last edited by macromizer; 14th August 2014 at 15:17. |
| Thread Tools | |
| Display Modes | |
